I have two spare fuses once I learned of that as well and keep it in my spares kit.
Okay, I returned to the plane today for more ground run testing.
1) Pulling the emerg ignition breaker drops the voltage to 0 in the GDU
2) Pulling the inline fuse at the battery positive does nothing to the GDU
I need my clamp meter to measure amps for the charge, I looked at buying a mini meter with a display or a bluetooth option which would require a shunt install like in my RV but decided not to.
AMPS today during the ground run did not exceed 11. I will never be in a condition where the starter and/or ignition backup are not in a nearly full state of charge. With pigtails on both, they will be maintained and charged after any period of non use.
I've decided to call this MOD done. I'm staying with the EarthX ETX104. I will fly with the right forward panel off a few flights to monitor for my own comfort, both the electrical but also my mount solution.
