Dual Engine Failure--Yeow!
Eagleflip
I gleaned this from the NTSB website, address noted below. Sorry if this is a duplicate, but I haven't seen it addressed on the board.
Any clues as to what happened?
http://www.ntsb.gov/ntsb/brief.asp?ev_id=20020612X00866&key=1
NTSB Identification: CHI02IA151
Scheduled 14 CFRPart 121 operation of Air Carrier SPIRIT AIRLINES INC.
Accident occurred Tuesday, June 04, 2002 at Wichita, KS
Aircraft:McDonnell Douglas MD-82, registration: N823NK
Injuries: 111 Uninjured.
This is preliminary information, subject to change, and may contain errors. Any errors in this report will be corrected when the final report has been completed.
On June 4, 2002, at 1238 central daylight time, a McDonnell Douglas MD-82, N823NK, operated as Spirit Airlines Flight 970, experienced a loss of power from both engines while in cruise flight at flight level 330. The power loss occurred about 20 nautical miles west of Wichita, Kansas. Power from both engines was restored and the airplane diverted to the Wichita Mid-Continent Airport, Wichita, Kansas, without further incident. The 14 CFR Part 121 scheduled passenger flight was operating on an instrument flight rules flight plan. No injuries to the 105 passengers or 6 crewmembers, were reported. The flight originated from the Denver International Airport, Denver, Colorado at 1140 and was en route to the Ft. Lauderdale/Hollywood International Airport, Ft. Lauderdale, Florida.
I wonder if there is an ATR code for soiled shorts?
I worked for a company that flew several types of large four engine airplanes. I was called to take over a crew position in an aircraft following loss of the crew. I didn't get any details, but learned on arrival that the crew was missing. Sure enough, when I got to the aircraft it had been cleaned out. This particular type of operation required the crew to be with the aircraft for extended periods, and all their things were gone. Nothing but dust.
I pieced together what had happened to them over the next few days. They had departed under IFR, and were between ten and twelve thousand feet when they experienced a rough engine on #3. They performed a precautionary shutdown and cage. Shortly thereafter, they developed fuel fluctualtions on #1, #2, and #4. Upon applying backup boost pressure, those engines quit, leaving them to begin an all-engine-out descent in IMC.
After 60 seconds without power, they restored power on one, two, and four, and continued to a safe landing. Within a day, both crewmembers had left and that was that. There was more involved, of course, and I don't think the captain would have quit over just that...it wasn't too big a deal. However, it came on the heels of the burning death of two close friends in a large airplane crash only a couple of weeks before, the birth of a new child, and during a fresh marriage...with heavy pressure from the wife to get out.
Sometimes there's a lot of wisdom in knowing just when to call it quits.
It's times like these, however, when things begin to go wrong and blood pressure rises just a little, that we're reminded of why we got into flying to begin with. With a little tension comes a welcome challenge and a change, and what was for a brief period routine, becomes fun again. It's all just a learning experience.
Probebly a elementary question, but does the MD-82 have a RAT for this very thing? Im know genous and no nothing about the MD-80 family, but if you don't have a RAT, then what altitude do you need to desend to so you can fire off the APU to help with the loss of power issue. I dought it would fire at FL330.
Be gentle, as I said I know nothing about the Mad Dog.
PA-31 dual engine failure
Any PA-31-350 pilots out there should read this.........
Go to www.atsb.gov.au
and search for a/c VH-MZK, it had a dual engine failure on May 31, 2000. A very good report with pictures and a MUST read for anybody flying Navajo's..............
Thanks for the link.
Who would have thought that proper leaning and antiseize compound would be associated with an engine failure? Is the copper based stuff still called "C5-A"?
I only know of one double engine failure that happened in the US on a Navajo. It was caused by a guy who violated his company's policy to remain with the plane during refueling. When he returned to the plane (after not looking closely at his fuel bill to see what he was paying for...) he took off with a load of Jet-A. He and the plane safely returned to the airport. About two months later, I had the pleasure of flying the same plane.
-With two brand spankin' new engines.
