Cl300
The CL300 is the first point design aircraft for the fractional market.
For comparison I'll include data for the Gulfstream G200 which is at a similar price point.
Challenger 300 / Gulfstream G200
Cabin dimensions: L 23'7" x H 6'1" x W 7'2"/ L 24'5" x H 6'3" x W 7'2"
Max. T/O Wt: 38,850 lbs / 35,450 lbs
Max. Ldg. Wt: 33,750 / 30,000 lbs
Max Zero Fuel Wt: 27,000 lbs / 24,000 lbs
Max. Fuel: 14,045 lbs / 15,000 lbs
Max Payload: 2,800 lbs / 3,800 lbs
Max Payload Full Fuel: 755 lbs / 400 lbs
Engines: Honeywell HTF7000 6,826 lbs thrust / Pratt & Whitney 306A 6,040 lbs thrust
TBO: On condition / 6,000 hours
Normal Cruise (Mach): 0.80 / 0.80
Long Range Cruise (Mach): 0.75 / 0.75
Mmo (Mach): 0.83 / 0.85
Range @ Normal Cruise: 3,250 nm / 3,050 nm
(4 pax, ISA, NBAA Res.)
Range@ LRC: 3,317 nm / 3,400 nm
T/O Dist (SL, ISA, MTOW): 4,840 ft. / 6,080 ft.
Landing Dist. (SL, ISA, MLW): 2,610 ft / 3,280 ft.
Initial Alt: FL410 / FL390
Max. Alt: FL450 / FL450
Direct Operating Cost per Hour: $1,638 / $1,702
GV
