Brakes work...
Ummm...the training/service bulletin (written by EMBRAER) in the SOP did.
You don't have to send the pax flying forward because the sop says so. The key to that is continuous breaking not hard breaking. Other manufacturers do not recommend continuous breaking.
The Q400 also has carbon brakes. We are told the same thing "light applications ruin the brakes, firm application is needed". I thought I was applying firm brakes then had a checkairman tell me to put about twice the pressure on. Way too much in my opinion, but I do press firmer than I use to.
I swear to god, I feel more stupid every time I visit this site...
I could care less about "wear and tear" and ATC constraints. I will do what is best for passenger comfort.....that is part of professionalism.
If airlines were concerned about brake wear from light applications of the brakes, they should install brakes that resist deterioration from light applications of brakes.
I would chalk this up to a "not my problem" issue. I avoid using the brakes anyway because Beta is cool and usually effective, but I won't over-use the brakes just to save the company a little bit of money.
Do you mean the manufacturers?
Part of being a "professional" is adhering to guidelines, SOPs, and recommendations supplied by both your company and the aircraft manufacturer.
Who's the real retard, the retard? Or the guy that argues with him?
Do you guys think that the military guys or the civilian guys know how to brake better?
Clearly the military guys can brake better because they are evaluated on it. And they have those patches on their jackets which add more credibility.
Most airplane manufacturers do not want you to use heavy breaking. We are only talking about carbon brakes here.
Mother of God...I'm no grammar nazi with my KY public school education but for fark's sake, you profess to be a professional pilot:
break = snap. malfunction. not working properly. fail.
brake = stop.
brake = stop.
Are you really that gullible?
I was coming in on a DL 767-4 the other day into ATL. There was no long out flare or anything, and from the look of it, we were easily in the touchdown zone. For whatever reason the brakes were stomped on and we turned off at a high speed. Being 5:30AM-ish, it wasn't a busy time at the airport. In the process of the heavy braking, a galley cart and some other stuff came loose and flew forward and you could here the shattering of stuff breaking. Loud. Startling to some pax. And it wasn't smooth braking. It was rough and jerky.
So I ask, "what's with all the heavy braking at mainline carriers?"
Now, I'm sure there was a reason. Just like there are probably reasons why you experience "so much" heavy braking on your regional flights. Must be all the "unprofessionalism" and the lack of hats at the regional carriers.
It's probably because it was a redeye flight. the pilots probably just woke up when the autoland kicked off. Seriously though redeye landings tend to be hit or miss, that's my 2 cents.
Probably military pilots, they never learned to give a crap about passengers, just hitting the third wire at all costs. Corporate pilots would NEVER make that mistake.
Okay, sorry - I just couldn't resist throwing the grenade in!
I'm kidding, I'm kidding!
During IOE, a demo of the "MAX" setting on the autobrakes is required at least once.
It can be quite abrupt...
Either that or Baby Huey wanted to make the first highspeed...
I'm really surprised that this thread has gotten to page 4 and nobody has mentioned that that the carbon brakes on the E-145 are designed to be applied firmly. Unless things have changed since I flew it, one of our bulletins detailed how the carbon brakes, as opposed to conventional ones, wear less the HARDER you apply them. It seemed crazy to me and it certainly went against passenger comfort but we were advised not to use gentle, consistent braking due to it causing greater brake wear. A firm continous application resulted in less brake wear and more effective braking.
Anyone?
Bing !!
You are correct more wear occurs with Carbon brakes on the taxi out than landing. It is the cycles, or number of applications, that cause most of the wear with Carbon. There is a good video, if you can find it, made by a brake maker explaning how Carbon brakes wear.
Bing !!
To the best of my (admittedly very limited) knowledge, it doesn't say that one application has to be max effort. Sorry, but I see an appalling lack of judgment and airmanship - RJ or B-747 on an 10K+ foot runway you usually don't need to demonstrate max effort on the brakes...
As a passenger... I always thought it was fun when they land hard and slam on the brakes... :-D seriously.
Yay for 3 pages!
Floating, floating, floating until you grease the landing with the power still on the engines... then SLAM ON THE BRAKES!
I've never understood how someone can care so much about a landing and so little afterwards.
why has this thread gone on for so long?
yeah you are right somebody needs to slam on the brakes and break this idiotic thread........
Almost forgot MESA SUCKS as does the braking on most rj flights...:puke:
just be happy you landed on a runway and not a taxiway.
I hear you Jeff....The other day a AAL 777 landing 27R floated a good 4000ft down the runway, touched down near the 14L intersection. My jaw dropped. Why he didn't go around I don't know, but they finally greased it, slammed on the brakes and almost ran off the runway. I say plant the plane in the TDZ. Nothing more worthless then runway behind you.
