Aeronautical Pet Peeves
Wang Chung said:
Yeah, what's up with that? Is there some reason or tradition behind that, cuz I hear plenty of Delta'S, United'S, Comair'S out there and I always found it a bit odd.
Not a pet peeve really, just curious.
I hear a lot of controllers using that terminology....
JimG said:
Radio hogs doing touch and goes at uncontrolled airports.
"ABC traffic, Cessna 1234X departing runway x.... ABC"
"ABC traffic, Cessna 1234X upwind runway x...ABC"
"ABC traffic, Cessna 1234X left crosswind runway x....ABC"
"ABC traffic, Cessna 1234X left downwind runway x... ABC"
"ABC traffic, Cessna 1234X left base runway x... ABC"
"ABC traffic, Cessna 1234X turning final runway x... ABC"
"ABC traffic, Cessna 1234X short final touch and go runway x... ABC"
When I was a Flight Instructor in EVB there was this dork who would always wear a safary hat and was working on his CFI.
Dork: "traffic, cessna 123 left downwind rwy 6.
Me: "traffic, cessna 456 taking rwy 6 for departure.
Dork: Ah you should be ok we are only midfield downwind right now and have you in sight, so go ahead and take off blah blah blah
I wanted to beat the crap out of that guy, the blah blah part was me stepping on his radio call, only did it a couple times though...
Multithousand hour pilots who NEVER advise ATC of having the atis on initial call ups and always have to respond to atc that they do indeed have the atis. And they keep doing it.
Blueliner said:
I hate that too, but I'm forced to do it in some aircraft that have strobes and beacon on one switch.
§ 91.209 Aircraft lights.
No person may:
(b) Operate an aircraft that is equipped with an anticollision light system, unless it has lighted anticollision lights. However, the anticollision lights need not be lighted when the pilot-in-command determines that, because of operating conditions, it would be in the interest of safety to turn the lights off.
I'd go by that, just leave your position lights on all the tiem you are taxiing. Sometimes the strobes may be just annoying on the ground, but other times it may compromise safety.
I've said it before and I'll say it again...
Pilots that don't know how to properly report turbulence. eg. Moderate to severe light chop. WTF????????????????:uzi:
Here let me help:
Light Turbulence that momentarily causes
slight, erratic changes in altitude and/or
attitude (pitch, roll, yaw). Report as
Light Turbulence
Turbulence that causes slight, rapid and
somewhat rhythmic bumpiness without
appreciable changes in altitude or
attitude. Report as Light Chop.
Turbulence but of greater intensity.
Changes in altitude and/or attitude occur
but the aircraft remains in positive
control at all times. It usually causes
variations in indicated airspeed. Report
as Moderate Turbulence;
Turbulence that is similar to Light Chop
but of greater intensity. It causes rapid
bumps or jolts without appreciable
changes in aircraft altitude or attitude.
Report as Moderate Chop.
Severe Turbulence that causes large, abrupt
changes in altitude and/or attitude. It
usually causes large variations in
indicated airspeed. Aircraft may be
momentarily out of control. Report as
Severe Turbulence.
Extreme Turbulence in which the aircraft is
violently tossed about and is practically
impossible to control. It may cause
structural damage. Report as Extreme
Turbulence.
"When I was a Flight Instructor in EVB there was this dork who would always wear a safary hat and was working on his CFI.
I wanted to beat the crap out of that guy, the blah blah part was me stepping on his radio call, only did it a couple times though..."
People who don't shut up at uncontrolled strips cause frustration, but it sounds like the guy was just trying to play nice with you. Cut the guy some slack.
I remember hearing a person call "Citation123AB is XX out for rwy X. Any traffic advise."
An aviation safety councilor would always correct the guy by saying "You're not supposed to say 'Any traffic advise'!". Meanwhile, you're waiting to call unicom for a fuel order.
Also, radio useage is non-regulated. If the frequency isn't congested, there's nothing wrong with ATC talking about sports scores or pilots saying "on the meter" or whatever. If the frequency is congested, don't gab.
sometimes---guilty as charged :)
Like around late Saturday afternoon/early evening (6pm'ish) I've found in western CO and throughout most of UT.
I used to regularly fly across the greater Phoenix area (airport hopping) in the middle of the night and have had numerous chats with ATC while doing it.
We were both keeping the other one from falling asleep.
No slack for this guy, he wouldn't stop, he was playing controller. I saw this guy a lot at the school and he was (Is) a real dork...
Oh yeah, if you are going to correct somebody on radio/flight procedures (and it is not an immediate safety issue) save it for on the ground.
I don't have so much a problem with small radio lapses (such as 'with you') because you can get busy up there sometimes and don't always have time to respond to the radio in the correct manner...and it is just not worth getting worked up over.
Its definitley the instructor's fault sometimes...but it is also the students responsibility to make sure to use the correct procedures (its in the FAR-AIM, is it not?)
If you have problems with radio procedures, get a tape recorder and a scanner and record your self and play it back, and listen to other pilots on the scanner to see what the do/do not do correctly. It may seem stupid, but it can really help improve your radio ettiquite.