The MD-80 series does not have a Ram Air Turbine to provide emergency electrical power. The emergency power system is powered by the aircraft battery and powers flight instruments and avionics necessary for a safe diversion. The APU may be started at FL300 or below, sometimes well below depending on how cold soaked it is.
The pilot of a Navajo operated by a former employer found the aux tanks full when he preflighted, normal procedure was full mains and 15 ea. aux, thinking someone topped it off by mistake and ferrying to pick up 2 people he didn't see a problem with full tanks. Reaching cruise flight he switched to the aux tanks and very high CHT and engine roughness began soon thereafter, switched back to main tanks and engine operation returned to normal. The aux tanks had been topped off by mistake, with JET-A! Pilots of piston airplanes should be aware of the possibility of fuel contamination. An easy check for jet fuel is to take a strip of plain white paper and dip it in the fuel if it is avgas it will evaporate leaving no sign it was ever wet. If it is contaminated with even a small amount of jet it will appear oily and will never completely dry. Afer the above incident I did this test on every flight that I did not personally observe the fueling of the aircraft.
We had 3 pilots and 5 flight attendants riding as passengers on that flight. It sounds like a lot more went on inside the cabin than anyone wants to admit. Once it gets out it is going to be a tough go for Spirit.
I'll bet a lot went on in that cabin. I wouldn't exactly be Mr. Calm if it suddenly got dark and quiet in there...
Anybody know at what altitude they were when power was restored?
One of the F/A's that was a passenger on the airplane said that they glided to the runway,but that comes from one of our FA's.......... I haven't seen Steve the captain of the crew to see what he had to say. He said that he knew that they lost one for sure, so that means that power via the APU must have been restored. But this is all speculation. Keep in mind if the news media gets ahold of this one they will have a hay day. Something that will not be good for any of us.
I just wanted to say thanks for the Navajo informatin. As a former PA-31-350 pilot, I soak in all the information I can about them. My former employer required us to personally oversee refueling operations, but sometimes during a quickturn on a cargo drop-off it got done before you could see what truck it was. If I ever get employed as a charter pilot again :) I'm going to try the paper test. I'm surprised that something about the Spirit incident hasn't gotten out yet. I'm looking forward to hearing why that happened.
TurboS7 said:
.......... . He said that he knew that they lost one for sure, so that means that power via the APU must have been restored.
You know more than I about the incident, and I don't mean to be smart; but how do you come to that conclusion? I'm at a loss to understand how you could deduce that his certainty about one failure was based upon restoration of APU power.
About the APU, I don't have my manuals in front of me, but it would be possible to start the APU regardless of the state of the engines. If the engines are dead, the APU starter is disabled, but an airstart is possible. If normal A/C power is available (one engine gen turning) then the APU can be started with its starter. As the DC9Stick said, sometimes the APU doesn't really want to start when it is cold soaked and the air is thin; but after warmer/denser air is reached, it should windmill to a start.
8N
a note to my friends, No it wasn't me.
Hey TurboS7,
My best bud was the F/O on that flight, and your moron theory isn't anywhere near what happened. It sickens me that you are willing to scream pilot error, with your apparent lack of knowledge in this incident. Fact is they both did an incredible job of staying calm and safely landing the airplane in Wichita. There were heroics performed by those pilots that flight, not errors. Out of respect for my friend, I told him I would not indulge to anyone the specifics of the flight until the investigation is over, but I can assure you they did a great job in a situation most every pilot could classify as their worst nightmare.
Oh come on!!
Wow TurboS7... pretty brazen. Do you work for FoxNews or CNN? They are also amazing people, they like to pretend to know. Even when they know sh!t about nothing.
You're a dingus. I was flying that plane and I say it was my fault. I like to do deadstick landings every now and then.
Man this is one old thread that I inadvertantly awakened. I remember this on the news, I saw the aircraft at ICT. I was wondering if anything ever came of it and just what the heroics were (that were mentioned in the thread)?
