ex-nutjeter
- Sep 14, 2005
I wasn't looking at picking a fight, but how do you know that the fuel was freezing? Is it stored above ground, underground?? makes a difference..
Also, I never relied on someone else doing the "Tactle Inspection", I guess you are willing to risk you ticket on someone else telling you it is OK? You are the PIC, you are solely responsible, the blame will be on you no matter what someone else tells you.
You will loose your ticket for taking off with a contaminated wing, but to remove the contamination with hot water is not illegal, I have never seen that written in any SOP's that I have copies of. I have a copy of a Hot Water deicing procedures manual if you want. It is co-written by Transport Canada and the FAA. I have asked this question to a POI that I know, not illegal as long as it is not forbiden in your specific SOP's...
As to this guys flight, He said he was leaving DAB at 0600, if you look up the flights on delta.com, simple check, he would have had over an hour to make his connection to SMF, that is not tight, pretty normal, would have been easy to check before everyone nailed him for making a tight connection
