HelloNewman
- May 7, 2004
Hate to burst your kool-aide bubble, but the forced pairings are a CN code for "coverage"...and there is nothing you can do about those when they are forced on your schedule! I've actually gone over my bids with several different PBS trainers and have gotten the same poor results. I've even talked to KH about trying to get better results, but the bottom line is if the pairings we get to choose from aren't any good, then the lines you achieve can't be much good either!
Do you think it's realistic to want to get more than a day or 2 off more than a new hire on reserve???
All I know from what was told to me is that CN is usually the result of a bid failure. The upcoming feasibility tour should help correct the plague of CNs.
I worked on making my bid feasible and only had one CN pairing this year which was a local because I Did not bid enough credit. Yes the pairings definately need work. The problem is if you have crappy pairings with hard lines you get even worse schedules and have no control over your own destiny. Yes you should be getting quite a few more days off than a new hire reserve.
