Regional Pilots Kill 228 People by Pulling up After Stall Warning
There's a big difference between 40 degrees AOA and 40 degrees nose up.
Yup. AOA was 40-ish with the pitch attitude around 15 all the way to the water
The airplane was close to the edge of its envelope when the event began. An airspeed indication discrepancy precipitated the event and the airspeed indicators are now indicating a ridiculously low value with no accompanying stall warning. TOGA thrust and 15deg pitch and the airplane is falling out of the sky in the middle of the night, over the middle of the ocean, in the middle of the weather.
That would have overwhelmed a lot of pilots.
Strange for a professional pilot to be staring at 40 degrees nose up and still pulling back on the stick
It's not the first time it's happened you know.......
Yep, the failures were pretty fast and furious;
02:10Z:
Autothrust off
Autopilot off
FBW alternate law
Rudder Travel Limiter Fault
TCAS fault
Flight Envelope Computation warning
02:11Z:
Failure of all three ADIRUs
Failure of gyros of ISIS (attitude information lost)
02:12Z:
ADIRUs Air Data disagree
02:13Z:
Flight Management, Guidance and Envelope Computer fault
PRIM 1 fault
SEC 1 fault
02:14Z:
Cabin Pressure Controller fault (cabin vertical speed)
Think about it!
It's not how much time he had at the time of the crash but how much he had when hired. If he was hired with only 250 hours TT, most of his time is in cruise, crossing the pond, on autopilot, eating French Toast, and French Fries. How long do you think it takes for a international pilot to accumulate 3250 hours? Four years maybe!?!?
IMHO he was more dangerous as time goes on than when he was first hired.
This is assuming he was hired with the absolute minimums.
Not really, AF is like any other legacy. He most likely started in the rt seat on a 320 or something like it on inter European routes with very short sectors
Actually, it should be more important to monitor the pilots from foreign countries that fly into the US. It is very common to have 250 hour FOs at carriers in India and Mexico. If we have to hire pilots with X number of hours, we should also have some system that monitor the quality of pilots and mx from foreign carriers that fly into here. We may be safer with better pilots, but without cabotage protections, we will be a a severe financial disadvantage to foreign carriers with code sharing or other rights to carry US passengers. I think it is important to have some better limits on 121 pilots, but we need to look at the overall picture of what could happen if we do not put other safeguards into effect.
Eric Pogo
Please...gimme a break. If you think XJT pilots are anything special, shall we go over old ASAP and FOQA data?
Baronman and Filejw:
My whole post was about 777forevers comment (most likely sarcastic) that all 121 FOs need 10000 hours. I guess I should have put that in quotes for you veterans here on FI.
When I first read the last sentence in the OP, I thought this thread was going a different direction.
In an Airbus, the thrust levers do not move. I could see how this could happen. About 2 years ago, a Northwest A330 had a similar problem. The thrust rolled back and the airspeed indications dropped to 0. The pilots recognized what was going on quickly, turned off the autothrottles, and set the thrust to pretty close to normal settings. A few minutes later, the airspeed indications came back and they were right on speed. The NWA crew was extremely confused as to what was going on, but they kept the aircraft under control. If the pitot tube was blocked, the airspeed indicator probably started acting like an altimeter (private pilot stuff). The guy starts pulling back, the airspeed goes up, he pulls back more, aircraft stalls. Bad piloting might have been part of the problem, but an unusual acting aircraft started the whole thing.
To the naive regional poster who started this post, karma's a bitch. I hope it never comes back to bite you. I truly mean that.
True stuff! If you had an Unreliable Airspeed condition, the aircraft doesn't know where it is or what it's doing. The pilot must recognize the problem first. If they don't know what's going on, they can't take the appropriate action. To compound things, the conditions they were in weren't helpful either. Before we throw them under the bus, we should wait to figure out all the details.
Briefing doesn't mean crap...I want to know how they ended up in this cell.
Use that experience of yours and think of the likely scenario's. I can think of a number of plausible ones.
We will never know exactly how they ended up in it.
Congress has to act on this now! 10,000 hrs to be a 121 FO. Anyone with less than 15,000 hrs is on the low time pilot observation program!
Hi, you're an idiot. First of all, Airbus has had this problem before, with the pitot tubes. A DL A330 had a failure flying from HKG to NRT, but it was day VFR and they landed safely, even though the indications were all screwed up. This Air France plane was flying at night, around thunderstorms in the ITCZ. If the pitot tubes had problems, and showed a high speed problem, then most pilots would decrease the thrust or pitch up, and unfortunately it did stall, even though they thought is might overspeed. You need to worry more about your own upgrade on the RJ and not about coming up with jokes that aren't funny.
Bye Bye---General Lee
Hi, you're an idiot. First of all, Airbus has had this problem before, with the pitot tubes. A DL A330 had a failure flying from HKG to NRT, but it was day VFR and they landed safely, even with the indications were all screwed up. This Air France plane was flying at night, around thunderstorms in the ITCZ. If the pitot tubes had problems, and showed almost a high speed problem, then most pilots would decrease the thrust or pitch up, and unfortunately it did stall, even though they thought is might overspeed. You're a genius, and probably never will reach a Major, let alone upgrade on your RJ.
General, switch your sarcasm filter back on. I am pretty sure he was joking.
He's trying to compare the problems between the Colgan crash and the Air France crash, and equate them. Our Regional airlines in the US do need better training oversight, and higher minimums to hire, rather than hiring 200 hour wonders from Riddle. The Air France crew probably didn't know what they were dealing with, and if the pitot tubes were the problem, it could have distracted them and maybe they did fly into bad weather. But, those crashes were caused by different problems, and should not be equated by this guy. And, I didn't really think it was that funny.
Sigh.........the old glass houses thing.
Anybody wanna bet how long it takes for the other username to chime in?
You're cool! The original poster has it all wrong, and needs to know it. Riddle guys right out of college don't need to be flying jets yet. You can't compare that to getting bad info from pitot tubes flying at night near thunderstorms. But you knew that! I think it's more likely you live in a glass apartment.
