G200
gunfyter said:
I hadn't really paid much attn but my understanding is that a great deal of the problems we Initially had with G200 had been ironed out by Gulfstream...
So it may be a better product now than when you looked at it.
I can't imagine Gulfstream would tolerate a poor product anymore than their buyers would.
I thought the 200 had poor reliability but the NJA pilot on here who flies them said they don't have that much trouble.
He probably came out of a Citation X.
I think you are probably right. We looked at several of the first when they where still green and in completion at Garrett Springfield. This is when you DON'T want to take too close a look at this airplane. A little too much bondo for my taste to make everything flush.
I do know for a fact that Gulfstream has done a LOT of work making it a better product. One of my best friends is an Aerodynamicist for Gulfstream and was tasked with getting the 200+ mile loss of range back that it lost during its inevitable weight gain.
It's some of the certification issues (like boots) that can't easily be worked out that will always haunt the aircraft.
We parked next to one in Hawaii a couple of years ago, spent about an hour talking with the crew, looking at each others rides. Just compare the wing side by side, its no wonder it staggers around at F370 and above when it gets warm.
I hate to knock the plane too much, it has its place. Alot of what you experience first and second hand builds up after 5 years. You don't hear a lot of good along with a lot of bad, and finally you decide there are better ways to go.
I stayed in the X. I just talk to people.
Some who I talked to are Gulfstream mechanics, who work on all our types of airplanes. One told me how much they loved the Falcon 2000 when I mentioned I might go to the G200 or the DA2000. Said it was her favorite airplane.
The pilots I talk to who fly the G200 have told me the BOOTS are not an issue to them. The boots are automatic and only come on momentarily... so not pulling power away from thrust constantly like my heated wings.
As far as passengers like NJOwner, whats not to like about the cabin? Also fractional owners can switch to different types when a G200 might not be what you want to take.
Hey gunfyter, did you fly the Cobra?
We have a local guy that came into some money, bought and restored 4 Hueys and a Cobra to like new. He just got his rating in the Huey and checked out in the Cobra.
I was in the pattern in the RV4 the other day going round and round with the Cobra. Pretty cool.
As many have said, the G200 is a great airplane. We all know about the problems it had, these have been corrected and are a non issue. Gulfstream is sold out to 1st quarter 2007, they have turned around the aircraft just as they promised they would. I think to compare it to the 2000EX is a stretch, compare that to a GIV to be accurate and then its no comparison. Not to take anything away from the Falcon its an amazing aircraft as well. Ultimately what I'm saying is if anyone is basing decisions on the G200 from information over 1 year old it would be in your best interest to take another look. On the flip-side, Yes the wing is small...you know it, I know it, Gulfstream knows it. IAI thought they would save a few bucks and extend the Astra wing a few feet and avoid a costly redesign, bad move in my opinion. To be positive though that wing is a dream in turbulence.
Which is a plus considering that there is more of it in the 30's where the beast is stuck. It is definitely the UGLIEST jet on the market. And what is it with the gear doors hanging out at "acceptable" distances from the fuselage?
ultrarunner said:
What is the initial cruising altitude at higher weights?
FL 350-370
The airplane has a lot of T/R issues at the moment. Gulfstream has been very receptive to all that we ask of them with this airplane, we are afterall, the biggest buyer of this plane. So, they are anxious to resolve our T/R problems.
HD
Hawk Driver said:
FL 350-370
HD
That's odd. We have no issues on the LR60. I can't imagine the TR's and their systems are much different on the 200.
GVFlyer made this post in the Corporate section. The G200 specifications are in the right column.
GVFlyer said:
Cl300
The CL300 is the first point design aircraft for the fractional market.
For comparison I'll include data for the Gulfstream G200 which is at a similar price point.
Challenger 300 / Gulfstream G200
Cabin dimensions: L 23'7" x H 6'1" x W 7'2"/ L 24'5" x H 6'3" x W 7'2"
Max. T/O Wt: 38,850 lbs / 35,450 lbs
Max. Ldg. Wt: 33,750 / 30,000 lbs
Max Zero Fuel Wt: 27,000 lbs / 24,000 lbs
Max. Fuel: 14,045 lbs / 15,000 lbs
Max Payload: 2,800 lbs / 3,800 lbs
Max Payload Full Fuel: 755 lbs / 400 lbs
Engines: Honeywell HTF7000 6,826 lbs thrust / Pratt & Whitney 306A 6,040 lbs thrust
TBO: On condition / 6,000 hours
Normal Cruise (Mach): 0.80 / 0.80
Long Range Cruise (Mach): 0.75 / 0.75
Mmo (Mach): 0.83 / 0.85
Range @ Normal Cruise: 3,250 nm / 3,050 nm
(4 pax, ISA, NBAA Res.)
Range@ LRC: 3,317 nm / 3,400 nm
T/O Dist (SL, ISA, MTOW): 4,840 ft. / 6,080 ft.
Landing Dist. (SL, ISA, MLW): 2,610 ft / 3,280 ft.
Initial Alt: FL410 / FL390
Max. Alt: FL450 / FL450
Direct Operating Cost per Hour: $1,638 / $1,702
GV
All the T/R's at Netjets are made by the same company, I won't mention them for fear of reprisal. We had some issues in the Ultra with them as well and now we are having similar issues in the G200. The company that makes them are very interested in getting the issues resolved, seems there is a lot riding on them fixing the problem.
HD
Payload for alot of 300s is more like 3200 lbs. Roughly 23.8k BOW. Most of the other stuff looks about right.
The T/O and landing performance helps on high and hot days.
Thanks, I use typical completion weights for performance unless stated otherwise. For instance, spec. operating weight for the Gulfstream G550 is 48,300 lbs (which is slightly more than the one I fly weighs) but some customers go for all the techno-luxo options while others want showers and bedrooms so the typical operating weight is 48,700 lbs (with a crew of four).
The typical operating weight for a Challenger 300 is 24,200 lbs which means some will weigh more, some will weigh less.
It's a good looking aircraft at a nice price point, enjoy flying it.
GV