Landing an MD 80(2) deadstick. Those guys *are* sierra hotel in my book, even if they may well have fouled up.
know of a guy who landed a T-38 dead stick. I've never been there, but AFAIK it has no alternate hydraulic power source. Supposedly he dove it keeping the engine windmilling supplying hydraulic power (from the engine) and got it down safely. Another guy I know tells how he once lost both on a Merlin in a storm, at night over moutains many years ago. Got them both relit. Good stories to swap over a beer at the hanger.
Dead Stick? Not the first time!
The odds of a double engine flame-out in cruise flight are low, but its happened plenty of times that I can think of. Most of these cases are pretty publicized, but the news media dosent like to pay attention to the ones that would make a professional pilot actually look like he was an asset in the cockpit during such an emergency. I can think of a 767 flying for a major airline that is affectionately known as the 'Maui Glider' and it has had 3 double engine flame-outs in its flying history with the company. Kinda scary when you think about it. Best advice I ever had was this; "the fuel panel will get you in more trouble, faster than anything else in the cockpit... so don't touch it unless you HAVE to." And this is true, most engine flame-outs are attributed to fuel system errors or pilot error in manipulating that system.
Since someone brought up this almost dead thread, I'll add a little for those wondering. The crew did relight both engines, they didn't land dead stick. The incident was turned over to the ASAP program and all info is confidential because of the rules of the program. That's all we know. It could have been anything. I can't speculate. I'm just glad that it wasn't me.
regards,
enigma
I recently spoke with a 10,000-hour DC-9/MD-80 guy about this incident. Apparently there are only a couple of things that could cause a double engine failure at cruise in good weather in an MD-80: not turning the center tank pumps on after takeoff, or a failure of some sort in the fuel system.
The center tank issue has come up before lots of times, but people usually catch it before they run the wing tanks dry. As for a failure of the fuel system, wouldn't that have prevented them from relighting the engines?
I'll be interested to see what the outcome is.
(By the way, for all you CRJ pilots out there, a little trivia: the MD-80's APU cannot be bled to the packs--or anything else--in flight. It's an airplane limitation...and besides, when you try to do it, the APU shuts down. Glad we don't have that limitation!)
I don't have time to do further research in the NTSB journals, even if I did, I would be well advised to keep my mouth shut. I will say that there are more than two ways to lose both engines, and that's assuming that both engines were lost. I really don't know. Like I said earlier, the pilots told their story to the ASAP team and it's all confidential. The report that the ASAP team published didn't even tell the whole story. I hope that someone hear can do the research of public information, find an answer, then post their findings. I'd like to know the truth. I only know speculation, and I'm not about to repeat any of it. I know that some in Hollywood say that any publicity is good publicity, but I'm not sure that applies to Spirit.
regards,
enigma
BTW, If memory serves, ASAP stands for Aviation Safety Action Program, and it's basically a NASA program run jointly by the company and the POI. It has good points and bad points, but that probably warrants another string.
So I guess the answer is that they no longer work for Spirit?
BTW Didn't Spirit also manage to stall one (airplane) in cruise, a few years back?
I wasn't going to mention it, but yeah. An MD-80 way up in the flight levels. Not sure if it was a high- or low-speed stall. The kicker is that after they fell out of the sky and recovered, they climbed right back up where they'd been and stalled again.
Now I'm not the brightest jet-jockey in the world, but I think after the first stall I'd have gotten the message.
Note: I don't want to come down too hard on Spirit. There are dopey mistakes made at all airlines. I believe my company holds the record for wrong airport landings in the Columbus, Mississippi area. (They all look alike! Thank heaven for GPS...)
Deadstik a 38?
flywithastick said:
I know of a guy who landed a T-38 dead stick. I've never been there, but AFAIK it has no alternate hydraulic power source. Supposedly he dove it keeping the engine windmilling supplying hydraulic power (from the engine) and got it down safely.
I think your friend was telling you a "good one!" I'm not absolutely 100% sure, but to the best of my knowledge nobody has ever deadsticked a T-38. The aircraft would become uncontrollable in the flare. Chances of survival are much higher in an ejection.
