Cpt Oveur
I had the fish for dinner
- Sep 9, 2007
Doesn't it take many months to reconfigure another carrier's aircraft. My initial thought would be at least six plus months before it is out on the line. Do they have to do flight and certification tests?
The short answer is it depends. It definitely does an acceptance flight(s). Most of the reason it takes a long time is not the physical labor but also the paperwork and recordkeeping. I am not sure if ATA leased these airplanes, but leased airplanes transfering to a different carrier has both its bolts and books looked over very carefully, you'd think the plane was undergoing a C check. Six months, though? I don't think the last ground of ATA 753s going to call were up there that long, but it must be at least 2-3 months I think.
I think CAL's original 753's are etops capable, but when they first bought them it was not their intention to send them transatlantic, it doesn't have the range of a -200. Same reason winglets weren't put on right away like the -200s, the load factor it put on the wing was beyond normal parameters or something like that. Who knows though, CAL never intended to put 757s across the pond when it first bought them. If anyone is going to innovate and find new ways to make things work, CAL will be the one.
