Legacy Bashfest - Bring it on!
WSCoD The real story
If this post is going to keep the WSCoD allive then at least pin it on a 'real' candidate.
See below.
Personally I think it should be deep sixed as not a worthy in a professional environment (and a public one at that). Brussel Sprout OK ........but not WSCoD.
Challenger jet has history of tragedy; Company officials defend model, claim data is deceiving.
JOHN DOBBERSTEIN
Tribune Staff Writer
7 December 2004
South Bend Tribune
The type of small jet that crashed in Colorado last month and killed the son of NBC Sports Chairman Dick Ebersol is no stranger to drama or tragedy.
Since 1980, 13 people have died in England, Italy and the United States while traveling in Canadair Challenger 600-series jets, according to various safety databases. Ten of those deaths have come in the last four years.
In fact, the same Challenger 601-1A jet that carried Ebersol's family rumbled to a stop on a Florida runway five years ago after braking problems.
During a Nov. 26, 1999, landing at Palm Springs Regional Airport, the pilot employed the thrust reversers and brakes on the jet, but "there was no indication of braking action," a report from the Federal Aviation Administration said.
When the brakes were released, all four tires blew out, but the plane stayed on the runway and came to rest.
Teddy Ebersol, 14, was killed in the Nov. 28 crash at Montrose Regional Airport in Colorado, as were the pilot and flight attendant.
The jet was headed for South Bend Regional Airport. Ebersol's family said the plane -- carrying Dick Ebersol and his two sons -- lifted briefly during takeoff, then tipped back and forth before crashing and burning.
Federal investigators have said the plane was not de-iced before takeoff, although nothing has been ruled out as a potential cause for the crash. Aviation observers have said the Challenger's design makes its wings prone to ice buildup, because the wings have no movable "slats" found on larger jets that help the aircraft lift from the runway.
Officials at Jet Alliance, the company that chartered the flight, said Monday they have no concern about the safety of Challenger jets.
"We've been operating them for tens of thousands of hours since 1991," said company President Clifford Russell in a statement.
Maintenance not an issue
FAA records show the Challenger 601-1A jet was owned by Hop A Jet of Fort Lauderdale, Fla.
The Ebersols originally contacted Los Angeles-based Key Air for a flight out of California on Nov. 28, but there was no plane available, said Jet Alliance spokesman Chuck Wyble.
Key Air contacted Air Castle Corp., a charter flight company and subsidiary of Millville-N.J.-based Jet Alliance. Jet Alliance manages charter flights and provides the flight crew for Air Castle.
Records show Air Castle Corp. has been cited several times by the FAA between 1985 and 2004 for violations of rules pertaining to flight manuals, the monitoring of inspection and maintenance programs, and the establishment of a required alcohol misuse prevention program.
Air Castle is still resolving a maintenance-oriented complaint lodged by the FAA from Oct. 15. Wyble said the complaint is a "procedural question" and wasn't safety-related, and it didn't involve the plane the Ebersols were on, either.
"The maintenance was done. It's not like the maintenance was not done and the aircraft was flying," Wyble said.
"A lot of these (violations) are tiny, minor things that are being put on the list of 'You didn't do that right.' A lot of it is paperwork, and the FAA is very critical on making sure things are done in a particular way.'
Fatal crashes have marred the recent tenure of Challenger jets.
On Oct. 10, 2000, two people were killed when a Challenger 604 crashed on takeoff during a test flight in Wichata, Kan.
Five people were killed on Jan. 4, 2002, when a Challenger 600 crashed at Birmingham International Airport in the United Kingdom. Officials said icing might have been the main cause, as well as the use of nonprescription drugs, jet lag and fatigue on behalf of the pilots.
National Transportation Safety Board investigators handling the Colorado crash are looking closely at that incident, because the plane carrying the Ebersol family was not de-iced.
After the crash at Birmingham International, which involved a Challenger 600, the U.K.'s Department of Transport issued a number of safety recommendations.
One suggested the jet's manufacturer, Bombardier Aerospace, and other aviation regulators warn pilots flying aircraft susceptible to ice contamination that "Wings and tail surfaces must be completely clear of snow, ice and frost prior to takeoff."
