Flexjet Response to NJA new offer:
There's nothing illegal about floating rest under Part 135. It's a gray area that pilots have wanted cleaned up for years, however the FAA has decided not to fix it...yet. To their credit they did clear it up under 91k, however Flex management was able to convince the POI to allow us to use 135 rules for all operations, even those under 91 and 91k. So, Flex pilots do not get called during rest, that would be illegal. However we do get called during that period after required rest is satisfied, but we are not on duty yet, and under the current 135 rules can still be counted as "rest" when looking back. Does it suck? Yes. Is it illegal? Not right now. Aren't they supposed to be re-writing 135 or something? How close are they to being done?
Wrong, wrong, wrong.......
You need to do some research before stating something like this. You might want to check out the faa legal council interpretations on this very subject. They are now available on the faa website.
Okay 400, in this age of cut-and-paste, why don't you just post it, or a link to it.
It appears that the legal interpretation part of the faa site is not working right now. This is a cut and paste from a pdf file that I have on the hard drive....
U.S. Department
of Transportation
Federal Aviation
Administration
800 Independence Ave., S.W.
Washington, D.C. 20591
In analyzing a pilot rest question, the first consideration is whether the rest period the
pilot received satisfies the requirement regarding the nature of a rest period, i.e., whether
the pilot received a period of time that complies with the three conditions the FAA finds
necessary to qualify as a rest period. The FAA has consistently stated through legal
interpretations that “rest” under the Federal Aviation Regulations is (1) a continuous
period of time; (2) determined prospectively; and (3) during which the crewmember is
free from all restraint by the certificate holder, including freedom from work or freedom
from present responsibility for work should the occasion arise.
See, e.g., Letter from
Donald P. Byrne, Assistant Chief Counsel, Regulations Division, to R.C McCormick
(June 25, 1996); Letter from Donald P. Byrne, Assistant Chief Counsel, Regulations
Division, to James W. Johnson (October 29,2002); and Letter from Donald P. Byrne,
Assistant Chief Counsel, Regulations Division, to James W. Johnson (May 9,2003)
(copies enclosed).
Under your fact pattern, the questions are whether repeated phone calls effectively
terminate the continuous period of time required for rest, and whether the flight
crewmember is free from all restraint by the air carrier. If, under your scenario, the pilot
is obligated to answer the ringing telephone, then the entire period that the pilot was
under such an obligation is not part of the “rest period” - even if the carrier does not call
the pilot once during that period (this often is referred to as reserve or standby duty).
See
Letter from Donald P. Byrne, Assistant Chief Counsel, Regulations Division, to James
W. Johnson (June 23,200O) and Letter from Donald P. Byrne, Assistant Chief Counsel,
Regulations Division, to James R. Knight II (December 9, 1999) (copies enclosed). If, on
the other hand, the pilot is not under any obligation to answer the telephone or to be
available to answer the telephone, the time up to the duty report time is considered a
“continuous” rest period. See Letter from Byrne to Johnson (October 29,2002) and
Letter from Byrne to Johnson (June 23,200O). It is the FAA’s policy, under the
commonly referred to “one phone call exception,” that a rest period is not viewed as
interrupted if the air carrier makes contact with the pilot one time by telephone, pager or
the like.’ Once the contact is made, it cannot, however, be made again without
interrupting the rest period.
To reemphasize - under no circumstances is a pilot obligated to answer the telephone if
the pilot is considered to be on rest.
It appears that some people overlook the voluntary
nature of receiving phone calls. Thus, if the pilot seeks to have an uninterrupted rest
’ period, the pilot certainly can take measures to prevent being contacted by the carrier,
e.g., if the pilot is staying at a hotel, the front desk can hold any incoming calls; or if the
pilot is at home, the telephone ringer can be turned off and an answering machine can
pick up calls. Further, a flight crewmember can provide written notification to the air
Note that the Federal Aviation Regulations do not explicitly allow “one phone call” from the carrier
during a pilot’s rest period. However, the FAA established the “one phone call” policy based on certain
narrow conditions and the fact patterns presented to us. Generally speaking, an air carrier can initiate a
phone call and a pilot can - on his or her own volition - receive one call from an air carrier without the
phone call being viewed as disruptive and,breaking the continuous rest period.
How about Online training that the company suggests we can complete while flying the line (in the hotel). If you're logged on and getting payed for it are you in rest?
The online training has to be completed 30 days prior to your long recurrent. They did not say that you must do it in your hotel while flying the line. When and how you do it is your choice. They merely stated that you will get paid the 4 hours to complete it.
Also, if so many pilots were not griping about having to be at training for 7 days on the long recurrent, we would not be doing this online training in the first place. A definite case of be careful what you wish for.
400pilot,
Your posting is great information for the masses. I just want to clarify one thing.
The section that I have cut and pasted from your quote is how Flexjet operates. The company can contact us one time. Those times are either 2 hours after off duty or 2 hours prior to duty. Typically it is 1700 local to 1900 local or 0300 to 0500 local.
The 2 hours prior is usually how we get contacted by the company due to changes. That is how they do it. Also, we are not required nor do we have to have our dingleberries on during our rest period.
Also, if we initiate the contact with the company and they respond, that is not an interuption of rest either.
I know plenty of Captains who turn off their phones.
Has it happened, yes I am sure it has. Does it happen all the time. No.
That being said, thank you for your posting because it was good reading.
CL300Pilot
Check out the airline profile for Citation shares and compare it to that of Flexjet. CS has about the same amount of pilots. The pay scale is similar. Yet they offer 25 domiciles and the 7&7 schedule. Ask yourself then why we cannot seem to achieve this at Flex?
Our management will not make any significant change of their own merrit. Why? Because they dont have to do anything. That's just business.
If we want to enjoy the Pay, QOL, Rest, and Domicile enhancements of our industry contemporaries then we must force it. As individuals our company will pick us off one by one. As a group we can make it happen, we need unity now more than ever.
Again, I am not a malcontent, I really like my job. The new numbers at NJA (if ratified) speak for themselves. We deserve the enhancements.
CL300,
It all depends on what the policy is. If your company requires you to be available and answer your phone, then it is not considered rest. However, in the example you provided, I see how the one phone call exception is being used. This post was more in response to the previous one about floating rest. Specifically,
and
