AA717driver
A simpler time...
- Mar 27, 2003
gkrangers said:The ILS 31C requires 4000 feet vis.
Pretty sure you are right, but aren't you guys also required to only use available runway distance, and not gas stations, intersections, etc..canyonblue737 said:SWA with HUD can do it at 3000 RVR.
Yeah, now you're just being a dick.RP 04 said:Pretty sure you are right, but aren't you guys also required to only use available runway distance, and not gas stations, intersections, etc..
tlax25 said:First of all glad to hear all from the plane are out safely and most on the ground are ok.
When an incident like this, at a smaller airport like MDW occurs, what happens to all the planes in the stack? Are they sent into a holding pattern by ATC, diverted to other aiports, etc? I assume MDW is closed for the time being. Would ORD and Milwaukee and Detroit be likely diversion airports?
Thanks. I know it is minor question, just curious.
atafan said:I swore off CNN years ago.
