3
350DRIVER
ch,
It is sometimes cheaper to put smaller aircraft on certain routes and aid them by the use of 37's. as well. I think DAL has pulled mainline aircraft off of many routes replacing them with rj's and this may not have worked as good as once thought. There is a major problem at DAL, when you replace mainline flying and jobs you may be helping ASA/CMR out but it does little for DAL since in reality ya'll are suppose to be feeding mainline. Some of the routes that cannot justify a 37 then by all means bring the rj's in but on other once profitable routes you must bring back mainline or DAL isn't going to return to it's glory days. I anticipate you will probably start seeing something along these lines in the relatively near future. What is in place now isn't really working, agree?
3 5 0
3 5 0
