Here are the TEC routes for California. http://www.laartcc.org/tec/index.phpmidlifeflyer said:"Tower Enroute Control" routes are very common in the northeast and California where approach facilities abut each other and cover a wide area.
You can go pretty far outside the "local" area and never speak with a Center controller as you are handed off from approach facility to approach facility. For example, there a TEC Route listed going from the BDL area in Connecticut down to Richmond VA, a 340 NM flight.
As has been already mentioned, in some areas, you don't even need to file ahead of time. In others you do. Either way, the A/FD and Jepp enroute information lists them in the same way as IFR preferred routes.
Do these actually work? From what I can tell this is a flight-simmers site.Here are the TEC routes for California. http://www.laartcc.org/tec/index.php
I file them by Route ID (ie SANM32) and we are normally cleared "as filed". Again, read the routings, way too complicated for use in high density airspace. It would simplify things greatly if they could simply insert a few named intersections where the airways intersect.
'Sled
This site is NOT affiliated with the FAA, the real Los Angeles ARTCC or any of the Airlines listed. The information contained in this site should NOT be used for real world navigation.
Thanks....so in a way, its kinda like getting a local IFR but you can go outside the first TRACON? Will ATC provide the turns, or will you be expected to follow the TEC routing, just like if you filed a normal IFR plan with airways?midlifeflyer said:"Tower Enroute Control" routes are very common in the northeast and California where approach facilities abut each other and cover a wide area.
Both. It's really more like, actually, =exactly= like IFR Preferred Routes, except entirely in approach control airspace.gkrangers said:Thanks....so in a way, its kinda like getting a local IFR but you can go outside the first TRACON? Will ATC provide the turns, or will you be expected to follow the TEC routing, just like if you filed a normal IFR plan with airways?
Depending on where you trained, that's not that surprising. First, unfortunately, not a lot of time is spent in instrument training on enroute stuff to begin with - the checkride is so approach intensive. Second, even if you touched on IFR Preferred Routing, you probably didn't spend a lot of time on it since those city pairs tend to be for the "big boys." Third, instrument training tends to be localized. If you didn't train in the parts of the country that use them, you probably wouldn't be exposed to them (I did my instrument training in New England where they are used). Look at the number of folks who train at towered airports and haven't a clue what a "void time" clearance is or, if they know what it is, have a clue how to get and use one.I don't remember going over it down here during my training.
gkrangers said:Just filed with DUATS...called FSS an hour later and they never got it. FSS guy told me DUATS blows.
I filed with DUATS...then I checked DUATS a half hour later to see if it was on file, it wasn't.. Then I called FSS to ask if the plan was on file, it wasn't. He told me filing thru DUATS just doesn't work...minitour said:You filed with DUATS and called FSS to get your clearance?
If so, you have to tell them you filed it with ___ Center. It's (most likely) in the computer. They'll probably give you a hard time, but its there.
OTOH...if they checked and its not in the computer...then my fears are justified.
The last thing I ever want to have happen is be on the ramp with the engines running, looking for an IFR to ORD with an arrival slot and I need to leave now to make it and..."sorry sir, there's nothing here".
That would suck....
-mini
gkrangers said:I filed with DUATS...then I checked DUATS a half hour later to see if it was on file, it wasn't.. Then I called FSS to ask if the plan was on file, it wasn't. He told me filing thru DUATS just doesn't work...
No, he asked for my departure time and checked something based on that, maybe he was checking the center computer then?minitour said:That's gotta suck...did you ask them to check the Center computer?
-mini
gkrangers said:No, he asked for my departure time and checked something based on that, maybe he was checking the center computer then?
I'll try it again next time.
But, this IFR stuff is cool.
Filed both ways today, its great!![]()
:werd: I like FSS...also feel like I'm more on record of getting a briefing if something goes wrong...that stuff gets recorded doesn't it?Pedro said:I like using the FSS too, I feela lot better when I caan taalk to somebody and get all the NOTAMs.
