cougarx530
Member
- May 26, 2004
PCL_128 said:The second certificate is no longer an issue for the time being. The company has stopped putting any resources into Pinnace 2, Pinnacle NewCo, or whatever else they have called it in the past. Before they put it on hold they were still 6-12 months from being able to use it anyway. Now that it's on hold, it will probably take much longer than that to get it going again whenever they decide to start. Management is focused on other things right now. Pinnacle 2 is the last thing on their minds.
Positive Rate said:Does the BK judge have anything to say about the "scope"? Can they over ride that on the XJ side for any reason?
CubanSmoker said:They can't do that unless MAIR themselves is also bankrupt. That's because that scope language exists between MAIR and Mesaba. We're bankrupt, they're not thus that language cannot be changed or chopped by a BK judge. That's right from our Alpa lawyer at the last LEC meeting.
Thedude said:Dont forget there are more than one certificate under the NWA umbrerlla NWA -Pinnacle-Mesaba-Champion. I am hearing that the feds have shot down NWA getting another certificate
Max Powers said:Not true I am hearing that NWA still has some certificates in their closet. For Example Republic to name just one. In any event they would have no problem getting a new certificate.
Max Powers said:Well what is it with pilots and certificates ...... Listen if Hooters/pace can get a certificate I don't think NWA should have much trouble.
They will start up newco.... IPO it...... and then whip saw whip saw whip saw!
Ye haaaaaaaaaa ALPA needs to stop this from happening or NWA pilots should walk. Oh wait you would have to have some balls to do that.
Monster Buck said:Newco? Let's see, hhhhmmmm... How is Mid-Atlantic, Song and TED doing?... Well one out of three ain't bad.
