Brutal IPC
  • Thread starter Thread starter TDTURBO
T
TDTURBO
I know there are a lot of CFII's out there and would like to know if anyone has an IPC format or sylibi that is nearly immposible to pass. I want my CFII to give me one tomorrow becuase Chicago hasn't had much IMC this summer and I don't want to lose my edge I've enjoyed for several years.
If anyone has a difficult syllabus, I would appreciate a look. I would prefer a lot of partial panel even though I have a R182 with SS(slaved 1000X), coupled HSI, S-Tec 50 coupled, (this runs off turn coordinator and not the A/I), engine monitor, Trimble 2000 IFR GPS, KR-87 ADF, DME, Garmin 295 on a ram pedastal between the seats, another DG, back up Vacuum, (precise flight), AD pending, so it's being removed with a sporty's electronic A/I with battery bac-up, KX-165 with GS, KX-155 as back up, A23 portable with VOR, 48 spare baterries under seat and a 396 on order possibly, if they get the magnet out of the antenna.
Did I mention a new stereo PXE PS engineering audio panel with stereo/FM/CD/MP3 player and cell phone interface?
This is used as a distraction in these types of situations and I never have in on when in a terminal area in the clag, so don't worry.
I was going to gut the panel and upgrade to a 480/MX20 but am I glad I didn't, I don't do much as it is shooting approaches to acutal minimums, so I felt no overwhelming need to part with 40K when I have a handheld and 396 for 2200 bucks.
Bottom line, I am so well equiped that I find it hard for a CFII to get me in a jam with failures. Instead I would like to concentrate on intersection holds with left turns off radials, ILS back courses, DME arcs, LDA's, DP's, STARS, VOR A's with slam dunks, ect.......... Using only my handheld at night under the hood with a total power failure maintaining ATP standards. I know, it sounds rediculous but I don't expect to pass, I just want to know the best I can do, fail or not.
I think it would be a good workout. This of course with all the necessary VOR checks and paper work up to snuff. I doubt this CFII will challenge me but I do know people on this board have some sadistic lesson plans and would like to pilfer what I can.
I don't like to waste money with CFI's building time in the right seat, I want my brain to hurt so bad that a root canal would be a picnic compared to this anticipated flight.
The usual IPC I get consists of a VOR into OXI, ILS into VPZ and a published hold on each ending with a VOR A into Lansing. Needless to say I am getting bored, I know some of you guys/gals have brutal lesson plans and would like to explore other options.
Does anyone have a link to this sort of info?
Any suggestions would be much appreciated,
TIA,
td
here is what you do, give me your airplane and go rent a cheap-0 172 with the basics. If you can maintain situational awareness in one of those you should be ok in life. But seriously if ya got, it use it. like hell I would turn anything in that cockpit off during a hard IFR approach (minus the sound system)
That's a good idea, but I only fly 2 planes, S2B for my aerobatic training and my R182. I don't want to get two sets of numbers interchanged by flying different models, I can fly an ILS hands off in the 182 because I know the numbers to give me 500 ft/min decent at the OM such as 12" and gear down with a half turn of nose up trim. If I go to another plane, it will just f*ck me all up. I want to be proficient, as one could possibly be, in MY plane, not someone elses.
The Instrument PTS now lists specific requirements for the IPC. It pretty much covers everything of substance that can be thrown at you. There's your syllabus, subject to your CFII's choice of emergencies and diversions.
mislife is correct,but youcan choose how hard tomake it. You can do the whole thing partial panel, do the arc right after the missed from an NDB apprach, do it on a windy and bumpy day.
An IPC is only hard if you haven't flown any instruments in a while.
have fun and good luck.
Almerick's got the right idea. Quit trying to impress us with all the widgets in your plane, rent a 172 and have at it. The challenge of flying an unfamiliar airplane sounds like it'd be right up your alley. Take your handheld along if you want to try that partial-panel/handheld scenario. As for numbers, well, if you can't figger out how to fly an ILS in a 172 without hours of practice, you might wanna' consider gettin' out of flyin' altogether. And flying a different plane is one of the best things you can do to sharpen up your scan. You wanna' get better? Fly a different plane once in a while. You allude to this by saying that you know the numbers and you'd get all f*cked up in another airplane. That's a bad sign. Very bad.
And any CFI worth his salt will tailor the ride to the capabilities of the equipment and the pilot AND take into account any desire on the pilot's part for a little torture. That's half the fun of being a CFI!