European officials also recommended the FAA and Joint Airworthiness Authority in Europe to review procedures pilots use to detect and eliminate ice from aircraft, "and consider a system that would directly monitor aircraft aerodynamic surfaces for ice contamination, and warn the crew of potentially hazardous condition."
FAA spokesman Mike Fergus said the U.K.'s recommendations are still being reviewed and haven't been formally adopted by the agency. The FAA routinely gets recommendations about safety, he said.
Some nonfatal incidents
Other crashes and incidents involving Challenger jets have brought scary experiences or injuries for pilots and passengers.
On Feb. 7, 1985, the pilot of a Challenger jet missed a runway in Italy and the plane slammed into the ground. There were no injuries to the crew of three and nine passengers. Eleven months later, the right engine of a Challenger jet "flamed out" while it climbed after takeoff from Syracuse Hancock International in New York. The plane landed without incident.
In August 1986, a similar jet was forced to make an emergency descent after pilots smelled fumes in the cabin. Hydraulic fluid was leaking onto a hot duct.
In 1989, after leaving Louisville International Aiport- Standiford Field in Kentucky, pilots discovered part of the outboard door assembly on a Challenger came apart while in flight. Three screws were sheared off at the head.
An engine fire in 1990 forced a Challenger jet to land at New Orleans International Airport, and in 1998, a pilot landed a Challenger jet at Dallas Love Field after the windshield cracked.
Later that year, a Challenger jet landed at Denver International Airport. Both tires on the right-main landing gear blew out, and the debris damaged other steering equipment. The crew managed to keep the plane on the runway using only the left brake. But as the jet slowed, it left the runway before coming to a rest.
The FAA does look for patterns in crashes or incidents with certain aircraft or operators, but drawing a connection can be difficult, Fergus said.
"You might have an accident with two identical aircraft," he said, "but different causes."
Ted Lopatkiewicz, a spokesman for the National Transportation Safety Board, said the agency has no record of issuing any safety recommendations to the aviation industry about Challenger jets or about Air Castle's operations in particular.
"If we see something wrong in any investigation, even if a company only had one accident ... and if we see something wrong in the way the company is operating its service, we do issue recommendations," Lopatkiewicz said.
"It doesn't require a pattern of accidents. We'll do it after one accident if we see something that could have been done better."
Bombardier has already defended its record. Of the 635 Challenger aircraft in service, 67 are Challenger 601-1As, which were first delivered to customers from 1983 to 1987.
Company officials have reserved further comment until the investigation of the Colorado crash is completed.
One small flaw in your logic...
The Challengers don't whistle... They are one of the quietest Corporate Jets built...
Ace-of-the-Base said:
Obviously, my Gulfstream friend, I know the whole story. I was in SAV when it happened and flew during several 'green' deliveries with the GAC test pilot who was in the other seat...but thanks for sharing the story with everyone else.
Ace
So Ace, does that mean you work for a company with three nearly sequentially serial numbered GIVs?
WSCoD
LegacyDriver,
I just found this on the Flight Options Board. Comments?
Legacy range is only 1 hour more than the 800XP ?
I was surprised with some literature I received today concerning leasing options from FO. I guess now you can lease as little as 50 hours a year with other options such as a plus 25 program, access 25 program and the 75/25 program. I had heard about such programs before but I had never seen anything in print until today.
The one fact that surprised me was the range of the Legacy. FO advertises the range as 3565 S.M. The 800XP has an advertised range of 3013 S.M. I guess I thought the Legacy had more than an hour longer in range than the XP. I was told that the first 4-6, not sure of the number, aircraft received would not be the same as the ones build as an Executive aircraft. I was told that they were built for a feeder airline and do not have the changes made for the Executive model. I was told FO received a great deal to take the aircraft. I am not saying that is bad, I am saying that I am surprised the Challenger 601 has an hour more advertised cruise (in range) than the Legacy. Looks to me like the Legacy will have a tough time in the winter going non-stop west bound from most of Europe to the NE part of the USA. Paris to NY in Dec. – Mar. looks difficult with IFR weather. It will be a good aircraft for trans-continental.
