TapitLight
Active member
- Jan 10, 2006
Your logic is illogical. What you are saying is that if the FAA surveyed an airport and found, I don't know, a big obstacle right off the end of the runway that you could only see right at one mile visibility, it would be impossible for them to limit the allowable takeoff visibility to exactly standard, and no less? It appears to me that that is the purpose of having individually surveyed runway T/O mins published, in addition to your company's ops spec allowable mins.I have to say I'm a little bit dumbfounded that some of
you folks think jepps are controlling. The only time they will be is if the takeoff mins are greater than standard, in that case I don't belive you can use reduced mins. I strongly encourage those of you who think jepps control at all times to clarify your understanding with your d.o. or a check airman.
Dointime,
You're stuck on this chart thing. If as the original post stated, the TOWER gave an RVR report, THEN IT IS AVAILABLE, and you have to abide by it. It doesn't have anything to do with who publishes your charts.
Ok LIDO has a tower vis requirement,
there was never any "tower visiblity" reported that morning only an ATIS reported 1/8 sm vis and an RVR reported at 1000'.
The vis was never up to 1/4 sm for the Pinnacle departures....
Is it possible that they were just wrong?
