The REAL NJ TA Story
Is one awarded aircraft type in newhire class based on the "seniority" within that class as to what's available? Or is it just assigned?
For a newhire, it's pretty much luck of the draw, based on things like sim availability, hiring needs, and so forth. Sometimes you'll get a choice, sometimes not.
When I was hired, for example, I was offered my choice of the Citation Encore, the Hawker 400XP (BeechJet), or the Citation Excel. Though the class date in the Excel was a couple weeks later, I took it because I wanted an aircraft with an APU. After 7+ years of flying a non-APU turboprop, I wanted some heat and AC on the ground!
What aircraft are the "junior" aircraft and therefore what you'll most likely get?
As a newhire, you'd get anything except the Falcon 2000EX or the Boeing Business Jet. All the others pay the same, and are assigned as the company's needs dictate. Aircraft bids go out to current pilots first (once their equipment locks are up), then the slots that aren't taken go to newhires. Since switching airplanes incurs an additional 39-month seat lock, few FOs will do it except to the 2000EX or BBJ (which pay more).
As far as likelihood of a particular aircraft? Well, current FAA records show we have 80 Ultras/Encores, 102 Excels, 70 Citation Xs, 29 Sovereigns, 32 Falcon 2000s, 5 Falcon 2000EXs, 31 Gulfstream 200s, 44 400XPs, and two 900XPs. Pure odds say the Excel would be the most likely, but again, it just depends where the openings are when they call you.
Is reserve similiar to that of an airline? When on reserve does one sit at the FBO awaiting an assignment?
Not at all. The "Reserve Schedule" will be gone as of 2/1, replaced with a fixed 18-day schedule. Since the new rules will all be in place by 2/1, that's what I'll use as a frame of reference.
In any case, the only difference between the schedules is which days you work. Once you're at work, the rules are the same, whether you're on the 18-day fixed schedule, the 15-day flexible schedule, or the normal 7/7 schedule.
You can be on duty at the airport awaiting an assignment, on duty at the hotel, or on duty at your residence in some cases. (In the latter two, you have to be ready to leave the hotel in 30 minutes.) The company can send a complete crew to the airport to man an airworthy aircraft for all or part of a (14-hour maximum) duty period to await an assignment.
That hasn't yet happened to me for more than a few hours, but they'll normally strategically place crews and available aircraft in various regions in case a plane breaks. Being able to recover quickly from a problem (mechanical, weather, or whatever) is something we do very well, but it depends on crews being out there and ready to go.
If you're at the airport without a full crew or airworthy airplane (maybe the plane broke, or a crewmember got sick, or somebody took your plane and you're waiting for another), the clock is ticking. If after 3 hours the company doesn't have a full crew or plane, you'll start earning hourly overtime until they fix the situation or send you to a hotel. (After 7 hours, double overtime starts.)
This is to prevent you from rotting at the airport for no reason. If you have a full crew and a good airplane, that's not eligible for this OT provision -- it's only if there's no good reason for you to be there. And as I said, airport duty can occur on any of the schedules; it's just the nature of our operation.
And about how long would one have to sit reserve before holding a more fixed schedule?
You can be on the 18-day schedule as long or short as you want, if your seniority will hold it. The 7/7 schedule is our normal schedule, and up to 90 pilots will be on it. Per the contract, you'll be able to go to a 7/7 schedule if you like when you're finished with IOE, or 120 days after you start IOE, whichever comes first.
10% of our pilots (either by bid from the top, or junior-assigned from the bottom if necessary, but not likely) will be on our 15-day Flex schedule. Roughly the same number of workdays, but it's a fluid schedule. If you're on it, you find out by 6pm each day whether you'll be working the next day. If they say no, then it's a day off -- you're not on call. If they say it is a workday, you'll get a start time to report to the airport, and that's the time when your rest period ends. When you report, then it's just a normal tour, just like any of the schedules would have. The only difference is that the 15-day schedule has max tour length of 5 days.
Are both pilots typed in the aircraft that you get? Also, about how long has the switch from right seat to left seat been running?
Yes, both pilots get full PIC types in the aircraft. The latest upgrades have been here about 2.5 years, but for someone hired now, I would realistically expect a 4- to 5-year upgrade.
