Andy Neill
- Nov 26, 2001
"..the crew didn't realize what "mode" the computer was in. "
Therefore, Pilot error.
However, were there no FBW ( direct mechanical control ) and no "modes" to deal with there would have been no crash.
Hmmm. A conundrum.
Next: Which came first? The Chicken? Or, the Egg?
MKR
Yup you are wrong and it wasn't the Paris Air Show...Try the Paris Air Show years ago when the flight computer landed the jet in the forest. Trying to do a low pass the crew didn't realize what "mode" the computer was in. It was landing. Crews advanced throttles and rotated the aircraft, both actions were overridden by the computer logic. Am I wrong here? It was a long time ago.
2 bodies found, and a suitcase now too from that flight
On a Boeing, if I override the autothrottles (just by moving them) or kick the autopilot off, I have control of the airplane. Period. The end.
Thanks Filejw for the good catch! Unfortunately, my memory is the second shortest thing I own anymore.Yup you are wrong and it wasn't the Paris Air Show...
Hmmm. A conundrum.
Yes you are wrong, the crew did not advance the thrust levers to TOGA in initiate a go-around. So the airplane thought it was still landing, not the smartest thing in the world...but like they say garbage-in, garbage-out.
Sorta...how many go-around's are performed in A320's during a year? How many have had a similar result?
I don't disagree, manual inputs provide a better "feel" but you can't argue with statistics.
I found this on a different site...
02:10Z:Autothrust off
Autopilot off
FBW alternate law
Rudder Travel Limiter Fault
TCAS fault due to antenna fault
Flight Envelope Computation warning
All pitot static ports lost
02:11Z:Failure of all three ADIRUs
Failure of gyros of ISIS (attitude information lost)
02:12Z:ADIRUs Air Data disagree
02:13Z:Flight Management, Guidance and Envelope Computer fault
PRIM 1 fault
SEC 1 fault02:14Z:Cabin Pressure Controller fault (cabin vertical speed)
Looks like you need to read up on Introduction to Avionics Systems, If you paid attention and READ the whole page, you would of known your quote is someones interpretation of what happened.
Further more ISIS doesn't have gyros, it has a solid state sensor.
And your a A320 FO lol ..
The crew did advance to TOGA but way too late! N1 had only gotten up to 85% when they started hitting trees. Full stick back was also applied but Alpha Protection limited the pitch angle The airplane did all it could and did respond to the pilot inputs but would not let him STALL it, just as advertised. They went through the trees wings dead level and only had 3 deaths. That accident was 20 years ago and still people can't get it straight.
Like I said they did not select TOGA to initiate a go-around, flying through the tops of the trees is a little too late.
Has anyone heard anything else after the news about having found 2 bodies?
You'd think that a P-3 with sonobuoys - ones that can find a sub that is trying to hide - could find a CVR and FDR that wants to be found.
Any one have info on that aspect?
Someone tell me what the issue is with the pitot tubes. Are they aerodynamically deficient, or is it a matter of heating? What's the theory of the link to the AF 447 crash?
On Sunday, Dominique Bussereau, the French secretary of state for transportation, told RTL radio that the authorities were focusing on a transmission from the plane, during the last minutes of flight, indicating that airspeed readings on its onboard systems were inconsistent.
“The series of readings represent the only real element for investigators at this moment,” he said. In particular, they were reviewing the performance of a Pitot tube, part of the speed measurement system.
“There have been situations on Airbus planes, and perhaps on others, where these tubes no longer indicated the airspeed because it entered a humid area, a low-pressure area, an area of turbulence,” he added. If the Flight 447 pilots could not read the correct speed, the plane could have been flying too slowly or too fast, with deadly results.
French investigators announced Saturday that the plane had been scheduled to have its Pitot tube replaced, but it remained unclear whether the part had malfunctioned or had anything to do with the crash.
