EagleRJ said:.
Useless trivia:
Does anyone know the only airplane that can back up on the ground, even though it is not equipped with thrust reversers or reversing propellers?
The mighty B-17
JAFI
EagleRJ said:.
Useless trivia:
EagleRJ said:Completely under its own power, and yes- it's an airplane.
Hint: it doesn't move backward in a straight line....
JAFI's got it.
Crews in the Fortress could bring the #1 or #4 engine up to full power while locking that side's wheel brake, and the plane would yaw, causing the other wheel to roll back a few feet. By alternating that procedure, you could slowly back the plane up into a parking spot. Crews did that to cope with tight parking situations at the airfields in England.
typhoonpilot said:It's not the only plane that has done it though. My dad did it in a B-24 in early 1945 on his way to England. He tells the story a lot better than me ( obviously, he was there ). Essentially they had to back out of a tight spot in Canada with no other method available to them.
TP
GravityHater said:Do you have the opspecs on board (I'm doubtful), or do you have to call dispatch to read/interpret it, for something that is rarely used and maybe forgotten?
User997 said:We've used it before (Citation II) to back into a parking space after arriving at our destination after the FBO closed and no one to push us back.
