CrewResearch
Active member
- Sep 28, 2004
Thrust Reversers
Thank you for your replies to my questions. I appreciate it.
Weasil -- thank you as well for correcting my use of the term reverse thrusters -- I was going by the original title of the thread. Can I correctly say that Thrust Reversers (the system) create reverse thrust (the effect)??
I can imagine that routinely powering back would indeed unnecessarily burn a lot of fuel, and, as you point out, end up costing the carrier a lot of money over time.
bafanguy -- When you say:
"However, policy did allow use of idle reverse to assist the tug during pushback on a clippery ramp after coordination with the ground personnel." [my emphasis]
do you mean warning the ramp folks, for safety reasons? or getting clearance for that from dispatch? or both?
User997 gave the example with the Citation. In general, would this kind of practice be more common with corporate/GA aircraft than with commercial a/c?
