On Your Six
- Mar 8, 2004
mdw is closing and dtw is opening to compete with delta
Great, you'll lose just like in SLC and very soon in ATL. Btw, great culture you had....
Godspeed!
OYS
Godspeed!
OYS
harlingen, the mexican food is much more authentic.
I thought SWA was code sharing with Volaris out of Harligen????
That has changed as of this week. I'm not saying it will be the base for sure, but it is most certainly back on the table. How long ago did GK make that comment?
Been hearing not. More likely TPA, LAX, SMF, PHL, or maybe even SAN. DEN is probably out of the running.
Doesn't the system chief live in DEN?
This is what I have heard from the higher ups. 717s will be moved out of Atlanta. Number 1 on the list is Nashville. The size of the Atlanta operation will be cut in half since it will no longer be operated as a "hub". LAX will most likely be the launch point to Hawaii from the West Coast. Management wants to max out aircraft utilization on the 800, so most likely the aircraft will not be based in LAX, but in some other city so ETOPs crews will do 2 legs to Hawaii. Management wants crews as close to 8 hours of flight as possible for the day. Large metro to large metro, then Hawaii. Guarantees max loads and max crew utilization. 5.5 hrs to Hawaii from LAX, so a 800 base within 2 hours of LAX is probable. DEN? Who knows.
