Some generally good points, but I don't agree with the last supposition. I can't see SKW going the LCC route. SKW's senior management has openly scoffed in the past at ACA's attempt to go that route and has repeatedly said that you can't operate the CL65 on an 'at risk' basis.lowecur said:The DL situation will dictate what Skywest will do, but a bankruptcy or cutback of Skywest routes will more than likely trigger a return to DL of the CL65's and an LCC startup.
I believe there was a thread a month or so ago where the CEO was in the Denver pilot's lounge discussing the purchase of Embraer 190's for a possible LCC startup. If this rumor is fact, then they certainly are thinking about it.Harlequin said:Some generally good points, but I don't agree with the last supposition. I can't see SKW going the LCC route. SKW's senior management has openly scoffed in the past at ACA's attempt to go that route and has repeatedly said that you can't operate the CL65 on an 'at risk' basis.
The SKW RJ pilots wanted more money to fly the CRJ700...they'll demand it (and rightly so) for anything in the 100-120 seater class. Add in the fact the need to add a third Flight Attendant once you add the 101st seat, plus demands for more money from the Mechanics and you can quickly see the overheads going through the roof.
I suspect that SKW is hoping that it's presence in IAH will provide it with a foot in the door to make a bid for Expressjet when the opportunity arises.
This is, above all, a contract flying company and suggestions of it becoming a LCC are, I believe, without foundation.
And exactly how is it that any group at skywest is going to DEMAND things?The SKW RJ pilots wanted more money to fly the CRJ700...they'll demand it (and rightly so) for anything in the 100-120 seater class. Add in the fact the need to add a third Flight Attendant once you add the 101st seat, plus demands for more money from the Mechanics and you can quickly see the overheads going through the roof.
