JetBlue control problem over Vegas yesterday?
I dont give a crap what airline, what airplane, background of crew, or how fat the FA's are. When you have a some pilots who are in a bad place and they safely land an aircraft without hurting anyone..............Fu#king great job guys and gals.
Well said
The bus has 3 hyd systems, and you do have rudder, elevator, ailerons, flaps & slats on blue system. You do not have reverse, brakes or nose wheel steering on blue alone.
Reports indicated a loss of green followed by a yellow overheat, then a recovery of yellow. A single failure does not give a LAND ASAP ECAM message, a dual failure does.
A dual failure without reverse and brakes would be sporty to land at LAS on a high density altitude day. EDIT: You would have the accumulator pressure for some brakes, but not normal or alternate brakes, and no anti skid.
Good job to the crew! I've had a single hyd failure in the bus which was a non event. This could have turned out bad if they had rushed it.
Really? You have to wait until the plane tells you land?
No, LAND ASAP (comes in red and amber varieties) is an *advisory* message that the problem is serious enough to land ASAP. If you know the systems, it's probably redundant but if you see it, it's a reminder that the problem is really serious. You don't have to wait for it before landing, but you'd be a fool to ignore it. Essentially, red means land RFN or you're going to die (or at least mitigate the problem so the red advisory goes away), and amber means land as soon as you can so you don't get hurt.
I guess you have it figured that Airbus pilots are idiots who have to be told what to do by the plane or they can't function. Maybe, just maybe, the Airbus ECAM logic is simply better and more comprehensive than what you're used to. For instance, I just saw the SWA incident report where they ran off the end of the runway because the speedbrakes weren't armed for landing. The Airbus won't let you do that (unless you don't even check) because spoilers being armed is a monitored condition on the landing menu. You're such a good pilot that you wouldn't need the reminder that spoilers aren't armed or that you ought to land ASAP, but the rest of us goof up sometimes - especially under the stress of a broken routine or an unfamiliar fault - and would like the backup.
No, but the absence of a LAND ASAP ECAM tells you the manufacturer thinks it is OK to continue the flight at least long enough to not do an over weight landing.
Remember the BA 747 crew that caged one and then flew all the way from the west coast to London on 3 engines? They got second guessed quite a bit in the industry. I popped one of the 3 hyd systems at altitude on a transcon, and finished the flight without incident and without any FAA Monday morning quarterbacking just because I did not get the LAND ASAP.
It's a bus thing, but quite handy if you know the logic behind ECAM and are up on your systems knowledge. The bus is very easy to fly, but can get really complicated real quick if you are having a bad day.
They actually diverted prior to Manchester for concerns of low fuel to to the 12% increase in fuel consumption. Also with fire reported shooting from the engine prior to shut down who knows what other damage could have occurred.
Pretty easy to be a Monday QB.
With the loss of the Yellow and Green system, you get no reversers, no braking except approx 7 applications of the parking brake, no nose wheel steering, and only 1 spoiler per wing.
That would have been pretty brutal being overweight in LAS.
Did anyone see a picture of the JetBlue airplane after landing in Vegas? Was the RAT deployed? Does the PTU get to do it's full self-test when doing a single-engine taxi followed by the second engine start and immediate takeoff?
With no loss of electrical I doubt the RAT had to be deployed. I am not sure what JB uses for wait time. But we use 3 min after 2nd engine start before we can takeoff.
If I was only on blue hydraulics, I'd want 2 sources to power that baby!
It's a good thought but it might not actually work that way. They might not work in tandem at all. The RAT might only come on line if the blue pump has failed, which means you're deploying it needlessly, or it may override the blue pump, meaning you're trading a known good component (the electric pump) for a unit that probably hasn't been in operation since the plane was delivered. I'd probably stick with the checklist on this one.
One system overheated, the overheat will fault the ptu.
Can you land the Airbus with no hyd at all, or are you screwed?
Did it in the sim as an exercise, which was interesting. I'm not sure I could repeat it in real world conditions. There's a sort of very low level reversion mode that really is only supposed to be used to keep the plane upright long enough to get one or more of the other systems back on line. It's not intended to land with. Think Sioux City.
But in order to lose all three, you either took a SAM hit that tore up three different isolated systems and lost all your fluid -or- both engine pumps, two electric pumps and the RAT would have all failed. Either you're incredibly unlucky or hydraulic failure isn't your only problem. Bad day all around.
Yeah, the self-test only takes a few seconds when you start the second engine. JB has a two minute warmup if the plane has been on the ground for less than two hours, otherwise it's five minutes, so that isn't a factor.
