Overpowered aircraft
The old Convair 880's and 990's were rockets from what I've heard from old airline pilots. Handled like sports cars too
Hiya all,
Half full DC-9-10. It will max out the autopilot...
What a ride...no school like the old school...
Nu
All these stories of "overpowered aircraft" with fantastic climb rates with low takeoff weights is nice, but what I would like to know is which Commercial Airliner has the highest thrust to weight ratio at MGTOW (Structural).
On a side note, the 74 Classic (GE powered) when light is pretty impressive. When you consider how much of a useful load range you have you might get an understanding how much excess thrust that is at light weights. When light at a max pitch angle of 17.5 degrees it will accelerate straight through normal departure profiles. That's with max reduced thrust for takeoff; I could not even venture a guess of what it would be like at max rated thrust!
EagleRJ said:
CRJ-700. Repositioning flight with 6000 pounds fuel. On takeoff, accidently select APR thrust on both engines.
:eek: :eek: :eek: :eek: HOLD ON!!!
Accidently....Right.....:)
FRJ
12,100#T/ 34524#W (heavy a/c gross, if memory serves me)=.35 ratio
Not to shabby, but throw on a straight, high aspect ratio wing and hold on.
I once saw 780 feet to FL310 (ceiling) in 17 minutes in a nearly full airplane flying the standard profile. I miss that airplane.
Imho :-)
I prefer the Pratt & Whitneys Qs. . . specifically, the JT9D-7Q :) And the lighter, the better. Can you say "Git up n go!"
Once upon a time, I was in Lear 35 that did 300 feet to FL 410 in around 11 minutes . . . cannot remember our takeoff weight, but a hop and skip we were airborne.
'Props :D
What about those DC-8s with the big fans that UPS operates?
Anyone got the numbers on those?
I know it's not a commercial airliner but the GIISP with a max take off weight of 62,000#s and 22,800#s thrust. Not to mention it will blow out all the windows within about six blocks with those low bypass RR's.
The Lancair Propjet/Sentry will do 7,000 fpm "solo".
750 hp, 2200 lbs empty.
Not exactly in the airliner/corporate jet category, but it's still pretty sweet.
I dont remember who said concorde,( sure it goes fast and high) but it barely gets off the ground. I have seen it probably over a hundred times and thought for sure it was going to crash on several occasions, as it doesnt do very well when it is slow. I would be interested to know its thrust to weight ratio but am guessing it is not so impressive.
