ASA Considers iPad EFBs
not true, they have been available in .PDF form for many years and any reader that can read .PDFs (sony, kindle, iPad, etc) can access them.
Yes, you could previously have viewed Jepp plates printed as .pdf on iPad.
That's not exactly the same thing as having a user-friendly, dedicated chart viewer application like Jepp Mobile TC is.
Does anyone here have an iPad...there is NO WAY that it would hold up to the beating it would take as an EFB. Way too fragile...thats why the currently approved EFB's are "currently approved"...because they are very resiliant. One day of use and that delicate screen would be shattered.
Here's the iPads newest problem. This won't work in a hot cockpit.
...the iPad will shut itself off after remaining in direct sunlight for long enough...
http://www.cnn.com/2010/TECH/gaming.gadgets/07/28/lawsuit.filed.overheating.ipads/index.html?hpt=T2
I think a better solution would be the Kindle, it wouldn't be so fragile and at $139, who cares. That's for the WiFi version. The battery lasts a month. Bring it inside once every 2 weeks and run an update. I'd much rather do that than leaf thru my updates manually. We've got a captain that has been trying to approach management about using the Kindle. Not sure, can it run apps? Cause if it's just PDFs that's not going to work.
Jepp has a program for the iPad now, just released. How long do you think it would take to get 121 approval for it? The iPad will be obsolete by that time....
So where is this thing plugging in to? A proprietary Apple/ARINC module? It's a pipe dream. How about buying off-the-shelf technology that's meant for professional use and not some GA toy.
Check the specs for ALL previously FAA approved EFB hardware systems (both Class 1 and II). Every one of them has a maximum operating temperature of 95 degrees f. The difference now is that the iPad goes standby to protect itself when exceeding 95 degrees while all the others continue operating until they hard-fail if operated overtemp long enough.
When the iPad goes into shutdown mode, it can be restored simply by placing it out of the sun (or in a cooler area) for about 3 minutes. It is much tougher than any existing EFB system (except for the Panasonic Toughbook, which is too big for normal cockpit use). The only way I have been able to get mine to overheat is to place it on the glareshield.
the ipad has a major problem that if you actually use it more than 24 times and not use it as table decoration, it actually explodes.
In a recent RGT speach by SH, HE brought up the fact that ASA was looking into replacing ALL the pubs with a iPad EFB. Said the bigest stumbling block was the battery and blocking the internet.... Seems like if they are down to those hurtles, that they are pretty far along in the process... Sure would be nice to carry that insted of the 40lb flight kit! Maybe this is their solution to the W&B problems with the CRJ!
Would this alleviate the need for each pilot to pack 3 bags and flight case for a 4 day and put them all in the overheads so as to keep the paying pax from using the bins?
I just flew on a ASA flight with a full crew on DH to DTW and there was zero overhead space from row 10 back on a CRJ700. Man, you guys can really pack some stuff. Its comical watching you guys pulling your trains of bags around in ATL. Pink or green tags, or whatever they are for you guys, learn to use them. You can even go down and get them yourself with your SIDA badges!!!
You ever heard of rampers losing a crew member's bag on day 1 of a 4 day? Sorry, but the bags stay in the cabin - where the company say's they are supposed to be! Thanks for the tip, though.
Think I might pack an extra back as if I'm going on an excursion now. Thanks, doosher!
You ever heard of doing a walk around after each leg? Never had my bag pulled in 7 years of commuter flying. If your policy is for you to put the 27 inch Purdy, tote, and backpack in the bins, then that is where they need to be. Tell management thanks for the job security.
HA! Hilarious! I recently WALKED my bag from the jetbridge to HAND it to the rampers at the back of the plane, asked them to put it in the cargo bin - all with crew tags all over it - and guess what? It didn't get on! More recently, my FO's bag was on the jetbridge, and 3 different agents/rampers asked and were told this was a crew bag and it was going back on. Guess what? Someone took that bag off the jetbridge and put it on the aircraft parked at the next gate! I've had a flight attendant walk out on the ramp for the first flight of the day and put her bag on the cart. When we left, no bags on the cart......they put it in the back with all the other bags, right? Nope. Some genius grabbed it off the cart and sent it to baggage claim thinking it was left there OVERNIGHT!!!! Sorry, that plan still doesn't work, and I'm too busy on a 20 min turn to babysit bags!
