billystack
New member
- Mar 20, 2008
Ehe ERJ has a hydraulic pump that makes a god awful noise when only one engine is running. What I don't get is didn't the pilots in the back on that ferry flight tell the guys that engine was not started as they were about to take the runway? They were probably already asleep due to 15 hour day.
If you can't remember to start your engines and can't figure it out prior to taking the runway then maybe you are in the wrong line of work.
At least in the CRJ2, with one engine still shut, you should have 3 msgs. 1 master warning for OIL PRESS, and 2 cautions for fuel pump and fuel low press. And you shouldn't have a "TO CONFIG OK" advisory message. If all that STILL doesn't catch your attention, then there is something seriously wrong with you. Fatigue, incompetence, complacent, etc.
Having a procedure to remind you to start the engines is like having a procedure to remind you which way to move the yoke to flare.
I bet that suckedI was once engaged to a jet engine.
I am flying with more and more FO's that seem to have the attitude that checklists are for wimps. I can see that if I didn't call for them they would not do them or question me.
For instance "trim and takeoff speeds checked" without even looking at them! I have to constantly tell them to ACTUALLY check, not just verbalize from memory.
Most of these guys have a "I am superpilot" mentality.
But as soon as red lights start to flash, they look like deer in the headlights.
Thank God for super captains like yourself
I was following an NWA DC-9 into Fargo a few months ago and witnessed the following:
Fargo Approach: "Northwest XXX, say speed."
NWA: "310 knots."
Fargo Approach: "You need to be at 250 knots or less below 10,000 sir."
NWA: "Ah... Roger..."
The good thing about this is we didn't have to slow down or take vectors for spacing :laugh:
Quote:
I bet that sucked
A good trick is to never set the flaps for takeoff until both engines are running. Not only is this a good way to remind yourself the engine isn't running, but also you'll get the "Takeoff... Flaps" warning and will remind you that you didn't set them for a reason.
