FAA Age 60 debate
Here is a great idea, let the ALPA pilots have it in their contracts that age 60 is the end of flying at that airline. And let the rest of the non-union world go about their business, flying charters, boxes, even people.
In the UK you can continue to fly after retirement age (which I believe is 60), however, in a heavy aircraft, you can no longer fly in the left seat. I am a fairly young pilot, and agree that an age 65 retirement would affect my upgrade time, and wallet width, however, I also agree that there is no data concluding that continuing to fly past 60 is dangerous. Now, having said that, I also think that there are a lot of regulations (tail-end ferry, and supplemental carrier reg's) that I believe are in much more need of a face lift.
And for the record, I bet more 3000 hour pilots who have nothing to list under ratings other than their cfi bust PC's in big jet's than 59 year olds who have flown everything from the mad dog to the 777.
That is an incorrect statement. The only restriction is that the F/O must be under age 60 if the Captain is over. Only one age 60+ pilot in the cockpit. France and Italy are the only two European countries that don't allow over age 60 pilots. My understanding is that due to EU laws that this will not be the case starting in October 2006. The following is from the year 2000.
http://www.publications.parliament.uk/pa/ld199900/ldhansrd/vo000201/text/00201w01.htm
Commercial Pilots: Age Limit
Lord Tebbit asked Her Majesty's Government:
  • What action they will take to protect the interests of British commercial pilots aged over 60 years currently prohibited from flying over or into France in command of public transport aircraft.[HL781]
Lord Macdonald of Tradeston: The Government have raised this matter both directly with the French authorities and within the Joint Aviation Authorities (JAA) and will continue to seek a resolution of the problem.
Under Council Regulation 3922/91 on the harmonisation of aviation technical standards, the national aviation authorities of member states are required to be members of the JAA. The Regulation also adopted some of the JAA's Joint Aviation Requirements (JARs) as the European Community's harmonised standard and established a procedure to adopt future JARs as the EC standard. Where a JAR has not yet been adopted under EC law, JAA member states implement them under national law and are obliged, under the JAA Arrangements, to use their best efforts to implement JARs by the due date.
Requirements affecting the age of pilots are contained in the Joint Aviation Requirements on Flight Crew Licensing (JAR-FCL), which was adopted by the JAA in 1996 with the implementation date of 1 July 1999.
JARs generally set standards that are compatible with those set by the International Civil Aviation Authority (ICAO) under the terms of the Chicago Convention, but can introduce differences, so long as member states notify the differences to ICAO. In drawing up the JAR-FCL, the JAA determined that commercial pilots can safely be licensed to the age of 65, provided that only one pilot in a multi-pilot aircraft may be over 60: this differs from the ICAO standard, under which a person can only act as a pilot in command if they are under 60. The UK and most other JAA member states are, or are in the process of, applying the JAR-FCL age limits. However, the 1 Feb 2000 : Column WA18
French authorities are continuing to apply the ICAO age limits within French airspace, although co-pilots up to the age of 65 are permitted. The French authorities have said that they are not opposed to a joint approach from the JAA member states to ICAO seeking a revision of the ICAO provisions in line with those in JAR-FCL, and we will pursue this with the JAA.
If the FAR 121 age limit is raised, there is no good reason to relegate the over-60 pilots to the right seat. The medical certification standards do not need to be tightened, as the limit as currently imposed was a corrupt act with no supporting medical data or study. I do realize that there WILL be an age limit.
It would be instructive to study the number or rates of both pilot deviations and pilot incapacition of over-60 pilots in professionally-flown corporate two-pilot aircraft, which operate in the same airspace, with similiar aircraft speeds, complexity, and pilot workloads, albeit often with only a Second Class medical certificate.
The medical standards should actually probably be relaxed. It's just airline flying; this is a sedentary job! There is no need for military-inspired superman or astronaut physicals. The creation of strict medical standards has probably rested on an assumption that the outcome is seriously in doubt if the PIC of a two-pilot airliner were to become incapacitated, and we all know that is not the case.
We shouldn't second guess those who choose to continue flying past 60, it is none of our business. One should not be forced to give up a well-paying job if one wants to keep it, as they are hard to come by, represent a lot of work and sacrifice. The desire of the young to bury their seniors is common, but is not a good reason to hold the age limit to 60 years.