Not sure where they get these range numbers, I guess they are talking about still air, fuel exhaustion, at long-range cruise, and not range with IFR reserves with requirements for an alternate at normal cruise.
I do find it a little amusing that I am on FO prospective client mailing list. Could it be that they want me to invest in FO after our case is settled? .:rolleyes:
Regards,
GV
Another fine piece of aviation journalism...
Silver wings--Did you actually read the article before you posted it?
The Ebersol plane had brake problems in Florida... The article said it landed in Palm Springs. Is there a Palm Springs, FL?:rolleyes:
The airplane didn't have any mx problems but it's operator had some paperwork issues with the FAA. Who hasn't had an anal FAA inspector point out that some of the "periods in the mx log actually look more like commas"? :rolleyes:
The Birmingham accident also involved icing and "nonprescription drugs, jet lag and fatigue". Better ground the fleet. :rolleyes:
In ICT, they crashed on a test flight. What aspect of the Challenger's design caused that accident?
None of the incidents can be attributed directly to the design or manufacture of the aircraft.
Is icing a problem with the Challenger? Maybe. We all know to err on the side of caution when it comes to icing. If someone is in too big a hurry or the operator pushes crews to not deice, is it BBD's fault?
I'd even rush to the defense of the Legacy if it was the focus of a similar article.TC
Yes I read the article, and broadly I agree with you.
The point was that this thread has unfairly labbelled the Legacy WSCoD...... when there are over 6 million hours of expereince with the airframe and not a single fatality. If you consider the fatalities with the CRJ/Challenger combination then you have a meanginful statistical difference !
Are Legacy/ERJ pilots safer than Challenger/CRJ pilots ? I very much doubt that.
Are the conditions of operation of the Legacy/ERJ and Challenger/CRJ so very different ? Answer no.
So logically the only differing variable is the aircraft. Hence the discrepancy in safety performance could reasonably be infurred as being due to the aircraft.
Or pure bad luck. But that's a lot of bad luck and it's beginning to push the limits of credibility.
Personal opinion, the Challenger/CRJ is probably no different to any other certified aircraft, and is quite safe when operated and maintained correctly.....howver the Legacy/ERJ has achieved a proven 'best in class' position in this regards by keeping a clean sheet over a very long time and lot of flying..........
Hence the reaosn why it is so wrong to put the WSCoD label on the airframe.
Heregoes, why not rename it the 'Whistling **CENSORED****CENSORED****CENSORED****CENSORED**can of Safety'......
Doesn't quite have the ring to it does it though ?
Since when did anybody in the USA have a sense of geography ?
This is a journalist as well....... you can't expect miracles.
all people should be well-versed in geography, IMHO...but pilots should definitely know a thing or two about it!!
so what is this thread about again?? oh yea...WSCoD!!!!!!!!!!!!!!!!!!!!!!!!!!!
I only wish your comments were true, but last summer I watched B52's from US bomb the wrong airfield....I was at Farnborough aishow...and they bombed Blackbushe..... oops....and that's with GPS I presume. (Blackbushe...small prvincial airfield....Franbough ...major Internalional airshow in prgoress on much bigger field). And it wasn't for the first time either. So you can't always agree with pilots.....on Geography.....
and reading your final post looks like you can't trust pilots like you on being able to tell a WSCoD from the aircraft with the best safety record (hrs flown vs. 3 dead) ever built........either. (In case you didn't know the ERJ series with over 6 million hours an no fatalities has the best record of any I've seen to date anyway.).
There should not be any fatalities when you fly a WSoD between Newark and Cleveland for 6 million hours.
Heck, a 9$/hr chimp can do that. Cont. Express proves that point.
Is using "death" in WSoD maybe a little exaggerated?...yes I suppose...but the point is the aircraft is really a Piece of $hit. Its noisy, it rattles, its uncomfotable, it has lame perf #'s, etc...all the qualaties a bizjet is not supposed to have - and for someone to come here and attest to how its going to compete with GV's etc....well, he's going to get it!
To please the PC crowds maybe we should change it to simply "Whistling $hitbox"???
Very Funny! Still laughing!
(What happened to G-Unit and Fiddy-cent?)
