Question Fuel pressure fluctuations in flight (fuel pump off)
Found it. Attached.
Has anyone ever found any significant contamination in the Andair filter?
I have never found any and don't see how it is possible if the gascolator is clean.
I was wondering that, didn't want to ask. Risk of messing with the fuel system vs. findings in the filter. Probably not something I'm going to do as anything that can make the engine stop is not something I touch so it will be my local A&P to do.
From what I have heard, the gascolator screen catches the vast majority of contamination, and if the gascolator is clean during the 100 hr inspection, you can skip checking the Andair filter. However, as the Andair filter is finer than the gascolator, if you find anything in the gascolator, you should also check the Andair filter.
Personally, I have never found anything in the gascolator other than a couple of small drops of water, which I think are from condensation because I do not always refuel to full after every flight.
