Informal poll for the IR's: do you fly single piston in IMC?
Do you fly Singe Engine's Into Hard IMC
  • Yes, frequently, sometimes (or often) with passengers.
    Votes: 89 35.9%
  • Yes, frequently, but never with passengers.
    Votes: 11 4.4%
  • Yes, but only in Turbine Powered Singles
    Votes: 6 2.4%
  • Occasionally, but I generally try to avoid it.
    Votes: 76 30.6%
  • Only if I absolutely have to.
    Votes: 35 14.1%
  • No frickin' way!
    Votes: 31 12.5%
  • Total voters
    248
I agree. I have a little over 100 hours of actual instrument in single-engine turbines, but I don't do that anymore.
It's all a risk management process and it's more risk than I am willing to accept.
I use sports psychology and positive imagery in much of what I do - forming a positive mental image of the desired outcome of the activity I'm engaged in. It just doesn't work in this case. I just keep seeing myself with no seat, in an engine-out glide in the clouds wondering what I'm going to see when I break out, if I break out, and all the while thinking what an incredible idiot I am.
GV
My sentiments exactly (emphasis added).
SS
I would never consider filing into hard IMC in my SkyHawk SP even though it is equipped with the Garmin G1000 NAV III glass cockpit.
My instrument qualification is for the time when I inadvertently encounter a JFK, Jr. type situation or when I need to fly VFR-on-Top.
_SkyGirl_
So far it looks like about 63% of respondents are in the generally try to avoid it, only if I absolutely have to or No frickin' way camps.
this past wed, thu & fri
single pilot, single engine imc.
1st leg's @ night. thu & fri w/ice
departure, destination & alternate @ mins.
a/c has 2 alternators, 2 vac pumps, full anti-ice and 1 engine :) and when i take off, i feel great because i love to fly.. im not a seasoned vet yet, but i have more than a 'little' experience (take it for what its worth)
i try to minimize as much risks as possible, but when push comes to shove, 1 engine is one engine... i dont think having an engine failure in imc will kill me, i believe when the man upstairs pulls my card, that will be when it is my time to go..
minimize risks that whats its about.. and the more we do it, the safer we will all be..
i could have hurt myself the other day.. i could have minimized my risk for this flight by not accepting an a/c out of maint that had 'stiff' pitch control.... i didnt believe it would be a problem, but it was.. (imc)
i chose to depart, but i should not have accepted the a/c. it was my decision which was a bad one... so on this flight i accepted some risk which turned out to be a bad move...
luckily everything turned out ok, and i learned a valuable lesson from this experience.
minimize risk + experience = longer life
a/c has 2 alternators, 2 vac pumps and 1 engine :)
That sounds like the opening statement in an accident investigation. ;)
LS
Why not night VMC? I can understand not wanting to fly a piston single in night IMC, but night VMC when done correctly is pretty safe.
Reading between the lines, you have never lost an engine at night (which is GOOD!) But I can assure you that you would feel differently had this ever happened to you personally. If you lose an engine--your only engine--at night, are you prepared to deal with it? Think deeply about this. Maybe you are. Maybe you aren't. It's difficult to say whether you are or not until you are actually faced with the situation. Only then does the truth of how you really feel about it come out of your bones.
A common hazardous attitude recognized by the FAA is "It can't happen to me." Engine failures or fuel exhaustion happen all the time in GA. Remember that this sort of event doesn't know and doesn't care whether it's day, night, 500 and 2 or, 50000 and 100. It can (and does) happen anytime.
Keep in mind that I never said that it couldn't happen to me. It certainly could, and I had a scare a couple weeks back with a misfiring engine at altitude during a night XC. Definitely learned something from that, and the thought of having to put down at night was very real in my mind at that point (maintenance said it was temporary fouling, but d*mn if that doesn't get your attention!).
But, does that mean that I'm going to quit flying night VMC in a single-engine airplane? No, not at all. It simply means that I'll ensure that I take more precaution in where I fly, and make sure to stick to it. :)
I'm not trying to be argumentative here; but just what precautions does one take to make night SE XC flying safe? I'd like to hear everyone's answers and reasoning.
LS
Depending on where you do most of your flying, finding a suitable place to make a forced landing during daylight--even on the clearest of days--can be a serious undertaking (e.g., the hilly, forested terrain in the less-inhabited parts of the PNW). I can assure you that it doesn't get any easier at night.
If you insist on flying your Skyhawk at night, rule number one should be to never, ever fly beyond gliding distance of an airport (with lights), ever. In some places, airports are sparse enough that they would require an altitude greater than the airplane's service ceiling to satisfy the aforementioned rule. Otherwise, your options are slim.
Where I do most of my flying, ditching in the water along the shoreline of Puget Sound is about as good as it gets for night forced landings if you are outside gliding range of an airport. Swimming off shore in my jeans after dark, choking on avgas in the water isn't my idea of a good time, and I don't ever intend to schedule it into my evening plans.
Evidently you haven't heard of the off-airport night landing method that I was taught...
When you lose your engine at night over unknown terrain you turn off all of your lights until just prior to impact. At that point, you turn on your landing lights. If you like what you see, leave them on. If you don't like what you see you simply turn them off. No one has ever provided me with a better solution to the problem.
LS
Well, I don't insist on flying my Skyhawk at night. They insist that I fly their Skyhawk at night. :D
Really, it's just like the FEX guys. I don't have much of a choice in the matter a good bit of the time, and even then, some units need to be completed at night (night XC training for my Private student). I know that's a cop-out reasoning, but in order to not be flying SE pistons at night, I'd have to quit my job. I'd quit if I felt that my safety was in jeopardy, but we fly SE pistons every night and not one has gone down in the years we've been doing it due to a mechanical problem. I trust maintenance here quite a bit, and I'm very familiar with the terrain on any of the XC routes I teach on.
i mean really are you serious..!!! you do know driving is more dangerous than flying.. so in that case why don't you walk to work..
LS
yes, ive heard of this method! works well
Actually, the stats indicate that you are 7-8 times more likely to have a fatal accident flying in a small GA airplane than you are driving/riding in a car.
It's the professional air carriers that have the better safety record.
Sometimes I do walk to work. :)
Where did you get those stats?
