BoilerUP
Citation style...
- Nov 11, 2003
Dude, I'm a desk jockey...no offense taken (especially considering the fact that my flying skills are non-existent).Walter.. the windshear training there sucks.. I wasn't in any way calling out your flying skills when I said the V1 cut was easy..
cale
Sounds like those SKW pilots have more "experience" than mainline pilots flying between LAX and JFK..........
Bye Bye---General Lee
'Extraction Procedure'
skywest proud? dork!
TAKEOFF WEIGHTS FOR RWY 33DP REQUIRE *
* USE OF MODIFIED PUBLISHED -LINDZ- AND *
* -SARDD- DEPARTURE PROCEDURES. *
* MAKE AN IMMEDIATE 15 DEGREE BANKED CLIMBING *
* -RIGHT- TURN TO A HEADING OF 340 DEGREES. *
* AT 10.3 DME SOUTH OF DBL VOR (DBL R-165/D10.3) *
* TURN -LEFT- TO A HEADING OF 270 DEGREES. *
* INTERCEPT THE IPKN LDA NORTHWEST COURSE *
* (OUTBOUND ON BACKCOURSE - IPKN 300/D15.0) *
* DIRECT LINDZ INTXN (DBL VOR 244/13.0). *
* CLIMB IN HOLDING PATTERN AT LINDZ INTXN. *
* (WEST, LEFT TURNS, 064 INBOUND).*
You must think about the radius of a turn. The faster the speed, in this case V2, the larger the radius...the larger the radius the greater the chance of hitting the rocks. That's part of the reason the Dash8's and Avro's were better aircraft in there. Low v2 speeds small radius. CR7's E-jets...lots of swept back wing need lot's of V2 speed.
Only airplane ever built with 5 APUs... :laugh:
ONCE AGIAN!! The problem.