Fly on down here to KDMW and I will give you a doosy- all in the ADIZ with unfamiliar fixes and appraoches. It will be at night though, and you will never see the runway.
So, are you not instrument current anymore? Why do you need an IPC? Just grab a safety pilot and go for it. Heck, an instructor and a sim would work too!
Anyway...
Wasn't that the idea?
Seriously, doing an IPC in your own airplane that you know well is one thing, but doing it in an unfamiliar airplane is quite another. If you want a real challenge, you should go do it in a completely unfamiliar complex airplane. If you just want to look good doing a "brutal" IPC in an airplane that you know well, then stick with your own. I mean, you do remember how to fly, don't you?
-Goose
You all have good points, but the bottom line is I want to be as proficient as possible in MY plane, not someone elses.
It can be argued that you always go back to what you were taught and mixing planes as well as mixing rigs can kill you. If I learn to fly a basic 172 with different switch placement in a dark cockpit then go ahead and try to find that switch or lever in another plane unsuccessfully, then I am defeating the purpose of getting good at flying and handling emergencies in MY plane. Look what happened to Janet at Mt. El Capitan, Yosemite(ooops). She was borrowing a different jumping rig that had the pilot handle on her leg strap instead of the BOC while doing a filmed base jump. This is what they believed to cause her death since she reverted back to her "ingrained" training with over 300 jumps with her rig. She borrowed a friends rig that day because she didn't want hers confiscated, (park policy), and consequently died as a result of flying unfamiliar equipment.
I only wish to become familiar and proficient with the equipment I have so if all fails, I can find every switch, lever and handle blindfolded. Switching planes would only mess me up in a pinch because human nature always goes back to what is ingrained in the neuro-pathways, that's why I want it done in My plane. I am legally proficient but still get a full IPC every 3 months to stay current and proficient. There is never "being too proficient", so I do my best to achieve this. The best way for me is to use the same plane. I hope you get it, if not, you will some day when you are flying an unfamiliar plane and things go wrong, you will automatically go back to what you were trained in the most.
The bottom line is safety, to accomplish this, flying the same plane day in and day out is the best way I can think of to maintain excellence.
So, does anyone have a link to a good IPC workout?
[Sermon Begins]
Get on down to ATLDC9 and let him work you over. If that doesn't work, come on out to Oregon and I'll grind on you. The IPC, with a good instructor, is going to depend entirely on the pilot. A day that would give you just the right workout might be way easy, or too much workload for someone else. Certain items have to be accomplished, and the instructor has to check the boxes and be satisfiedbut the 'extras' vary from applicant to applicant. Find an instructor that hears your, "I want a challenge," line and rubs his/her hands together and snickers an evil snicker, and you'll have some fun.
Sounds like you need to find a different instructor. One with enough experience, flexibility, and courage to work you over a bit. What's the point of passing an easy IPC?
And your story about the unfortunate BASE jumper would seem to prove the point of those whom you asked, then dismissed: If you ever find yourself in another airplane in the soup and have a problem, are you gonna' be in a world of hurt? Hmmm...
Automatic responses can be a good thing, or a bad thing.
[/End of Sermon]
No, what killed her was an idiotic desire to fling herself off of a cliff. The location of the rip cord was just a contributing factor.
Switching planes would only mess me up in a pinch because human nature always goes back to what is ingrained in the neuro-pathways.
Exactly. So you'd actually have to slow down and think about what you are doing. I think that'd be a good thing. In my professional opinion as a sadistic instructor, you've become far too comfortable with your surroundings. It raises a red flag in my mind because it suggests that while your technical instrument flying skills are very sharp, your problem solving skills are somewhat lacking.
-Goose
<shakin' head>
I'm so good, my equipment is so good, I know the CFII can't challenge me...
... and you guys still take me seriously.
<shakin' head>
TonyC said:
<shakin' head>
<shakin' head>.
At least I spelled everything correctly! ;) <shaking head of my ..........>
I am far from "too good", I only wish to be pushed beyond the normal minimum standards of the PTS.
Today I found that person, my skull feels like it was hit with a nine iron! This guy was exactly what I was looking for, not some schmuck CFII looking to build time. I learned a lot as well as relying too much on the AP. Flying without the GPS, AP, A/I and DG was hard enough without throwing in an unpublished, non-standard NDB intersection hold. I am going back up tomorrow, I love this guy, he is ruthless!
