Age 60 informal poll
Abolish the Age 60 Rule for other that Part 91 pilots?
  • Yea
    Votes: 668 35.5%
  • Nay
    Votes: 1,214 64.5%
  • Total voters
    1,882
Foxhunter,
That paragraph was written for a reason and one reason only – to protect everyone’s butts in case of an age 60+ pilot that is involved in an accident or incident from a crippling avalanche of lawsuits.
No, it was written because it was the finding of the studies. You just can't accept the fact that experience results in a better outcome. You will find that incidents/accidents are the lowest among those close to age 60.
Here's a gem from a month ago that I missed. Hey Bozo, you're flapping your yap about ending "discrimination" against pilots and yer fellow Americans... yet here you mention "age 65 is a must".
So tell us Einstein, why is 65 okay and not discriminatory? Why not 67 or 70? I mean, if you put any fixed number on it, it's discrimination, right??
Actually, this post you made is the closest you've come yet to ackowledging that the whole debate is about the cash and not discrimination... but you still hide behind the "discrimination" label. Nice.
The fact is that 99% of the reason age 60 has not changed has been the raising of the "safety" flag. ALPA/APA/FAA have all used it. It is like the argument that for "safety" jet aircraft had to have three pilots in the cockpit. The result was that multi-thousand PFEs were replaced with new hire pilots with 200 hours total time. Safety or a jobs issue? The 737 when introduced was certified as a two man airplane but ALPA forced a three man cockpit, resulting in one long bitter strike at Wien Alaska. Was the three man 737 a safety or jobs protection issue? What is the make up of 737 cockpit crew today?
When you remove the safety issue you will find little support in the political arena. Yes, age 65 is another hard number, but it is an improvement. There is also a good chance after a few years with the age 65 limit that also will either increase or be eliminated.
The 737 was certified 2 pilot while the Super 80 was initially 3 pilots. ALPA wanted to spare the larger DAL pilot group the dirty work, so they stuck Frontier with the task of holding the line on 3rd pilot. Frontier did not hold the line and it fell to Wien Alaska. Frontier pilots felt it unrealistic to hold the line for 3 pilots on a two pilot aircraft when DAL was going to fly the certified 3 pilot S80 with two. The FAL MEC was placed in trusteeship as a resut of this.
That's all ancient history, really. But, NO ONE can deny we'd be better off with three pilot flightdecks! It has proved to be of incredible safety importance. Some things we should not change, age 60 retirement might be one as well.
Age 60
It isn't a perfect rule. Propose something better. ICAO proposal is worse. If age wasn't an issue, the ICAO proposal wouldn't include the if over 60 then under 60 requirement. Age is an issue.
All the Age 60 rule opponents, or most of them bellyache about "age discrimination"
ICAO proposal is age discrimination.
Propose something better or live with what we have.
Cyclone, they'll be bellyaching in 5 years about how 65 is not good enough anymore either, how it is discriminatory and stuff. Don't worry!
It's all about them anyway.
ICAO found;
"In the JAA countries, the upper age limit of 60 has been maintained for pilots in single-crew operations, but since 1 July 1999, the JAA regulations have allowed airline pilots to continue flying until age 65 with limitation to multi-crew operations and with the proviso that no other member of the flight crew is older than 59. However, the Secretariat is aware that this proviso was not based on medical grounds but rather the result of a compromise between the different parties. Although recommended by IATA, the Secretariat does not consider this proviso safety relevant"
So Fox, what you're saying is that ICAO rule is discriminatory too.
Man, we should just let you around til you drop dead - whether it's on short final or your own bed... max pay to the last day, right?
Compromise
Just to be clear about this, I am in favor of no change to the current rule. However, I proposed the following compromise on the UAL board:
>Implementation of this change as currently written is a no-go. It does not have the necessary support within ALPA, the FAA, or Capital Hill.
In order to garner additional support, the pro-change crowd needs to amend the language of such a change to something more palatable. I'd propose the following:
1) All over 60 pilots retain their seniority within the company.
2) All over 60 pilots are restricted from acting as PIC.
3) The FAA medical standards need to be increased for all, not just those over 60.
4) Allow the initial change to go from 60 to 62, the minimum retirement age. After that, have the age increase in 6 month increments every calendar year. This would eliminate most of the lawsuits by those who would be excluded from the change.
