From what I have heard, the gascolator screen catches the vast majority of contamination, and if the gascolator is clean during the 100 hr inspection, you can skip checking the Andair filter. However, as the Andair filter is finer than the gascolator, if you find anything in the gascolator, you should also check the Andair filter.Has anyone ever found any significant contamination in the Andair filter?
I have never found any and don't see how it is possible if the gascolator is clean.
Well, I emailed this address when you provided it. Nothing heard to date, sadly.I have exchanged several emails with Brandon Dildine at
Technicalsupportn (Lycoming)<[email protected]>
He has always been helpful and supportive. I do no know what discretion he may have on warranty claims.
The parts in the fuel pump that could fail are the diaphragm, the inlet valve, and the output valve. I doubt any of these would have failed at such a low time. I would expect contamination intermittently preventing sealing of the input valve.
Perhaps Lycoming will take an interest in this early failure and offer an exchange part. Send your data to Lycoming and ask for support.
I have a Lycoming IO-360 in my Carbon Cub FX-3. Fuel pressure is fluctuating around 22/22 mag pressure/rpm. Pressure is fluctuating between 25 and 29 psi. What could be the cause and is there cause for concern?
Short answer: a small oscillation like 25–29 psi at a steady power setting on a Lycoming IO-360 is often normal, but it depends on how fast and how consistently it’s fluctuating—and whether anything else (engine smoothness, fuel flow, EGTs) is moving with it.
Let’s break it down in practical terms.
What’s likely normal
On a fuel-injected Lycoming, especially in an experimental like the Carbon Cub FX-3:
A swing between 25–29 psi:
- Fuel pressure gauges (particularly electric senders) can hunt or oscillate slightly
- The engine-driven fuel pump pulses a bit by nature
- Some installations (especially with lightweight plumbing) show 2–5 psi variation
- Is within a typical operating range
- Isn’t automatically a problem if the engine is running smoothly
Common causes of fluctuation
1. Sensor or gauge behavior (most common)
- Electric fuel pressure transducers can:
- Drift
- Pick up electrical noise
- React to vibration
- If the engine is smooth but the number moves → this is your leading suspect
2. Engine-driven fuel pump pulsation
- Mechanical pumps don’t deliver perfectly steady pressure
- Some installations lack enough damping → visible fluctuation on the gauge
3. Fuel system damping / plumbing
- Lack of a snubber/restrictor fitting can make fluctuations more visible
- Light experimental aircraft are more prone to this
4. Slight vapor formation (less likely, but important)
- Especially if:
- Fuel is warm
- You’re at lower pressure / higher altitude
- Usually comes with other symptoms (roughness, flow variation)
5. Electric boost pump interaction
- If boost pump is on:
- It can “fight” the engine-driven pump slightly
- Cause pressure oscillation depending on system design
When to be concerned
This becomes worth digging into if you see any of the following:
- Pressure swings more than ~5–7 psi
- Fluctuations are rapid and erratic, not smooth
- You notice:
- Engine roughness
- EGT/CHT fluctuations
- Fuel flow instability
- Pressure drops below minimum spec for the IO-360
- Problem is new or getting worse
What I would do (practical next steps)
- Correlate with engine behavior
- Is it running perfectly smooth at 22"/2200?
- If yes → less urgent
- Check fuel flow and EGTs
- If those are steady → likely instrumentation
- Turn boost pump on/off (in a safe phase of flight)
- Does the fluctuation change?
- That tells you a lot about pump interaction
- Inspect the sender and wiring
- Common issue in experimentals
- Loose ground or aging transducer = fluctuating readings
- Ask yourself: has it always done this?
- If yes → likely normal for your installation
- If new → investigate
- At next maintenance
- Consider:
- Replacing the pressure sender
- Adding a restrictor/snubber if not present
Bottom line
- 25–29 psi fluctuation alone is not inherently dangerous
- If the engine is smooth and fuel flow is stable, this is very likely instrumentation or normal pump pulsation
- Still worth verifying—fuel system issues are not something to ignore—but this doesn’t immediately sound like an emergency
