Mini...minitour said:I've done the electronic filing a few times. I always get worried my flight plan is going to get lost and I'll be stuck on a ramp trying to phone FSS from my cell to file. But that is a good option with the electronic programs.
...I so agree with the time spent calculating. Usually when you do that, you get two clearances before you depart, one or two right after takeoff, then two or three enroute before getting direct as soon as you can possibly get the destination to ID (assuming no GPS)...what a PITA.
Lead Sled said:FWIW, I don't know if I'd let a student use any of those programs during his training. Manually planing the flights tends to ingrain the concepts involved - there will be plenty of time to use all of the shortcuts and aids later.
'Sled
'Sled
Psychos for the Ethical Treatment of Animals....Fly_Chick said:What is a PITA?
Lead Sled said:And Mini, yes, I can tell you the time and fuel burned and the fuel remaining between any two points on our flight plan. Although we seldom file or fly airways (95% of our flying is direct), we do have VOR/DME based waypoints along our entire routes at roughly 150 NM mile (20 minute) intervals to back up our great circle based direct routing.
'Sled
This has been one of my pet peeves for years. The first thing I do when I'm going to be doing a lot of flying into / out of a new area is to give the local controllers a phone call and find out what the local prefered routings are - it really cuts the time it takes to "become fluent" with the new area. As long as I'm talking pet peeves, Take a look at the local preferred routings here in Southern California. Why is the FAA still defining pref routings with airway to airway interceptions or VOR radial to VOR radials? There is such a high percentage of FMS/GPS/Loran equipped aircraft out there, this would certainly end a lot of cockpit confusion and heads down time in high density areas if they would use named intersections instead. I also love it when they tell you to fly the AAA VOR XXX degree radial to BBBBB intersection. That's the long way to say, "AAA Vor direct BBBBB intersection" - again it overly complicates what would otherwise be a simple task.Vector4fun said:The FAA is also at fault for not publishing more pref routings. We have to use them because of LOAs between facilities, but they're not published where pilots and dispatch can find them.
Lead Sled said:(Are you sure you're not my wife?)
'Sled
I did something similar last year. We took a vacation trip to Florida last year and decided to rent an airplane and visit friends and family. Figured most of the flying would be VFR, but planned at least one of the them to be IFR. I sent an email to Miami Center and asked what I could expect for a routing. They replied within 24 hours and the route I filed was exactly the route I got.Lead Sled said:This has been one of my pet peeves for years. The first thing I do when I'm going to be doing a lot of flying into / out of a new area is to give the local controllers a phone call and find out what the local preferred routings are
minitour said:Do you actually file a flight plan for TEC or just ask for Tower Enroute from ground/clearance?
IOW: I'm on the ground at BKL to go home (YNG). Do I have to file with FSS, or do I just ask Ground "Ground N123 Tower Enroute to YNG with Lima"?
I always wondered but forgot to ask.
Thanks for da help!
-mini
I don't even know what TEC stands for...but ti doesn't sound different. On a short flight you'll be at a lower altitude and likely stay within the terminal airspace....on a longer flight, you'll be higher, and get above the terminal airspace into center...GotBoost? said:My understanding is that TEC is just getting the handoff direct from YNG-CAK-MFD approach without ever talking to center, not any difference with how the route is filed. I've flown from the CAK area to BOS area a few times routing thru ELM-BGM-ALB, and I've noticed that flying at 060-080 I talk to approach at each terminal area, but the one time I got up to 110 to get on top & ride some good tailwinds, I was on with Cleveland & Boston centers much more. Just my observations based on my miniscule experience.
One of my CFIs showed me the fltplan.com site while I was working on my IFR. He'd have me do the planning manually & then run it on fltplan to compare times & whatnot. I've been using them to file as well, and so far between fltplan DUAT & FSS its the only method that hasn't lost a plan of mine (yet).
gkrangers said:Heres another question...under what environment can a "local ifr" be used? Does the flight have to stay within the TRACON it was requested in?
"Tower Enroute Control" routes are very common in the northeast and California where approach facilities abut each other and cover a wide area.gkrangers said:don't even know what TEC stands for...but ti doesn't sound different. On a short flight.
