puddlejumper
Unemployed /Contract User
- Nov 26, 2001
I agree with onthebeach in that you do not need the high altitude endorsement to log PIC, only to ACT as PIC. I disagree, however, on his/her comment about needing to be instrument rated to log PIC in IMC. This is a condition of flight, like night/day. If you are the sole manipulator, you can log the time in an aircraft in which you are rated. Regardless of required endorsements, currencies or flight conditions. Category/class pertains to being rated in an aircraft. Instrument rated applies to an operational rating on one's certificate. (that isn't coming through very clearly, maybe someone can explain it better)airspeedsalive said:Huh. That's interesting. I recently just started doing a part-time seat warmer deal in King Air. I assumed that on the dead legs I could log PIC time, but I'd need to wait until I had a high altitude endorement.
I'll check into that when I get home. Does everyone else agree with onthebeach?
Here's an example: You're out of BFR. You go and fly with a CFI. You are the sole manipulator for the flight review. You log it all as PIC, even though you can not act as PIC until you've completed the review. Let's say the CFI gets a local IFR clearance and you go fly around in the clouds. Log it is as PIC, actual instrument. You're rated in the airplane, just not the type of operation you are conducting. Just because you are current at night, and fly at night with a CFI, or a safety pilot, one still should log it as PIC, as long as the CFI/safety pilot is current and rated for the type of operation and agrees to ACT as the PIC.
Edit(added) If you are a non-instrument rated ASEL Pvt pilot training for the instrument rating, you log the training as PIC, even if you're on an IFR flight plan. In IMC, you would continue logging PIC and actual instrument. Say you're an ASEL Pvt getting a AMEL rating. The time receiving instruction is not PIC, since you're not rated in the aircraft yet. If your MEI signs you off to solo it and you go fly around as the "sole occupant" I believe you would log that as PIC time. Although, the regs may say that only a student pilot may log sole occupant time as PIC, I'll have to check.(end)
Clear as mud huh?