GV
GV
Fiddy be back, just tied up at the moment slappin some ho's over on the fractional board...
SkyGirl said:
Ace,
You're wrong to call GVFlyer stupid (as in Keep it Simple Stupid) because he uses a different writing style than you do. You come off looking petty. I like his posts; I think they're informative and entertaining. He gives me an insight into aircraft certification and manufacturing that I wouldn't otherwise have. I suggest that if you don't like his posts, don't read them.
As for me, I'll keep reading his posts and those of the other pro's like FalconCapt.
-SkyGirl-
I'm glad you like his posts - keep reading and keep learning.
If you look (not to closely) at my KISS remark, it had a little :) next to it. Cheeky, get it. Obviously all of us that have thousands of hours in Gulfstreams have something of value (most of the time) to say, not just the ones who make the longest and most frequent posts. GVFlyer has a lot to say about ALL airplanes and takes the time to make some pretty interesting posts for us all to read. I commend him for that. And also for knowing everything about the Gulfstreams :) <---(did you see the face?)
Ace
How did you happen to be at the Farnborough Air Show - manning the Legacy static display perhaps?
GV
Sorry this took so long...
GV I will gladly rebut the FO commentary you cited.
Comparing the first five Legacy jets (N525CW, etc.) to those being built now (N809SG, N825SG being the last two delivered to my knowledge) -- the LEGACY II -- is like comparing a G-IV to a G-IVSP. They are substantially different.
The facts that differentiate N525CW (Legacy I) to current-build Legacy IIs (N825SG, etc.) are the following:
__________________________
1) Engines - Legacy I = A1P
Legacy II = A1E (Substantial changes in thrust and SFC between the two).
2) Aerodynamics - Legacy I has: Windshield Wipers, standard air inlets for avionics bays, etc., standard RJ unfaired wheels, and a lack of gap seals (among other things).
Legacy II - No wipers, Faired main wheels, intake doors for avionics compartments etc. that close in flight to reduce drag, and gap seals for all control surfaces.
3) BOW - Legacy I weighs over 40,000 lbs empty (N525CW is close to 41,000 lbs).
Legacy II weights under 40,000 lbs. (N825SG weighs under 39,400 BOW, a figure that continues to go down with each airplane as they learn how to do it better).
4) Fuel - Legacy I had a different center fuel tank and tank system. Fire suppressing foam was installed in the tanks that later proved substantially beyond the requirements for the job.
Legacy II, based on this information, removed a large amount of fire suppression foam from the center tanks resulting in an increase in fuel volume available. The resulting fuel increase is anywhere from 800-1200 lbs depending on how you measure it.
These changes, among others, make the current production airplanes a significantly different animal than the first five built. The AOM lists them as different machines.
The range on the Legacy II is superior to the I by a substantial margin due to the changes listed above. The first five airplanes, now operating at Flops, are not representative of new-build airplanes. The performance is well beyond 3,200-3,500 NM with the Legacy II. When FL410 comes the range will be even more. NY-London and back is no sweat even with headwinds.
I don't know what else I can say. I am repeating myself here.
Also, with the exception of the wing crunch for taxi the first five Flops jets have been flying in excess of 135 hours/month with a 99.5% reliability rate...
jeez, i am sure that if i was in your position i would be promoting it as well. BUT, give it a rest already. it will have its niche. just not with the people that can and do own Gs and Gexs. maybe with the hooters of the world. apples and oranges.
But you are so wrong here... Some people are leaving the G-IV world for the Legacy. I flew a guy on behalf of my boss last week and he said he switched from a G-IV to a Legacy and he doesn't regret it one bit. "You just can't find a more affordable airplane than this one. The acquisition cost alone is reason enough to go with it. It could be a little taller in the cabin but that's a minor quibble." We talked for fifteen minutes about it and the guy has no regrets leaving the IV for the EMB.
He may not be the rule, but a sale is a sale. Come on...if the Legacy weren't a threat to Gulfstream and Dassault then the vitriolity in this thread would be gone.
People don't become rich by wasting money. If a Legacy will do the job for them for less money then the prudent person will buy it. It's that simple.
