Golden Falcon
- Feb 8, 2006
Just engine thrust left after a dual hyd failure? Why did they stay in the air so long if it was that serious? The Alaska MD-80 crew/pax might be alive today had they landed asap.
Kind of wondering that myself...really that concerned about an overweight landing with 2 hyd systems on the fritz?
I dont give a crap what airline, what airplane, background of crew, or how fat the FA's are. When you have a some pilots who are in a bad place and they safely land an aircraft without hurting anyone..............Fu#king great job guys and gals.
The bus has 3 hyd systems, and you do have rudder, elevator, ailerons, flaps & slats on blue system. You do not have reverse, brakes or nose wheel steering on blue alone.
Reports indicated a loss of green followed by a yellow overheat, then a recovery of yellow. A single failure does not give a LAND ASAP ECAM message, a dual failure does.
A dual failure without reverse and brakes would be sporty to land at LAS on a high density altitude day. EDIT: You would have the accumulator pressure for some brakes, but not normal or alternate brakes, and no anti skid.
Good job to the crew! I've had a single hyd failure in the bus which was a non event. This could have turned out bad if they had rushed it.
Really? You have to wait until the plane tells you land?
