Legacy Bashfest - Bring it on!
So far this has been a great discussion. I am finding it hard to believe I am still talking about an airplane I have never flown (for the record, flew RJs for AE).
I applaud your knowledge GV but I have to call "b.s." on ya'! :)
The Legacy is the same type certificate as the ERJ-135, it is the ERJ-135BJ.
Yes, but even the 135 has evolved. The oldest models we had were not as good as the newer ones. Embraer made signifiacant changes to all three RJ versions, adding fuel, thrust, changing cockpit, improving fadecs, etc.). The 135BJ has gone through a similar evolution.
And yes, I’ve watched it grow.
I’ve watched it grow poorly engineered winglets which disrupted airflow and introduced yaw instability requiring the installation of vortlons and ventral strakes.
This is the part where your knowledge hole appears. The airplane had vortilons from day one. The winglets were not added until nearly a decade later.
As for the engineering goes I can't comment. The winglets must do something or they would be gone. It is probably hard to mate winglets after the fact so some concessions have to be made. I think the strakes look cool any way. :)
I also watched it grow fuel cells in every imaginable region of it’s wing and fuselage in order to make it’s range guarantees.
Another BS call on you here. The wing tanks are the same as the LR (the Legacy actually claims a slight reduction in wing fuel from the LR). The fuel tanks in the fuselage don't seem too complicated: one bisected fwd one bisected aft. Grand total four fuse two wing tanks.
As for Embraer vs G design philosophy, take a llok at what it was built to do. Embraer told its customers it could deliver 2000-3000+ hours per year and lots of cycles with high reliability. That is what it was made to do and is doing. I cannot call that fragile. In fact, it may be overbuilt for the corporate world (we might be lucky to fly our Falcon 500 hours a year and we don't do five legs a day - what are FLOPS' Legacys doing? Three, four times that?). Also, as one pointed out earlier, have you seen the landing gear trunion/strut on a Legacy/ERJ? That thing is beefy! Hardly fragile.
Gulfstream is wonderful, but it sounds like they are a lot less efficient than they need to be if they are as overbuilt as you say.
C&DD may be a reputable organization, but I have to go with the people flying the airplane who tell me what Volumes 1 and 2 of the AOM say. C&DD are a little behind the ball.
Also, forgive my ignorance, but would the Legacy delay flutter with a boosted elevator?
some_dude said:
GV, great posts!
I must agree. It appears you have a great handle on this ..... vs that unfortunate Aurther Q comment.
I always enjoy reading your informed well thought out retorts. I always learn something new. Thank-you.:)
This is the frustrating part, however, and that is that the man can make mistakes about the airplane that are obvious even to a lowly former-RJ driver but the crowd still cheers. People are not being objective in this debate, they are simply taking the side of a guy they like even when he is wrong (perhaps rarely, but still not infallible). Try to read what is being said by both sides and call a spade a spade.
LegacyDriver ... how nice it is to have you back. That NetJet Strike post was threatening to talk over as the highest number of post on the FI message board. I look forward to watching this .... again.
Really, it is nothing personal, it is just fun to watch
I guess I am now the third (?) peson to be incorrectly accused of being LegacyDriver? Were I he I would have come up with a more original nickname to hide my identity - like "StickShaker" or "EGPWizzard").
Whoosh goes objectivity!
I am not he (thank God), but I think I will pack my things up and exit this discussion. From my perspective using the "LegacyDriver" argument is much like using the "Hitler/Nazi" argument. When one is losing a debate they'll pull that trump card out of their hat and any hope of a sane discussion quickly disappears.
I sense the rational tone evaporating shortly.
