Thank goodness they let you input the times in local format.TDTURBO said:Out of the 300+ times I have filed thru DUATS, I only had one that was dropped. It was my fault, I screwed up the time of departure while converting it to Zulu. That time change twice a year always gets me.
How can you check online if your flight plan is in the system?
We knew you could do it.gkrangers said:Just filed with DUATS..and its there! Yay!
I'd just like to thank everyone at Flightinfo for helping me achieve this stupendous....achievement!Lead Sled said:We knew you could do it.
Lead Sled said:(Vector4fun correct me if I'm wrong...) If you file via DUATS, it's held in their computer until 2 hours prior to your proposed time of departure; then it is sent to the ARTCC computer. 30 minutes prior to your departure time it is sent to the local controller (Clearance Delivery, etc.) awaiting your call. It is available there for two hours before it is dumped. Flight service never sees it unless you call them for your clearance and they won't know if it was actually filed or not.
TDTURBO said:How can you check online if your flight plan is in the system?
gkrangers said:Heres one...How can I verify that its on file?
I think FBOWeb is like $15/month. FltPlan.com also has a flight tracker service.puddlejumper said:My company subscribes to a flight tracker service, FBOWeb.com. When I file, 2 hours before the proposed time off, I get a text message on my phone. Your FBO may have a subscription, ask them if you can look at their list of proposed flights off. If you file with DUATS, it will definitely be there. 09-27-2005 13:02