5) The maximum age would rise to full retirement age - let's not kid ourselves; the pro-change crowd has no intention of stopping at 65. For those wondering what the full retirement age is, here's a link: http://www.socialsecurity.gov/retirechartred.htm For most of us, this would mean 67.
6) Restrict all over 60 pilots from flying more than 75 hours/mo.
I can sympathize with those that find themselves in a poor financial position when they reach age 60, but I expect them to come to the table with reasonable proposals rather than a grab for everything. It reminds me of the tension during the aborted UAL-USAir merge attempt where USAir pilots were screaming for DOH.<
I also wrote the following:
>Changing age 60 is a negative sum game for pilots. It is not a zero sum game because the change will open the door for airline management to lower wages. One of the reasons why pilots' compensation packages are as high as they are is due to the fact that we are out of a job at age 60. And you can bet that management will be all over our wages if this passes.
You refuse to acknowledge that this change, as proposed, would be a windfall for those pilots in the 55-59 age group. At the same time, most pilots will end up stagnating for several years in their current seat. For furloughees, it just adds additional time on the street or returning to be a junior reserve pilot. At a lower wage scale for the rest of their careers.
While I would personally suffer under my proposal from the last page (since all over 60 pilots would be senior to me in the right seat), I considered it to be an extremely generous offer. But it appears that your ego is so large that you cannot fathom moving back to the right seat.
I expected as much from someone who boldly offered everyone to celebrate his 60th birthday in Honolulu and then fly back to ORD as the PIC. You wrote this when there were more than 500 pilots on furlough at United who had yet to be offered a recall class.<
Safety issues aside, changing the rule will have a negative impact on all but the oldest pilots' careers. If anyone here thinks that our wages have bottomed out, just get this change passed and watch what happens to pilot wages.
There really should be no age limit but age 65 is a start.
Check this out: http://dmses.dot.gov/docimages/pdf99/424637_web.pdf
LAST PARAGRAPH - "IN CONCLUSION, THE CIVIL AVIATION MEDICAL ASSOCIATION SUPPORTS THE ICAO POSITION AND RECOMMENDS THAT THE FAA ABANDON THE AGE 60 RULE."
Why do you say that? It's what you're pushing for. You don't want to admit it, but you are against "age discrimination" against airline pilots. In other words, you don't admit that aging is a safety factor. Forget ICAO studies, talk to your FO's.
Sadly, it's very much like senior drivers... you could never convince one that it might be time to hang it up for their own good as well as for those around them. It's very much like your crowd opposing the age 60 rule.
Many FAR's were written in blood. Does this one need to be too?
I believe you'll be very surprised in just a few weeks. In fact, there will be many surprises.
Have you forgotten that the FAA Administrator and the Sec. of Transportation are Republicans who were appointed by a Republican? No matter what the results of the next election, that won't chanage. And you saw the age 60/65 letter to the Administrator signed by 12 of the most powerful Republican Senators, right? And have you read the ARC comments? Do you think that any of this is a factor in the outcome, no matter HR.65/S.65? And besides, do you really think any Democratic Senator wants to oppose this change so as to hear all this again at 10 times the level next year? I don't really think so.
Andy: With all due respect, change is in the air. You're still invited to my 60th.
The FAA could have changed this rule anytime they wanted to. If they were going to change it, it would already be in writing.
I assume that you've seen the clip that Klako's plastered everywhere of Blakey commenting at Sun 'n Fun. This issue isn't even on her radar screen. And not all 12 of those 'powerful' Republican Senators will be reelected.
Have you noticed that United will be recalling two classes of 20 starting in January? They'll be recalling 40/mo until they shut down TK for the summer. With United's forecast YOY growth of 1% (requiring ~70 additional pilots), they would be awful fat on pilots next summer if they are planning on minimal losses for retirement. The forecast for 2007 recalls is more than 300.
As for your invite - I find it rather tacky when there are almost 300 United pilots who have not yet been offered recall. Did anyone mention to you that they also lost their pensions? Oh, but they have more years to recover - they can adjust to a lower standard of living. I guess that after 9/11, it was too late for you to adjust to a lower standard of living; you only had 5+ years. And a bunch of stock and bond money.
Wasn't it the DC-9 not the MD-80 at DAL. I agree with everything else.