Don't be so sure of yourself.
Syllibi has two "l"s, and it's not even the correct word. The correct word would be the singular, syllabus. Impossible has but one "m" and has two "s"s.
That was just the first sentence. Need we go on?
Oh, I get it - - you were trying to be funny? As in, you spelled "everything" correctly? Yes, you did spell the word "everything" correctly.
No, wait, you haven't used the word "everything" until now. I guess it couldn't be a play on words, after all.
:rolleyes:
Isn't "syllibi" spelled "syllabi?"
<duck>
:rolleyes:
Man you're brutal!
I still love ya though.:o
<duck>
:eek:
You know you'd never have to duck from me!
LOL
Yepp.
You're right.
That's why I don't claim to be perfect, or even that good. :) I just looked right by that one! OOPS!
This post is pretty funny, here is how to challenge yourself. Get a good instructor and hit a sim. I can't say enough about the "not so norm" You fly your plane all the time and you know where evrything is and how it works etc. The realism comes into play when you are not familiar with a particular a/c, approach, etc. Trust me thats a real distraction and like someone said before that will give you the confidence. I am a freight pilot and flying different a/c throughout the night is part of the gig. This post is not about me so please don't take it that way; However imagine flying all night in bad weather rain, turb, TZ stroms 1/2-1 vis. with all the gadgets, then having to swap a/c in the middle of the night into something that has 2 vor's and and adf.... that's it no radar, no gps, just the basics. Doing this will give you confidence. Flying the airplane is just second nature by this point in your experience. The trick is how do you manage the workload, prioritize your taskes and do what you need to do effectively. We know you can shoot and ILS or VOR/GPS approach. A good sim will allow you to simulate things that are either hard or imposs. to do in a real a/c and give you some solid partial panel and emergency's to deal with. When they see you just getting too overworked you can stop evaluate the situation then dive back into it with another approach to the situation. I highly recommend a sim. Any more ? fell free to pm me. I hope this helps.
Why not fly the IPC in the PITTS S2B. If you can pass the IPC in this palne you are golden.
Because it's not IFR certified.
No sims worth a sh!t by my house either, I would love to try out a sim but have 0 hrs in one.
I think I am going to that place in Springfield and complete their sim training.
I also didn't pay a quarter mil to fly a rental, the only plane I will fly in are the ones I own.
more power to you if those are the airplanes you will ever fly, but having a hard time holding at a non published NDB hold without auto pilot or GPS sure makes me glad I can safely and efficiently fly a beater in IMC when KDAL tower tell me to hold at a 5.7 DME DURING the ILS approach with 30 second legs to help a southwest 737 get in with an aft cargo fire. But I do see your point if you will never fly professionaly.
I did fine, I just want to do it to ATP standards, I can always get better, I just want to learn from a guy that knows more than I do about my plane. I could care less what a 172's #'s are for IR flight, I will never fly one or a GV, I just want to know everything there is to know about the 182rg and S2B. I have taken every type course there is to offer, every engine management class, all the wings classes in my area, so I only wish to find someone better at flying my plane then me and that is getting hard to find.
"Oh, Lord, it's hard to be humble...when you're perfect in every way!
I can't wait to look in the mirror, 'cause I get better looking each day!
To know me is to love me, I must be one helluva man!
Oh, Lord, it's hard to be humble, but I'm doing the best that I can..."
The person who knows everything there is to know about a S2B is Art Schol. You can ask him.... wait, Art Schol is at the bottom of the Pacific Ocean and can't get to a phone right now. What I am trying to tell you is that the only way to know everything about an airplane is for the plane to kill you. You will realize the split second before you die what you need to know. Art Schol knows exactly what happened to him in his Pitts and he aint telling nobody.
You should publish that as a song - - I'll bet Mac Davis could sing it.
"I used to have a girlfriend
But I guess she just couldn't compete
With all these love starved women
Who keep clamoring at my feet
Well I probably could find me another
But I guess they're all in awe of me
Who cares I never get lonesome
Cuz I treasure my own company
(chorus)
I guess you could say I am a loner
A cowboy all locked up and proud
Well I could have lots of friends if I wanted
But then I wouldn't stand out in a crowd
Some folks say that I'm egotistical
Hell I don't even know what that means
I guess it has something to do with the way
That I fill out my skin tight blue jeans"
