Let's Hear it Folks ! You Might be a FR8DOG if......
You wake up in-flight not knowing where you are, what time it is, and knowing the engines don't sound right, only to realize you're in cattle class deadheading to the next load.
You're snoozing in the jump seat on another leg and after landing are queried by the NTSB regarding the flight's severe turbulence encounter and subsequent diversion. You can't help as you slept through the whole deal. 'Flight felt fine to me.'
You wake up 10 seconds from touchdown, 'my airplane', and prevent the pay-to-play FO in the right seat from pranging the plane.
You deny the Fed's ramp check request as you haven't had a chance to empty the lav. The Fed says that type doesn't have a lav. He disappears when you say 'I know.'
You upgrade and celebrate. Now you can afford a place with only 3 roommates.
You met your instrument currency last night, including the partial panel non-precision approach with a circle-to-land with a holding pattern in lieu of a procedure turn.
You go back to flight instructing to fly newer airplanes.
Fly SAFE!
Jedi Nein
Your boss upgrades the freighters with GNS530's...but pulls the HSI's out...
(True story...)
Eric
When you get into a newer airplane, and there's no vibration.
..and it scares the hell out of you...
CE
(how do you tell it's runnin'?)
Spoolingbyu said:
While waiting on freight with no other place to go, you decide that with a modest effort the 9-G Net can be strategically re clipped into a makeshift hammock for a few z's.
When Speedy in LRD knows you by name.
When you use the same 9g net as a clothes line to dry out sweat soaked shirts and pants.
A newer airplane is anything manufactured post WWII
You go back to CFIing for more money
As a CFI, you subconsciously add 2 quarts of oil to the engine of the c172, before every flight. You then have a more "at home" feeling after your plane begins leaving its mark on the ramp.
You think a GNS530 is a new video game
I LOL'd
CE
You can find your company's parking spot at ORF from the oil stain just to the left of center. That happens to match up with that particular plane's drip pattern.
OH, John- and a good way to clean that windshield in flight is to keep a squeeze type water bottle in the plane. Reach out and stump some fuel, then spray at the base of the windshield. Should cut enough oil off so you can land (or pick). Still gotta wash it later though; it does tend to fog the windshield after a while.
if atc advises left or right of course approved to avoid a level 5 TS and you dont care.
don't deviate, penetrate!!! or you'll be late.
"You've ever thought 1sm and 400' OVC is practically VFR."
It isn't? I always thought is was good VFR
You only check the Wx to see how much fuel you need.
You might be a freight dog if your aircraft's logs are in spanish.
If you've ever used a flashlight or two for landing, nav, or position lights. TG for duct, er, speed tape!
Bonus points if you broke down and bought a green lens for the flashlight.
You don't complain about being put up at the Craphole Motel. You're just happy they put you up in a motel intstead of leaving you at the fbo for 10 hours.
If a dispatcher has ever said "the radar looks reasonable along you route of flight" and ten minutes after takeoff your FO's flightbag bounces its way into your lap.
Take care,
Fish
p.s.
It should be fixed. We looked at it and it seems fine.
Write-up: Aircraft turns uncontrollably to the right. Straight and level flight is obtained by constant left aileron pressure.
Mechanics actions: No problems noted, return to service
Take care,
Fish
FR8dog
You been asked to slow to final approach speed because your van is catching the lear on final
or you've been told to "slow it all the way down" and then when your at 70 kts in your Caravan, towers laughs and says "OK speed it back up"
both happened this week @ ATL