As for your invite - I find it rather tacky.
Funny you should ask about the Sun'n Fun video. Who do you think the questioner was? Do you think it might have been UndauntedFlyer? And that video was just the start of the FAA getting into high gear to do what is the right thing. And right now they are full speed ahead to end the age discrimination and the discrimination against Americans. This change will be the best thing to happen to the pilot group in years.
In just a few years, we will look back and see ending the age 60 rule the same as ending discrimination by race and gender. All of these were ended because it is wrong and it is only the right thing to end it, or so everybody really knows.
Regarding UAL, the fact that they are in a rush to recall lots of pilots is a sure sign to me that they think the age 60 rule will change.
Regarding the party, do I take your answer then to be a no you won't be there? I really do hope you change your mind. You'll be my special guest of honor if you can make it. Bring your friends too.
This change will benefit the profession in the long run.
Andy and other FI members: What did you think of the CAMI letter to the FAA? (post 1180)
Would you care to elaborate on this reasoning?
Good qustion Flopbut: I was hoping someone would answer it. Of course UAL doesn't have a crystal ball any more than anyone else, even including me, you or Andy.
But just based on my experience, big companies are usually about 180 degrees out of phase with the world because they are about 6 months behind on changes. Example: They hire 500 only to furlough from that group before the last pilot completes training.
Of course the announcement of recalls could also mean a big expansion so that every pilot, furloughees and over age 60 pilots will be needed. I think we all like the second thought better.
I reckon what Andy was saying about your coy invitation to your sexagenarian gala is, "stick it up your arse". Just a guess though. Have fun and don't forget to take your motorized chair from the Scooter Store. When Wilford Brimley gets there tell him that changing the age 60 rule is the "right thing to do". He'll agree with you and might even get you a good deal on a Liberty Mutual testing kit.
Undaunted,
Nobody wants to hang out with you in HNL. I have been at the Seaside most of the month....and I have asked around....NOBODY wants to party with you.
RETIRE! Stop making such a FOOL of yourself and once again can you PLEASE answer the guys on the UAL-MEC ALPA Board, EXACTLY who said you speak for the UAL pilot group...CAUSE YOU DON'T!
I think that qualifies as a smackdown.
Undaunted,
What is important to me is to work and support my family, not having a party. If the law changes and I can continue working that's worth something to me and thousands of other pilots. I will be celebrating my 60th and I hope it's in HNL. I see nothing wrong with that. You're invited too, Sonny Crockett.
I do not speak for the UAL pilots, for any group or for anyone else. I only speak for UndauntedFlyer..
I do believe there is an expansion coming and that soon all the furloughed pilots will return. I do expect that this industry has room for lots of pilots, including the over age 60 group. There are more working airline pilots today than there have ever been in history and there will be more next year.
Undaunted,
Jeez, I'm not sure about talking for the UAL group but I've met a large number of UAL guys in DC singing the same tune.:beer:
The old guys aren't as stupid or ignorant as you make them out to be. I have "retired" a pilot as a result of poor performance. As an instructor/manager, the job fell on me. It was the hardest thing I ever had to do. No one was more aware of the time being right than he was. He remained professional, courteous and honorable to the final handshake, when he wished me well!!
For what it's worth, I've had the responsibility of showing the door to a few young guys, too. They didn't have the balls, or the brains to know that I was doing them a favor.
We can't judge pilots by their age group, any more than we can judge them by their equipment types. One of those old guys is just as likely to save your a$$, as you are to save his.
Sample size of one
I think that's what we should do...base this whole decision on 3Bcat's experience with one person. Come on. That is so statistically significant that you have finally persuaded me. Plus, I really loved the violins playing in the background.
"It is better to remain silent and be thought a fool than to open one's mouth and remove all doubt." Look in the mirror Mr. "I've shown the door to a few in my day." Talk about an arrogant putz...yikes.
Post a few more jewels like the last one. I can't wait.
Try using logic next time or maybe even think about the issue and try to come up with a better solution. So far none of you expert senior experienced all-knowing pundits have. Oh, except that Foxhunter needs the money....so we should change the rule.
I like the part in the new medical report where it says raising the age may actually increase safety by keeping the less experienced pilots out of the cockpit longer.
You would.
Guess what? They are talking about you too. Or were you born with 25k hours?
