Reporting Leaving an altitude
During upgrade at airline number one, I was told by a Denver Center controller that reporting out of an altitude when given a crossing restriction is not required as the airspace is already blocked off, therefore I don't do it. But to each his own...
when you begin a descent after having accepted a clearance that included discretion, you aren't leaving a previously assigned altitude for a newly assigned altitude. you are descending within your assigned altitude.
no report to atc required.
that's why they respond with roger
that's why there has never been a violation for same
Paragraph 5-3-3
a. The following reports should be made to ATC or FSS facilities without a specific ATC request:
1. At all times.
(a) When vacating any previously assigned altitude or flight level for a newly assigned altitude or flight level.
From the AIM Flight Information Publication Policy:
"...This publication, while not regulatory, provides information which reflects examples of operating techniques and procedures which may be requirements in other federal publications or regulations..."
Anyone know if Paragraph 5-3-3 (or anything similar) appears anywhere in USC or FAR? Just curious, but it sounds like more typical check airman drivel then actual fact. Must be a qualification for the job.
Now if it's in the respective FOM I guess the company can compel you to state it, even if it isn't required by the regulatory agency, but it's still pretty stupid.
Threads about radio calls are almost as entertaining as threads about pilot costumes or ALPO. :rolleyes:
BTW I agree with cheater1239, I've read back the clearance so I'm done. After all, I have Sudoku to do.
Correct radio call:
"And Center, Flight xxx out of two phife oh for one tree thousand. Good evening."
To achieve proper form, you must begin the above referenced call with the ever-important: "Ahhhhhh..." (approximately 3 seconds in length, made with that 3 pack-a-day gravel voice, befitting of those with single digit seniority).
Drives women wild.
If flying in radar coverage in the Northeast Corridor on a Friday afternoon with weather everywhere, maybe not.
If flying into Africa in non radar talking to the "controller" with a barely understandable west African accent being filtered through a 60's vintage HF radio, sun at the 12 o'clock high position rendering HF communications dicey at best, absolutely without fail.
Just curious if the average airline guy makes a report to Center when leaving one altitude for another after he's given a PD or crossing restriction.
i.e.:
Center: Flight xxx cross GEELA at 11/250
Flight XXX: Cross Geela at 11/250
....when leaving altitude:
Flight XXX: Center, Flight XXX leaving FL230....
The check airman at WN point to an AIM sentence that says it's a required call. I've never done it before and quite frankly never heard anyone else do it until I started here at WN, so who's right?
Why are you even asking this question...yes it is required.
c'mon- you've never had a controller forget whether they gave you an altitude or not? OR keep you up high on an arrival b/c of traffic?
The AIM may not be regulatory- but from the FAA- careless and reckless is what they violate you w/ when you violate the AIM. If the pilot can be blamed- they will be. So why make it an issue.
I've never heard of a violation for it- and don't make it a big deal- but if the FAA didn't want that radio call- it's a real easy fix for them- take it out of the book. In the meantime, it's an easy call.
Point to the line about not taxiing faster than a brisk walk and ask them about that.
That recommendation only applies to airplanes without brakes.
break
As somebody already wrote, reporting vacating an altitude is a holdover from older days. If the freq is busy do us all a favor and don't do it.
Another one: when reporting entering a hold don't bother saying the time. I'm willing to bet every ATC'er has a watch by now.
We all need to work together to do what's safe instead of getting bogged down in archaic and irrelevent regulatory minutiae.
Oh I probably use to make that call 10% of the time knowing all what everyone has said on this thread previously.....until one night.
We were given a crossing restriction and about 5 minutes later when we started the desent I made that 10% of the time call and then it started. The controller made about five calls to give heading changes, altitude changes, maintain altitude and such. We thought we totally screwed up. There was much confusion on everyones part and when we asked if we did anything wrong (ASAP) the controller owned the mistake and appologized to all involved.
I make that call 100% of the time. Everyone is human.
there you go. well said.
I guess there are two kinds of pilots out there:
1. The dude who thinks the FAA is watching him at all times, that his F/O will NARC on him, and that the F/A, the pax, and the rampers all are out to get him. This guy will do everything by the book, and judges anyone that doesn't as an inferior pilot. He judges one's flying skills by knowing procedures verbatim and never veering off. This dude is usually called the "anal guy who no one wants to fly with".
2. The dude who is not afraid of his shadow and understands the regs and follows them because he wants to be safe, not because they are simply written in a manual. He understands that veering off regs is ok sometimes, as using his judgement is what he's paid for. This individual is considered the "laid back" guy who many of us strive to be - of course, not all ;)
Beytzim wins the prize. 30W as well.
In Africa or SA, it's defnitely a good idea. In a radar environment, it's just a waste of frequency.
Let's be real, only about 10% of us waste the energy.
I guess the rest of us are asking for a letter from the FAA -- for violating the (advisory only) AIM.
That sums it up quite well.
If its not going to get you hurt or violated, who the hell cares?
Couldn't agree more. Usually the anal one is the captain so you can't totally ignore him but you have to not let him distract you to the dangerous point with his BS. Usually the FO will listen if you explain to him what is important now. ID the next vor after you get that radio call you just missed again.
And it's this first type of pilot that will always include the phrase "I'm pretty laid back" in his briefing to you. If you ever hear this phrase, watch out because you are about to fly with the most anal S.O.B on the planet. If you really are "laid back", you won't have to tell anyone.
Oh for cryin' out loud.
If you can't say "Center, ABC XXX two-seven zero descending wun wun thousand" in less than 3 seconds to New York, Cleveland or whoever, swallow the dry bagel in your mouth, take a swig of water then TRY.
All y'all Joe Cool types complaining about that which is required by AIM and which can be accomplished in less than 3 seconds are pathetic.
That goes for the time stamp in the hold, too, for chrissake. ::shaking head in disbelief::
I agree 100%
What's the proper phraseology for....
"Hey center, does anyone have the Steelers' score?"
i agree w/ this for the most part-- but it's too cool-cat: and usually these guys are the ones who didn't get laid enough in college and get most of their social identity from being cool in the flight deck.
There are two other types of pilots- those who've been the subject of an FAA witch-hunt (or been close to someone who has) and those who haven't. Doesn't mean your scared of your shadow- just means it's f-ing ridiculous to make this job harder than it is by being cool. It's in the AIM- say it. Don't make the job hard. Anything else and i'm curious what other anti-authority issues you got.
Well, I guess we know which group you represent.
Welcome aboard, you dust-farting dinosaur. :laugh:
Ty
Close but...
Correct radio call:
t...two phife ZERO...
my IOE capt was big on this, given the number of non-native english speakers on freq. Good practice too when yo start flying int'l.
Ty
Thanks, Ty.
::in my best grampa voice (the best I can do for a 40 year old)::
"In my day, our double-I's would hit us with a rolled up NOS lo-enroute when we forgot to report leaving an altitude. And those dag-gum ADF's...I'll give you a needle flip!"
Seriously, I never thought calling out of one altitude was something so uncool. What the hell are CFII's doing, then? Why don't they teach this? I sure as hell did for the 5 years I taught. Just plain sense. As Web Wilder would say, "Pick up on it."
SCR
It is not "required". It is "recommended" per the AIM.
2008 Aeronautical Information Manual (When did it change from Airman's Information Manual?)
Paragraph 5-3-3
1. At all times.
"Required" reports would be compulsory reporting points in a non-radar environment, unable to climb/descend at 500 fpm, etc....