As any flight attendant who pink tags her/his bag. They'll tell you about the times it never made it to the overnight. Bad idea. As far as overpacking, it has to do partially with the fact that most of our guys are slam clickers and pack 5 days worth of food, their computer, two pairs of running shoes, sweaters, jackets, clothing, and for some strange reason, just one uniform shirt for 5 days.
As opposed to the guys who get in, have to quickly change and head to the nearest bar to drink all night and spend $60 bucks a night drinking? So whats wrong with the people that save money by bringing food, and exercising instead of drinking?
Well, I am truly sorry that ASA has such a low expectation and tolerance of ineptitude in their ramp/gate employees. I am now in agreement with you! Put you bags in the cabin and let the paying pax have the lost bags. Again, please tell your management thanks for all the effort they put into the betterment of the fractional industry.
A side story, if you will, that goes nicely with yours. Airline in to OMA on ASA. Wait in the jetbridge for bag. All bags are gone and I am still there. Agent very forcefully explains to me that all the carryons are unloaded. I suggested that they were not. I was then informed that I had checked my bag and that it would be at baggage claim. I explained that it looked like the "real" pilots' bags and I had physically placed it on the cart in the rain in ATL. He mumbled something about baggage claim again. I went to the ticket counter downstairs and found a more than competent and way less methed out Frontier agent who gladly took my $20 to go look for and retrieve my bag from one of DL's Canadairs. He and I chuckled about it. I then got in a cab for the hotel, single bag for a 7 day with a clean shirt for every day and some play clothes;), in tow.
All of ASA's baggage handling in ATL is done by Delta. Additionally, OMA is handled by REAS- Regional Elite Air Services, another Delta-owned company. Unfortunately we don't have many ASA-handled stations left anymore; a shame, because many truly cared about delivering a quality product and service to ASA's customers, and took pride in the company they worked for.
I know they did. So did the many XJ and 9E and NW ramp and gate personnel over the years that endured the carnage of Hurricane Northwest. It is a shame what has happened to them and to the products that they were proud to be behind.
We used to personally place our overnight bags into very large high-visibility yellow vinyl bags which would Velcro shut and place them in the cargo bins ourselves. You couldn't miss these things. The rampers would then remove from the airplane, struggle to get them out of the yellow "crew bags", and send them to baggace claim, another airport, etc... They of course would say "what bag?
Hey, dbag dork-nuts, ASA doesn't have any ramp "slash" gate personel. The same thing happens to me on mainline. Retrieving my bag from baggage claim in Atlanta is not unfamiliar. And yet I still don't cry on FI for the Delta pilots to "implore management best recognize". Take that stick outta your butthole. That is a stick right, Frances???
Who says you can't exercise then drink?? Sounds like a cop out.
slam-clicking and "saving money" = masturbating
I follow a simple rule, there are two kinds of baggage, carry on and lost! I only check when I am forced to, gate check if possible.
As any flight attendant who pink tags her/his bag. They'll tell you about the times it never made it to the overnight. Bad idea. As far as overpacking, it has to do partially with the fact that most of our guys are slam clickers and pack 5 days worth of food, their computer, two pairs of running shoes, sweaters, jackets, clothing, and for some strange reason,just one uniform shirt for 5 days.
That is so true. I've seen guys wearing the same dirty shirt for days and they tell me they can't afford shirts and here they are stuffing their faces twice a day with those $5 lattes.
I believe it was widely discussed a couple of years ago about Delta taking over the ASA gate/ramp stuff because of the unreliability of the personnel working there at the time. It has gotten just a teeny bit better, but that's like saying the hurricane must be past because the wind has dropped to 74 mph.
Maybe the current/past personnel there think they are/were delivering a quality product and service but I have never heard ANY customer say anything good about the product. I travel from ATL to the Tri-Cities area 6 or 7 times a year. My choices are one hour on an ASA RJ or a five hour drive. Choose the drive...every time.
And I made it in 39 minutes the other night! Enjoy your drive.
well then enjoy your drive, our flts to TRI are usually full anyway so you're not missed
If the RJ is almost full then I know I will be better off at 5 hours in an Escalade. If ASA put an RJ90 with first class seats on that route I would probably take the flight. When they put the 15th seat in the 200 series it became too crowded for us taller folks.
No need to be a dork, besides instead of the escalade why not drive the falcon?
