Net Jets Question
The 15 day flex would be my first choice but I would guess that it will be a long, long time before I will be able to hold that if it only is available to 10% of the pilots.
As far as the seat locks go; will the 39 month seat lock be effective immediately if the IBB passes or will current pilots be grandfathered in under the 24 month lock until they make an equipment/seat change?
Yep. Everybody's up in arms about the possibility of getting it junior-assigned. I don't think they'll be able to get it if they want it! (And I want it too.)
Grandfathered in:
"All Equipment Locks in effect on the date of ratification of this Agreement will remain unchanged following the ratification of the Agreement.
Grandfathered in:
Nice. There is still hope for an APU in 24 months then for me.
Yep. But keep in mind, if you bid another airplane as an FO, you will either have wait to upgrade in-fleet (and thus no additional equipment lock), or upgrade into a different aircraft and have your remaining seat-lock added to the 39-month one. Just something to think about if you switch planes as an SIC, and then upgrade into a non-APU plane.
This is actually a big improvement over the existing contract. Under it, if you switch planes as an FO, you're completely blocked from upgrade until the new 24-month seat-and-equipment lock expires.
Yeaaaaah....thanks for the help...you can go ahead and just kiss my a$$....not on the left side...or the right side.....but right in the middle...
Hot Dog: The Movie. Awesome
Yep. Everybody's up in arms about the possibility of getting it junior-assigned. I don't think they'll be able to get it if they want it! (And I want it too.)...
The 15 day flex certainly looks interesting. As a family, we'd at least like to try it out to see if we like it. Just how senior do you think they mean when they say it will "go senior"?
With Cessna in ICT how would the schedules be in ICT, I see alot of NJ guys in and out of ICT. how senior would that base be?
Schedules same as anywhere else - pick between 18-day, 7/7, or 15 day (if this passes - if not, 7/7 or 18-day reserve). No bidding to get into bases - just let the company know which crew base you will be using. Change as often as you like with a 30-day notice to the company.
Edit - to clarify, schedule bidding would be within the CBA, so the potential is there to be junior assigned to the 15-day, or denied the 15-day if too many people above you bid it. I'm sure you get the idea though.
Along with imacdog's reply, in case you are wondering, there is no "basing" of aircraft in ICT so anyone using ICT as their crew base could be on any plane in the fleet. So you wouldn't necessarily be assigned a Cessna product if you choose to live in ICT.
With regards to scheduling, the 18-day Fixed schedule is volunteer-only and it's capped at a 40% participation level. All new-hires are paid wages for the 18-day Fixed schedule in order to accomodate training. One could bid off the 18-day Fixed when IOE is completed, at the next bid period.
Also, from my understanding, where you are based will have no effect on what schedule you are on. The schedules are awarded fleet-wide, irregardless of what your base is.
That is correct.
The Beechjet(400XP) is just misunderstood! It is a great little airplane, just doesn't like to climb with wing heat on. At my company we do 2 or 3 legs a day, while other frame do 5 or 6 legs and 14 hour days. Pay being the same, would you rather fly an Excel/X and get hammered or a Beechjet and have a nice relaxing day.
It doesn't like to climb period! :laugh:
Actually it's the 2nd segment climb performance that usually causes crews to be stranded until the wx is VFR.
I'm in the 400XP sim now for initial ground school. Overall I like the jet much better than the Ultra/Encore but that's mostly because of the avionics package. The jet is faster and the cockpit is laid out more logically for us ex-airline types. Of course that fact that it breaks all the time and the crews often only fly 20-30 hours month had no bearing on my bidding the 400XP ;)
AirBear