At the top of a seniority list, the job can often be like a part-time job, so the refrain, "Get A Life!" by those wishing too retain the age-60 Rule rings hollow. They DO have a life.
Agree. Don’t need stricter medical standards.
Age 60 rule actually started in the mid-50’s as a risk study. Actuarial research and statistics were utilized in an attempt to answer the question: at what age are the odds of a pilot in a critical phase of flight becoming acutely incapacitated due to a cardiac condition approximately one in a million. Actuarials came up with 55-60. But tickers keep tickin’ and the real concern as we age has become cognition – aging of the squash. But this gets thoroughly and regularly tested in the sim so, as long as sim rides are passed, good to go from a brain perspective.
But in the end like many things it will be an economically-driven decision made by the folks in DC. Science will be irrelevant.
No, it does not.
Flying a checkride in the sim requires very little in the wage of cognitive ability. If you're been in the airplane for a while you know the maneuvers, you know the numbers that it takes to make the sim do the dance. There are few surprises.
Airliners don't crash because someone didn't hold the LOC within tolerance or couldn't hold altitude within 100' while rolling out with 10 degrees on a steep turn. The mistakes that lead to crashes are much more subtle and the key is the crew's inability to detect and correct their mistakes in time. There is nothing in the current system of recurrent training and checkrides which even attempts to quantify this type of cognitive ability.
LJ-ABX said:
No, it does not.... The mistakes that lead to crashes are much more subtle and the key is the crew's inability to detect and correct their mistakes in time...
Hmmmmm. This is interesting, had not considered. Was thinking of testing the ‘machinery’ itself, but you are referring to a still higher level of cognition. Any way to program/test this by sim/scenario?
Be interesting to see how this goes, seems from what have read there is a fair amount of pressure to change the 60 rule, from at least two lawmakers. Wonder what is their motivation, not clear. Also remarkable how sharply divided the ‘camps.’
Hello,
An earlier post (Tyro) eluded to the fact that this entire debate is not about science, it's about airline economics. This is what led to the age 60 rule in the first place. I'd recommend doing some further research on the topic and I think that most of will agree that the airlines simply want a way to be able to terminate legally the most highly paid and marginal employees (Marginal refers to their cost/benefit, not their skill level). Some of the most lauded airline executives of their time are to blame, along with one of the most obvious cases of government corruption and colusion. Now, nearly two generations later, the debate has re-emrged and it's would seem that many of the people that are debating aren't even aware of the history behind the original rule!
I'm behind any effort to extend the retirement age to when we are at least eligible for Medicare (age 62?). That would seem to be a reasonable compromise. I know that ALPA is trying to get legislation passed that would extend pilot's medical benefits through age 62. I think the airline industry will go with cheapest solution. I'm not sure what that is, but I think the bottom-line is going to rule.
Finally, I think that there is no substitute for experience in any field. Some of the top surgeons in this country are over 60 years old. Along with many industry and government leaders. Saying that one day someone is perfectly fine and fit to fly one day and the next day is not is ridiculous and defies logic.
Regards,
ex-Navy Rotorhead
Kaman makes an excellent point. Retirement. Not everyone will make the majors. If many of us are to be left in the regional carriers earning a salary that does not reasonably permit building an adequate retirement – what of the 60-65 ‘gap.’ Particularly as those same lawmakers are currently debating delaying the eligibility age further.
This dilemna should gin up a few wry jokes.
Alpa = 60
Again Kaman has hit the nail on the head, it was never about health or ability, it was about economics. Back to a previous post, let the ALPA carries have the age retirement in their contracts, since they voted that is what they like. Let the rest of us work for a living until we can retire. Put me back in the DC-9
I have flown with senior captains on the MD-11 lately. Four out of five were against raising the age 60 rule. What needs to change is how retirement is paid not the age 60 rule. Why would age 62/65/67 be any better? That is age discrimination too....It's all about retirement. Some senior guys are pretty smart about financial planning...others are not. Age 55 is not the time to build a million dollar home and mortgage $800,000!!! Then complain that you may not have a job in five years.
It was a great rule when you were 30/40 years old..it was a great rule when you were a junior captain...Now it is a great rule for folks that are in your shoes...20 years later.
The way I look at it is that if the age is increased to 65 it will give all of us time to have one more wife before retirement. That alone makes it worth it.:)