I've seen it mentioned that the retirement is possibly a bit subpar, from what I've seen the only retirement is the 401k is that correct?
Yes, that's correct. I don't really consider is sub-par, since most of the A-fund pensions have been little more than empty promises these days. :0 The 401K match is very generous: the company matches 50% of your contribution, up to 15% of your salary and up to the IRS limit (currently $15,500 annually). The 401K is administered by Fidelity.
Hope the info helps!
By work rules, I am referring to company operations policies that are not covered by the CBA. For one rather interesting example, there is nothing in the CBA that says what the Captain-First Officer ratio must be. Therefore, before the seniority integration occurs, NJI management could elect to make the ratio 90-10 if they wanted thereby granting every NJI F/O currently on the property PIC status and the salary that goes with it. Interesting prospect, yes?
Not really all that interesting of a prospect! In order to accomplish this NJI would be required to post captain vacancies if they were to create the aforementioned ratio. If you remember correctly, 1/3 of all captain vacancies must be filled by individuals from the NJA seniority list. NJI is full within their rights to do something like this, but they will have to award quite a few captain slots in order to advance 90% of their pilots into the left seat. Personally I believe this is a game they do not want to play!
Thousands of dollars? I think not.
It's not the H/AMEX points, it's the airline associated VISA/MC cards that we lose out on. YTD I have earned 94,000 points on my airline card and I earned slightly more HHonors points in the same period. I quit using the AMEX long ago.
You'll still be earning points with the company CC, with no point limit per year. I like using my airline card as well but the company CC looks like it will be more flexible in terms of how we can use our points.
When does your duty clock start on first days? For example your base is FLL and the company sends you on a trip out of MIA. Does your duty clock start any earlier than usual to give you time to drive to MIA or do you drive on your own time?
If your base is FLL, then your duty clock starts when you show up at FLL. They won't make you drive to MIA.
the company will provide ground transportation via taxi or sedan, or they may have you rent a car and make the drive. All of this on duty time.
Wow! You hear that Flexjet! At Flex we currently travel throughout our gateways on first days catching airlines or company aircraft on our own time and dime. I would like to see us fix our current gateway rules before we think about opening new ones. Yet another wonderful reason to send in your card.
gutshotdraw - not to fog up your rose colored glasses, but many things that never came to pass or changed were promised to EJA/NJA pilots thru the years. I sincerely hope you have better luck with your "promises" by that source than we did - hard nosed negotiating and contracts worked better for us.
I hope you had the sense to take the BeechJet. I had the X, XL, 560, 680, 800 or BeechJet. One look at that bagbay, the small fuel tanks and low stock room, it was the BeechJet for me!
Nah, as I said, I took the Excel; I really wanted something with an APU.
I'm sure I'll get my shot at the 400 lifestyle whenever upgrade comes along. :D
nevermind fll tpa same thing
Never said I had a source that promised me anything, just a "what if." The point is, there are work rules that are a little different at NJI and it remains to be seen how a single seniority list would affect those rules. I'm just talking QOL issues, scheduling, training, dispatch, etc. that have made this a good job for many of us.
biggest complaint is the term. It is a 5 year contract, but can be extended if the company meets certain goals.
Five years?????
"extended if the company meets certain goals???"
I assume all the NJA pilots are not inclined to refuse any flights then for any reason? That would be the only way the company would "meet certain goals" related to the pilots.
Interesting.
So it all starts over again at the end of 5 short years.
How excessively long will the fight last THIS time?
Five years?????
Huh? I've refused flights for various reasons, from fatigue (several times in my first year here) to weather to mechanical. What would change?
Interesting.
The "certain goals" are spelled out in a six-page section of the contract, and they're not insignificant.
Maybe no time at all, just as there was no fight this time. The IBB system worked this time, and it's very likely we'll try another session a few years down the road.
Exactly my point... (looking at it from the company's perspective).
It would like be impossible to meet these "certain goals" from their view
"another session?"
"no time at all?"
"no fight?"
What company do you work for, or did you just hire on there?
You obviously don't know anything about the IBB that just passed...
My POINT is that there was an excessively long fight to get where they are from starting off as the lowest paid fractional, that will likely start all over again in less than 5 years when it is determined they don't "meet certain goals" the company deems worthy of extending. Enjoy it the short time it lasts.
