ASA, DAL almost collide in ATL
captainv
Let's be careful out there...
Passenger jets within seconds of collision at Hartsfield
By JIM THARPE
The Atlanta Journal-Constitution
Published on: 01/11/08
A Mexico-bound Delta Air Lines Boeing 757 came within a few seconds of colliding with a smaller commuter jet Friday in Atlanta as the smaller jet crossed a runway in front of the larger craft, which was going more than 100 mph on a takeoff roll.
The incident, which occurred about 10:30 a.m. at Hartsfield-Jackson International Airport, has sparked a formal investigation by the Federal Aviation Administration, said FAA regional spokeswoman Kathleen Bergen.
Bergen said initial indications suggest the pilots of Atlantic Southeast Airlines Flight 876 to Greensboro, N.C., improperly taxied across the runway after controllers in the Hartsfield-Jackson tower ordered the plane to stop short. The pilot, Bergen said, apparently acknowledged those instructions and repeated them back to the tower, but the jet continued across the active runway.
"At this point we consider this a pilot deviation for the pilot in ASA plane," Bergen said.
There were 130 passengers aboard the Delta flight and 44 aboard the ASA jet.
ASA officials said they also are investigating.
"The safety of our passenger and our people remains out No. 1 priority," said ASA spokeswoman Kate Modolo. "We currently are conducting an internal investigation, and we are working in cooperation with the FAA regarding this occurrence."
No one was injured, and both airplanes continued on their way. At the closest point, the two planes came within about 1,250 feet — or about 2 to 3 seconds of colliding, according to air traffic controllers.
"It's fortunate the (ASA) plane continued through the intersection because the Delta flight could not have stopped," said Doug Church, a spokesman for the National Air Traffic Controllers Association. "If that (ASA) plane had stopped, there would have been a collision."
The Delta plane, Flight 261, took off and continued with out incident, landing in Puerto Vallarta, Mexico at 12:49 p.m., said Delta spokesman Kent Landers. The ASA flight later took off without further incident and landed in Greensboro at 11:23 a.m.
"As always, safety is our No. 1 priority at Delta, and we will work closely with the FAA to provide information as needed," Landers said.
Not that it really matters, but for informations sake it was a very senior cp and very senior fo on the acey flight.
What's very senior???? He's barely in the top third on the 50. Capt is a little over 8 yrs, FO is a year and 9 months. Very senior? Not really...
You're not looking at the right flight. It's the second flight to GSO this morning.
Flight from ATL crossing an active runway? Maybe crossing 9L/27R heading down to 10/28 for departure?
If so, that can be such a cluster when that operation is in effect.
I was trying to figure the same thing out. GSO is a north or east departure? 10/28 departure is the only thing I can figure if the AJC got the flt number right.
Well my posts were removed because too many people complained that my info gave away who it was....
....my poinit was that it wasn't a senior FO..... it was a junior FO.....contrary to what was posted earlier....
....the main point that should be discussed is whether or not all the "briefing" BS contributed to this event.... Maybe less "briefing" and more heads up and ears to the radio is in order....
......it will be interesting to hear the training dept./FAA spin on this..... probably yet another procedure that will simply compound the problem......
Last week we were told to cancel take off clearance on 27R as a Delta 737 rolled across the hold short. We were doing about 50-60 knots. Tower was none too happy and they got a phone number. It goes around...
MODERATOR NOTE:
DO NOT POST ANY INFORMATION ABOUT WHO THE PILOTS WERE. THIS INCLUDES, BUT IS NOT LIMITED TO...
SONORITY NUMBERS
DATE OF HIRE
ETC.
You get the idea. Thanks in advance for your cooperation.
MODERATOR NOTE:
SONORITY NUMBERS
DATE OF HIRE
ETC.
I didn't post "sonority" number, DOH, etc..... I just posted that this wasn't a real senior crew as was posted earlier.... if you want accuracy, you would remove the post that said this was "a senior crew".......
I understand the issue of protecting the crew, but it isn't fair to portray this as a "senior crew"....... Fair and Balanced.....
Checking the etrip info again, the first flight to GSO was a junior crew. The second flight to GSO (the one in question) was a senior crew.
Again, not that junior vs senior matters. I primarily pointed it out considering there are other threads on the forum discussing the cost of having more junior flight crews.
Not that it is an excuse, but it will be very interesting if a contributing factor was the FO doing a taxi engine start, and the other stuff merchant mentioned.
I believe GSO is a DAWGS departure which is normally 9L/27R, but can be switched to a 10/28 sometimes.
I agree Joe, there is a time and place to run checklists. So many people get so worried about getting the brief and checklist completed.
Theres a time and place to run checklists. And at busy airports you will eventually be stopped behind someone for a long time to complete the required checks.
I am not trying to be monday morning quarterback, and I don't know what happened there in ATL. But I don't know how many times I have told new FO's that I am not ready for that checklist. And try to explain to them that if I am busy in a turn or looking for taxi ways I am not gonna hear one word there saying anyway.
Be safe out there everyone and don't get so rapped up in the damn checklist that you forget whats going on around you.
ASA briefs on the taxi roll??
Why wouldn't you? If the work load is low you can do that briefs while moving.
I don't know what ASA's SOP's are, but I have jumpseated on my airlines that do there checks on the taxi roll.
Theres no problem with it when there no workload involved.
Most majors not only brief on taxi, but also get all the weight and balance data, performance data, and set speeds. Delta is one of the few that still do that at the gate.
With all the emphasis on hold short clearances it does make you wonder what what going on in that flight deck. It also makes you wonder what action the feds will take on the crew. If it is only a license suspension hopefully ASA will allow him to keep his job.
