I agree with NJA Capt. ATC's goal should be efficiency and maximum traffic flow. I got eight low altitude 120 - 180 degree S-turns to keep me behind airliners coming out of New York last week! Once they cleared me to altitude my normal cruise speed caused me to pass them anyway.NJA Capt said:Hold, Why does the "turn the slow aircraft" rule only apply when the slow aircraft is non-airline?? When the overtaking aircraft is corporate, ATC turns or delays the corp aircraft instead if the "slow" airliner. Why the double standard?
GVFlyer said:I agree with NJA Capt. ATC's goal should be efficiency and maximum traffic flow. I got eight low altitude 120 - 180 degree S-turns to keep me behind airliners coming out of New York last week! Once they cleared me to altitude my normal cruise speed caused me to pass them anyway.
Let me climb and get out of your way. I never file for anything less than FL450 unless it's a very short flight.
And consider speeding me up rather than slowing me down to get the spacing you need for lower slower traffic. I don't mind being assigned, "Max forward speed, please."
GV
All because the controller turned you off the airway? How about, after he hears that he will be pissed off and violate some hard working pilot right behind you for not turning fast enough.81Horse said:Try, "May I have your operating initials, please?"
Stealthh21 said:All because the controller turned you off the airway? How about, after he hears that he will be pissed off and violate some hard working pilot right behind you for not turning fast enough.
Pick your battles.
81Horse said:Yes, pick your battles. I didn't ask the original question -- somebody else did. Guess I should have used the little winkythingI thought about using, but didn't.
Also, controllers don't "violate" pilots. At least not in the legal sense. <winkything again>
Safe, Orderly, and Expeditious.GVFlyer said:I agree with NJA Capt. ATC's goal should be efficiency and maximum traffic flow. I got eight low altitude 120 - 180 degree S-turns to keep me behind airliners coming out of New York last week! Once they cleared me to altitude my normal cruise speed caused me to pass them anyway.
GV
gkrangers said:Safe, Orderly, and Expeditious.
I never said they stuck to it, but thats the mantra.GEXDriver said:How does that apply here?
What's safe about keeping an airplane down in the high density airspace longer than necessary? What's expeditious about repeatedly heading an airplane North, then South, then North again 8 times when say, the pilot's trying to head West? And, I bet it doesn't look too orderly to the passengers in the back looking at the Airshow.
h25b said:I think you're seeing my point about the D-RVSM BS... Am I the only one that has witnessed zero benefit to RVSM.
jackotron said:From the pilot-controller glossary:
Have Numbers. Used by pilots to inform ATC that they have received runway, wind, and altimeter information only.
metrodriver said:from controllers: omitting the company part of the callsign.
