BushwickBill... yes it will be in our twins(mostly Barons), however even though they are single pilot airplanes, the FAA gives authority to our CP to assign an SIC to that run which then makes that single pilot a/c a two pilot a/c since the assignment of the SIC makes him a "required crew member." It has been talked about, and debated, on here before, however the letter of authority from the FAA that we have on file says exactly what i put above, which puts all debate to rest actually. I did it back in 2000, for 8 months (started here with 500tt) and it was nice to get to participate in the action before being thrown out on a run for the first time the same night you pass your checkride...it gives you a better feel for the operation and what is expected of you when you are ready to upgrade.
aperson, I believe the above about ~100 hours a month is pretty close, and i think you will do most of your SIC'ing out of LCK...they used to let you pick where you wanted to go, but now it is all assigned by the CP so that you will gain the most hours in the shortest period of time.
