Hold West
JAFO
- Mar 22, 2006
A squadron is not the controlling agency. "SeaLord," or "Clover Control" or "Nellis Range Control" is not a squadron.
Each MTR and piece of special use airspace has one organization that "owns" it, usually a squadron or a wing - different from and not to be confused with the "controlling agency". Any military folks that want to use one have to coordinate with the owner, that's how basic deconfliction of the airspace works. The problem is that very few civilians have access to the AP/1B that says who owns what and give the point of contact.
However, for the civillian pilot wishing to transit a MOA will not necessarily get reliable information from ATC, and may be unable to contact the range or MOA agency, and the MOA may be overseen by civillian ATC until it's active. ATC may not know, and typically does not know when it's going to be active, until it goes active. Part time MOAs may also go active off-hours.
Civil ATC absolutely does know when MOAs are scheduled hot, since ATC has to separate from them! ATC may not know if aircraft are in a given area or not at the exact moment, but they DO know the times and altitudes the MOA is scheduled.
It takes less than 30 seconds, but ATC can only tell the pilot if it's not active now...and may not even know that. ATC can't say what will happen thirty seconds from now.
A MOA can't go hot on a second's notice, since ATC has to have time to clear non-participating IFR traffic out of the area. In fact, IIRC, there's a time limit on how far in advance an MOA must be NOTAMed, I think it's at least one hour, maybe two. Can't look it up, the appropriate FAA order, 7610.4, has sensitive information in it and had been taken off the web.
So there is no such thing as a no-notice activation of a MOA. Now, that's not to say that a MOA can't be scheduled for an 8-hour block, and only occupied intermittently by aircraft. That ATC won't know about, and can either be handled by blocking the airspace for the full period OR blocking it on request of the using agency or directly by the aircraft going into it. In either case the NOTAM still stands; I've told countless VFR aircraft that an MOA had no known aircraft in it at the moment, but that it was NOTAMed hot and thus the fighters could show up at any second.
I wouldn't go through an active MOA for all the tea in China [Edit: unless it was being worked by an MRU and I could raise them on the radio and coordinate transit with them!]. Others are blissfully ignorant or don't care. You can't legislate stupidity out of existence.
By the way, there is a pretty good SUA website:
http://sua.faa.gov/sua/Welcome.do
It'll let you know what's scheduled.
