RJPilott said:By the way, quick question for those that work at CASW. Was that the CASW hangar? If not, are you familiar with that hangar? Is it heated (looked like it had insulation on the door and walls)? And do they spray Glycol inside the hangar?
1 Probably the Hangar the FBO uses to put the aircraft in when it's snowing.
2 I'm not familiar with the hangar
3 Probably heated given that part of the world, we are required to preheat the engines, prior to starting below 30ºF, and to ensure the precontamination check is done within 5 minutes of departure. So if the aircraft has sat in the hangar and is clear of snow/ice/frost and it takes 4 minutes to taxi to the runway, and complete pretakeoff checks, then you could be good to go (FZRA, FZDZ excepted - operations in which are prohibited according to our manual)
4 Unlikely that they spray Glycol inside the heated hangar - think that would cause a possible fire risk (common sense), but then I'm no fireman.
I'll answer any question you have about our ops., but I'm not going to tolerate your unprofessional attitude - your airplane is bigger and faster than mine and your paycheck should be at least 3 times mine if you are an FO 5 times if you are CA, but I really don't care. What goes around comes around.