The following is not an attempt to nudge it that direction, but I can feel the heat of the flames already. :)
The thread's primary debators have not even established a true baseline upon which to objectively discuss the airplane in question. The data being quoted is in dispute. That is quite clear. I would think that if a Legacy is so poor an airplane then use the best numbers available - i.e. those most favorable to it - in order to evaluate it. It is quite clear that the Gulfstream numbers used are most favorable to it coming from a man who is arguably one of their test pilots. To use the best numbers for yourself and the worst for your competition is automatically an unbalanced playing field. All the data I have managed to find - which shows a more up-to-date acquisition of information - exceeds C&DD for the Legacy. Why are some afraid to simply accept that as factual for the sake of the argument? If Embraer were lying about their performance numbers would they not be liable as well? I would think it was a bit more important for the manufacturer to get its numbers correct. Needless to say, nothing I have seen anywhere other than C&DD shows the 3,050NM max. range that was quoted earlier.
GVFlyer said:
Keep in mind that Long Range Cruise for the G350 is over 8% faster than the Legacy while the 71,300 pound G350's hourly DOC is only 7% more than the 49,758 pound Legacy's. So actual operating costs are about
On fuel burn alone the Legacy beats the G-350 by 27.7% per hour. And we all know Legacy pilots make much less (being the second class citizens they are treated like here is that surprising to anyone?). EMB parts are cheaper (being made out of tin foil and such), too, so how can the G-350 even approach 25% much less 7%? It defies the laws of physics in my mind.
Cost per mile numbers claimed by Embraer take into account the difference in speed, by the way, and Embraer claims a huge savings over G-Anything. I have yet to hear the cost of MX and parts replacement addressed either, but based on discussions, Gulfstream parts cost a great deal more. Also I am told Embraer's "on condition" engine replacement program is also cheaper based on how it is "charged" to the customer - based on hour credits and other things - to the point that Embraer is claiming a 40% operating savings over a G-350. I am still waiting to hear if my fuel burn calculation is anywhere near reality. Paying $5 a gallon for fuel makes that a very significant number I would think.
Six million bucks is a lot of coin, too, so I don't know that throwing money at something necessarily makes it better.
But digression is not in order so to the point.
As noted previously (to AcroChick) this thread is merit-less, especially when the principles involved can't refrain from name-calling, insults, dog-piling, personal attacks, and accusations-of-identity-theft that have no bearing on the discussion at hand. It seems difficult for people to maintain a civil tone where Embraer is concerned which I find quite puzzling to say the least. Are they such a dire threat to Gulfstream and Falcon that one has to resort to denegration of Embraer and their supporters? (They're Brazilians, after all. Perhaps you don't like brown-skinned folks, is that it? Or is this a classic "you're-a-Nazi" argument and these evil Brazilians are actually descendants of Nazis and are thus to be despised? Help a guy out here I'm trying to understand the hatred, honestly.):(
(And yes, I have a sense of humor - I think I am the only person here who actually took the thread title for the tongue-in-cheek attempt at humor that it was.)
Enjoy yourselves, kids! Toodle-loo! :D
Of course you took the thread title correctly ... you wrote it! You have told us about it before, remember?
Anyhow, please do go away mad, or go away at all.
Yup, it's confirmed... ERJ-140 is IN FACT LegacyDriver... Who is also LegacyIIDriver who is also Skull-One, who is also vracui...
The guy just can't resist...
IP Addresses don't lie...
A glutton, eh? He is not hard to pick out. The sentecne logic and syntax is the same on all 3 (or was it 4) of his names. Even his kiss off to the board is the same. Oh, well. It was fun while it lasted.
Next time you come back .... and you will ... please try and make it a little more sporting for us all. I know it is hard to change ones personality, but please try a little harder.
Well, good luck to you. I hope the WSCofD continues to treat you well. It is obvious to all of us that you REALLY like the airplane and that is GREAT. Please come back and tell us more "stories" about the WSCofD. I enjoy them ...
OWNED!
What a freakin' tool!
Keep's coming back for more....
Hey Capt, hows it going?
Multiple personalities...that's just wierd.
On the other hand, another member of my family also has a screenname here. I'd hate to be called on the carpet just because we both have the same IP address.
Falcon Capt said:
Going well... Tomorrow is the big day... It's been way too long, ready for it to be over!
THE BIG DAY, what might that be?
I know, you're trading in those nice shiny Falcons for a WSCoD:D !
