minitour said:But yeah, you're probably right...you probably shouldn't be PIC of an airplane with people in back if you haven't experienced icing...
-mini
Standby 1 said:That should read "if you haven't experienced icing in an aircraft that is certified to fly in known icing conditions."..
minitour said:Exactly!
I was trying to cover all the bases, thanks for picking that one up for me.
-mini
Standby 1 said:No need to cover any bases --- clearly you have a good deal of common sense and good judgement when it comes to ice and limitations of aircraft. I'm sure you'll get more than your fair share of icing conditions someday when you're hauling freight in some beat-up old Navajo or schlepping corporate customers around!
Did it not occur to you guys that there was a temp inversion???? +1 on the ground and +6 at 6000 msl???? With +1 at the surface what is the temp "supposed" to be at 6000'???apcooper said:I am merely suggesting that pilots be better trained in how to escape ice not fly in it! We train for an engine failure instrument failures, etc so shouldn't we know what to do in ice if ACCIDENTALLY encountered.
NJA Capt said:...Pilots DO receive training in icing procedures. It happens when you train in an APPROVED aircraft type....
vetteracer said:...That comes from you. Most companies will have a training session on Ice and T-storms and how it relates to their companies policy and how you should handle it. Then from experience and hanger talk with the "old salts" you figure out what to do, and what not to do.
Mark
Keep in mind the opinions on this thread have been about C172/182RGs that are not approved, as opposed to non-K aircraft that haven't had the training.minitour said:...how do you assure everyone gets icing procedure training in an aircraft that doesn't require an additional training/type rating?
Just curious... mini
