Interesting MOA encounter with Viper
MOA's are open airspace and due diligence is required by all parties entering nd operating within, the military does not have precedence.
If you have ever flown GA out west, particularily slow planes, then you know that some of these areas takes forever to circumnavigate. The exciting areas are "R's" and when in use, stay the heck out.
Heck, next thing we will hear is how all GA planes must avoid MTR's or be called idiots.
Don't the answer what?:pimp:
The what answer to question huh?
Dude, you started the pissing contest by spouting off on something about which you know nothing...namely MC-130 formation. I asked a simple question, you claimed to know the answer yet fail to answer.
You're coming across as the guy in the debrief that says "oh yeah, I had SA right there...I was thinking X,Y,Z, but yada yada yada." Making sh*t up the whole time.
I would argue that the military does have precedence. We can operate in a MOA differently then other airspace, GA is restricted from operating IFR in a MOA. How is that NOT precedence?
MILITARY operations area. ie: Fast, military jets will be operating at high speed in large numbers. How is it that GA thinks it's OK to blast through there?
MTR's are very easy to avoid. Some near Yuma I would avoid at all costs. Some in Texas NEVER get used.
2 questions:
1. Why will no one agree to calling before entering to make us aware of you so WE can change our plans and avoid you?
2. Would you go blasting through a sailboat race with your boat? It's legal.
P.S. Magnum and SNA, unless your discussion is relevent to the thread topic either please PM each other or start a new thread.
Bjammin,
Just playing devils advocate here, but if the military needs unrestricted use of the airspace, it becomes a "R" area.
MOA merely means that the military may be operating and even during active hours, the military often isn't actually operating, merely advising that they might be.
I am not sure there is anyone a GA pilot can call to advise you, the mil pilot or the operating facility , that they will be passing through. Normally as you know, the GA pilot can call FSS and inquire as to activity, but doubt that gets handed to you.
MTRs as you said yourself, are depicted, but are often not used, so whereas it might be possible to see Mil activity, on many, odds are higher hat you would be struck be lightning.
As for your sailboat racing analogy, not sure it applies, certainly no one would fly an airplane through the path of say a tanker dragging fast movers. Futher, a sailboat race is in a relatively defined area and I doubt you would avoid sailing, if the around the world race was going on. Some of the MOA's are so big, that the odds of running into a fast mover is akin to your boat being hit by a tanker in the Atlantic on any given day.
I have spent a fair amount of time out west, in and around MOAs flying puddlejumpers and honestly I cannot say, that I ever saw a fast mover. Were they there, probably, did one ever have to maneuver to avoid me, doubtful.
Bjammin,
You do realize that tankers do drag fast-movers through moa's (although normally high enough to be no factor). . . . ? That is the danger as uninformed ga pilots (I am one too) we dont know whether we're dealing with a 2 ship goofing off lazily or some LFE involving many many manuevering aircraft. .
Oh and B-jammin. I have called controlling agency of a moa. In fact last friday i did (its easy when you have an AP-1B in your civvy flight bag though). .
Not really, especially for light aircraft when the MTR crosses your route of flight. You've got to overfly the route. The analogy might be better compared to crossing train tracks, but without any form of warning. You can't just stay on one side of the tracks forever. The rule for military and civillian aside, like it or not is see and avoid...and it's not just a good idea. It's the law.
Even in instrument conditions.
When I lived in Kansas and sprayed (crop dusted) full time, we had a B-1 route that cut through our operating area. Not uncommonly we'd be spraying a field, far from any MOA, and a B-1 or other aircraft would come blowing through at low level...sometimes as we might be pulling up out of a field from a low altitude spray run. I kept a very sharp lookout for traffic all the time, especially any time I had to climb above 5'. I doubt the Lancer pilots would have spotted me, but the main thing is that we were both looking.
I can tell you I certainly was. Furthermore, simply because someone elected to put an oil burner route through my working area doesn't mean that I'm going to fold up and go out of business.
It's a matter of staying heads up and everybody working to share the same airspace. There's only so much to go around, and MTR or MOA, it's nobody's domain. Everybody's got to learn to share.
avbug says
Truer words were never spoken. Flying the RF-4 on MTRs in Alabama and Mississippi, two of the lesser populous states, I can recall a couple times we came close to Cessnas and can't tell you how many times we saw cropdusters. They were bright yellow and we were trained to clear for aircraft so we'd usually see them well before getting too close. Still, there'd always be the potential for one to pop up from behind a treeline. In the heavy ag areas during spray season we'd often climb up to 500' to further ensure clearance.
Only MOA encounter was with a Mooney. We were doing a two ship pop-up attack in line abreast formation. When we popped up the other WSO and I saw a white Mooney with a blue stripe. Probably startled him a lot more than it did me, to have a very fast jet suddenly come up out of the woods and fill up his windscreeen. Oh well, that was the risk he was taking.
When I was a FAA Inspector many years ago we had an ongoing problem of military aircraft straying off of a low-level route in our district. One time a B-52 flew through the traffic pattern of a very busy GA airport with a pattern full of students from a university flight school. The airport was 12 miles from the edge of the low level route. Several near misses occured and one Tomahawk on base leg was inverted by the vortices. Luckily that one had an instructor onboard and didn't crash. We got no cooperation from the AF commander, not even a promise that they would look into the issue. Their attitude was that they were saving us from communism and we should be grateful and stay out of the way. I was pretty fresh out of military aviation and I was embarrassed by the attitude on display. We finally violated the the B-52 crew for failure to give way to an aircraft being overtaken. The AF refused to divulge any action taken against the crew and I doubt that there was any. Eventually we got frustrated and managed to go through channels and get the Senate Armed Services Committee interested. That led to the current agreement that military services will respond to the FAA Administrator about actions taken to resolve a FAA violation. I suppose navigation has improved somewhat with all the gee-whiz stuff we have nowadays.
sounds like some of the MIL attitudes on this thread... lucky for all there are cooler heads in the USAF/USN..... and the Senate Armed Services Committee.
Its good we live in a democracy. Places like commie China, the MIL stonewall public safety....
message deleted
You commented on it so you must care on some level. Or it could be you're just another Navy pilot who spouts sh*t like he knows what he's talking about, which usually isn't the case. Sort of like thinking we still wear ascots. Kinda like y'all wear golf shirts under your flight suits.
What's the answer?
He's a Marine, and a RAG student, so don't pay attention. He's got no operational experience, and thus no real argument in this thing.
Answer to how close MC-130's go lead-trail at night in the moutains on gogs? Way fugging closer than I want to be. Watched a multi ship of those guys in a valley in Afghanistan, from WAY up high. Yeesh.
If you read back a couple posts from my first I was actually mocking the MC-130 guy that was AGAINST what you all were saying. But I digress.
It's all good here. We're on the same team, including Deuce. I know him well, and we had a fairly heated discussion about this thread. He convinced me he was actually correct in what he was saying, but he does agree the civvie guys were dumba**es. I jumped to his defense on a few things, simply because I know alot about what he does and what he did in OEF and OIF. In the future, you probably shouldn't try to mock guys that have more night combat time below 1000' AGL than you have total time, no matter what they fly.
SIG, thank you for being the voice of reason and rising above the petty rivalries here. And for continuing to say Dave Griffin is an a** every chance you get.
SNA, best of luck in the RAG and over the next couple years. They will be, without question, some of the best and most challenging years of your life. Enjoy it!
