Lead Sled
Sitt'n on the throne...
- Apr 1, 2004
Huh? I guess that means that the 5,000+ flight plans that I filed through DUATS via Flitesoft didn't work??? Man that's bad. I guess I'm going to have to call someone up at the FAA and apologise for something.gkrangers said:He told me filing thru DUATS just doesn't work...
Here's the drill...
(Vector4fun correct me if I'm wrong...) If you file via DUATS, it's held in their computer until 2 hours prior to your proposed time of departure; then it is sent to the ARTCC computer. 30 minutes prior to your departure time it is sent to the local controller (Clearance Delivery, etc.) awaiting your call. It is available there for two hours before it is dumped. Flight service never sees it unless you call them for your clearance and they won't know if it was actually filed or not.
By the way, I'm not kidding about having filed over 5,000 flight plans through DUATS and I can count on 1 hand the number of times that it wasn't there. For all intents and purposes, it's nearly flawless. If you guys are having the problems you claim to be having you're doing something wrong or...