Pilots who insisted on discussing their political, religious and moral beliefs in the cockpit. (I'll get more out of reading the instructions on the vomit bag)
Approach, Departure, and tower controllers in Phoenix, AZ
Anyone who is under the impression that they are so special they demand that all "all other traffic please advise"
Mental Giants who start their radio calls with "UUUUUHHHHHHHHHHHHH!" (think it through then press the button)
Guys at uncontrolled fields that listen to 3 or 4 airplanes make radio calls in the pattern such as "so and so, downwind for runway 9" wait for a gap on CTAF then use it to call unicom and ask "which runway is the active today"
The AMF pilot in the Lance at PHX that in the middle of rush hour ate up 7000 feet of runway getting his Lance down and stopped, forcing me to have to go around and spend another 30 minutes circling outside class B waiting to getting sequenced in again. (Thank you sir....you are an inspiration to us all)
Guys who after being handed off to another controller end their reply to the previous controller with "SSSSSEEEEEEEE YYYAAAAAAAA!!!!!!!. (Your are not a VJ for MTV just say thank you and carry on with your day)
The CAP pilot I saw taxiing out in an old Mooney with a current issue military flight helmet on and the damn visor down. (anyone who feels this is necessary equipment to fly a 40 year old Mooney needs to be locked in a portable toilet and set on fire!)
Or ABC traffic, Cessna 1234X turning left final runway x... ABC
The CAP pilot I saw taxiing out in an old Mooney with a current issue military flight helmet on and the dang visor down. (anyone who feels this is necessary equipment to fly a 40 year old Mooney needs to be locked in a portable toilet and set on fire!)
Who do you fly the Twin Beech for? I hope to get a chance to fly one some day.
It's not just pilots who do this.
I've heard controllers carry on with this crap and wondered WTH?
4fanman said:
Any traffic please advise...
I just heard this peeve yesterday, again. Some guy picking up his clearance with ground control...."Ground, Citation xxx clearance on request to KXXX.." That's a phrase that the controller uses when he/she doesn't have your clearance right away, not for the pilot requesting the clearance. I've noticed that this seems to be popular with ex-mil guys. Is that how they pick up the clearance in the military?
Yes, you are correct. Standard phraseology goes something like this...
"Clearance, Bulldog 44 IFR to BFE, clearance on request, ready to copy"
Some guys, such as myself, who are military but fly civilian airplanes to civilian fields don't neccessarily say that when they're asking for you IFR.
Not annoying, but funny
Tower: Flexjet XXX, hold for release, I'm waiting on your callback from Chicago, should be about 20 minutes, but I do have some good news...
FlexJ: What's that?
Tower: I just saved a bunch of money on my car insurance by switching to Geico.
Zing!
I think we should use some common sense when using the radio (and when evaluating others' use!).
If it's Sunday at 6am and no one is around I don't give a flip if atc and a pilot are discussing last night's game. Who cares? Chill. No biggie.
If it's busy and every second of airtime counts, 'Seeeyaa', "With You" any extra words at all may screw up the flow.
Heck I doubt 'Thanks for the help' is in the PCG but its not going to bring down a plane or aggravate me in the slightest.
This thread is mainly about how wired us pilots can get!
Perfection as a goal is admirable.... but let's not discard common sense entirely.
TIGV said:
Someone saying: " Checkin' in with ya at ... " when contacting centre
Freight Dogs asking for ride reports
Southwest getting priority even though we're all at 250 under 10 and I can do my 250 to 5nm out aaaaaaand I have enough money in the back of my bird to buy 2 or 3 737's
Centre panicking when I don't contact 'em right away
Centre panicking when my transponder doesn't work
Centre asking about my ride while I'm in a level 4
Freight Dogs forced to wear uniforms
Folks who read back their entire route clearance almost to show off that they remembered it all, while the rest of us wait and gnash our teeth.
The list is long and plentiful, please add..............
WTF??? What kind of limey douche flies through level 4 cells and doesn't have a working transponder, yet you can buy 2 or 3 737s?
My gripe: Idiots who can't spell CENTER.
UnAnswerd said:
Nothing wrong with "with you". Instructor says it all the time...
...except that A.) It's not in the pilot/controller glossary B.) You're not "with" him, you're miles away and thousands of feet up, how can you be "with" him? C.) It's unneccessary, redundant and just plain sounds retarded D.) Makes you the laughing stock of professional pilots everywhere.
OK, my gripes are small, because I say "with you" although, I am trying to get over it.. It has actually started annoying me, so I'm trying to quit. :)
And my gripes are..
Fair weather flyers who think they know everything..
Being cut off on downwind by a Gulfstream 2 who not only cuts me off but then says "we'll be stopping on the runway for a couple of minutes to remove some equipment...."
Guys who will sit and chatty chatty on the CTAF..
I will admit, I love saying "Don't seem em' yet, but I got'em on the fishfinder.." But I am from Alabama and love fishfinders. :)
Almerick07 said:
New one.....people who cant land on the effing centerline!!!
Yea! Like that stupid JetBlue pilot last month! Man! He was about a foot off from the center. He really did a bad job.
jk:rolleyes:
Pilots who lie to mechanics. "Hard landing? No, the landing seemed pretty normal to me."
Pilots who have never learned some of the most basic facts about their airplane's systems. Squawk: "Alternator 2 does not operate until 1700 RPM."
Me: "Good, that's how it's supposed to work."
Netjets crews who create imaginary intermittent squawks just so they can spend a weekend in Chicago, thus wasting my time and their employer's money. You know who you are.
Netjets crews who put the security sticker in a different spot every time. Why? Do you like making a mess all over the door? Why not put the new sticker in the same spot as the old one? That way, the mess will be confined to one small spot.
Netjets crews who apparently have their young children write their squawks for them, judging by the handwriting and grammar.
